Cleaning up XP
PostPosted: 15:03 - 20 Jul 2010    Post subject: Cleaning up XP Reply with quote
Any currently recommended good 'do it all' programs for speeding up an ageing XP system?
Helping somebody out with a slow XP system. I've upgraded the memory (to 2.5gb from 1gb) and poked around a bit at other stuff, defrag, clean out the startup folder (haven't checked what else is starting up from registry etc yet.)
It does have a fair few things running, but seems to be slower than it 'should'.
Did have active ant-spy-virus-etc running.
MarkJ
PostPosted: 15:17 - 20 Jul 2010    Post subject: Reply with quote
Have you run the 'msconfig' command in the run box, gone to the Startup tab and disabled anything that doesn't need to be run on startup? That normally speeds things up a bit for me.
Does it have any virus' in the system running anything at full CPU?
panrider_uk
PostPosted: 15:51 - 20 Jul 2010    Post subject: Reply with quote
Autoruns
Ccleaner
Defraggler
Set any unneeded services to disabled or manual start
Mark
Misc
PostPosted: 16:06 - 20 Jul 2010    Post subject: Reply with quote
Format. Will solve the problem. It's a hassle if you can't back up data or have a copy of an OS to use but if they have/can then i find this is the best way.
PostPosted: 16:36 - 20 Jul 2010    Post subject: Reply with quote
Will be properly going through start up things next time I'm there.
No viruses, didn't check too deeply about what malware protection/detection it had.
CPU was fine when it was at rest.
I did suggest a format, as in my experience this is the only way to get back to 'new' system performance for XP, but that's going to be too much hassle right now.
panrider_uk wrote:
Ccleaner
Cheers - have used this before at some point so will give it a go Thumbs Up
Misc
PostPosted: 17:36 - 20 Jul 2010    Post subject: Reply with quote
There was a free software that used all the popular cleaners in one so saved a lot of time & obviously found more crap then just using one.
Sure someone will remember the name of it.
The Artist
PostPosted: 19:43 - 20 Jul 2010    Post subject: Reply with quote
Re install it.
Better than any program. Only takes a couple of hours.
DJH
PostPosted: 19:53 - 20 Jul 2010    Post subject: Reply with quote
Tuneup utilities 2010.
everyreasonto
PostPosted: 23:36 - 20 Jul 2010    Post subject: Reply with quote
https://www.youtube.com/watch?v=G5mGAUwMbXg
Thank me later
PostPosted: 23:53 - 20 Jul 2010    Post subject: Reply with quote
If it was me, I would reinstall - for the record, I have probably installed XP hundreds of times!... well, over 100 at least Smile - having worked in a 'production' department of an IT service company in the past, I created images for new PCs, documentation on installing it 'our' way etc (including initial testing of XP when we first started to use it in the company - yes a few years ago!), but a bit out of touch with latest such software.
However, the computer's owner doesn't want to, so it's not happening. Don't blame them from a 'newb' point of view with the amount of hassle it can be getting all the settings you've got used to over the years reconfigured.
Free trial unfortunately and this wouldn't be a case of 'serialz'.
Startup, Ccleaner and double checking his anti mal/spyware/virus system should do me - cheers for the thoughts Thumbs Up.
Phoenix
Twisted Firestarter
PostPosted: 00:52 - 21 Jul 2010    Post subject: Reply with quote
To be honest all those programs do exactly what you probably already know to do manually such as checking the 'run' sections in the registry and removing services using msconfig or system admin tools.
Most slowdown is due to anti virus/spyware stuff, different programs have different effects, such as AVG used to work fine on my old AMD XP2000 until version 8 totally stalled it, much like Norton will kill any computer's performance, just don't understand why people use that. A lot of spyware programs cause a lot of slowdown too just by running but some have extra stuff such as background scans and email scanners running by default, all clog it up.
Internet explorer addons also kill the computer while browsing so switching to firefox is the best way to speed that up rather than trying to remove all the junk that gets bolted onto IE.
Another good program I use to check exactly what is running including viruses and unnecessary programs that often wont be found in the normal places to look (registry/run or services) is Security Task Manager. Just use it to identify stuff and then remove it or disable it manually.
PostPosted: 08:28 - 21 Jul 2010    Post subject: Reply with quote
Yea, I've got annoyed with AVG and made a point of researching the speed of different free anti-virus programs before installing last time I did it.
Unfortunately the computer in question has got quite a lot of silly background tasks, but the obvious ones I could see at least were 'wanted' unfortunately.
Deckx
PostPosted: 03:39 - 03 Aug 2010    Post subject: Reply with quote
i've been using "System Mechanic" for last 5-6 years...excellent program... Just run automatic maintenance wizard and it does the lot..
deleted111
PostPosted: 10:50 - 03 Aug 2010    Post subject: Reply with quote
Only scanned the thread so my apologies if it's already been mentioned.
I use TweakNow Powerpack and not had any problems with it, hasn't cost me anything and seems decent enough. Although with the age of this thread, any advice from here is perhaps as useful as a chocolate kettle?
Either way, hth.
Steve.
The last post was made 16 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 79.77 Kb
