| dextersaurus |
 dextersaurus World Chat Champion
 Posted: 23:39 - 04 Jul 2010 Post subject: GPZ500s carbs... |
Well, with my new purchase not starting, i decided to strip the carbs, and clean them out. Found that the jets were blocked up, so cleared them and fitted it back on.
I then started it up on full choke, and it ran for about 3 mins, idling at about 3k rpm. It was smooth enough, no wierd noises coming from the engine, then it started to bog down and then it just died and refused to start again. There was plenty petrol in it, and the petrol tap is functioning properly...
I left it for 5 minutes, then turned it over, and it spluttered, then just kept turning over, not starting.
Is it a carb issue?
And would starting it without an airbox on it cause this problem? i'd have thought it would make it run crappy at the most...
Dunc |
| Paddy Blake |
 Paddy Blake World Chat Champion
| dextersaurus |
| Ingah |
 Ingah World Chat Champion
| Kickstart |
 Kickstart The Oracle
| dextersaurus |
| Paddy Blake |
| el_oso |
 el_oso World Chat Champion
| dextersaurus |
 Posted: 09:13 - 06 Jul 2010 Post subject: |
So, if replacing the spark plugs doesn't work, i'll replace a coil.
flush tank with new petrol, clear jets on carbs again...
If it doesn't start after i've done that i'll shout on here
Dunc |
| c_dug |
 c_dug Super Spammer
 Posted: 10:01 - 06 Jul 2010 Post subject: |
With the GPZ the_godfather is on about cleaning up the terminals on the coil made a noticeable difference before you go replacing parts needlessly
c_dug ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Kickstart |
| dextersaurus |
 Posted: 10:27 - 16 Jul 2010 Post subject: |
Well, since i've not had much time to actually work on the bike recently, i spoke to my old man (who is more familiar with old british bikes - he has a Royal enfield and an old Francis Barnett) who i let do the pilot screws on the carbs, and he told me that he had screwed them 2.5 turns from the end... so that'll be why it's not running
I'll post up when i sort that and see what happens.
Dunc |
| dextersaurus |
 Posted: 16:45 - 20 Jul 2010 Post subject: |
Yo guys.
So today since it was nice and sunny, i took the carbs to bits.
Cleaned up everything, sprayed the jets through with carb cleaner and let them soak before fitting everything back together, then sorted the pilot screws.
It did take a VERY long time to start, backfired through the airbox
But then it fired into life, and sounded quite good.
Ticked over at 1.5k revs on choke so the idle screw needs sorted...
But me being me, i forgot to attach the petrol tank so it used the petrol in the carbs and then died.
So when i attached it again, all it was doing was turning over... then the battery died.
So i'm leaving it on the trickle charger overnight, and i'll get back to it in the morning - see what it's doing then.
I also checked the spark from both plugs - It was a strong spark from both, but they were kind of white which goes with the fact it's been running lean from when it had the pilot screws done wrong.
So it's definately getting a spark, and the carbs are definately getting petrol, so the problem is lying in the fuel getting from the carbs to the plugs.
To be honest, i have no idea how to properly strip and clean a set of carbs, so i only took the float chamber covers off, and the top covers (of the diaphragms) off and cleaned about inside there - never split everything. I think that may be a job for someone more technically minded or experienced than me.
On a side note, can someone direct me to a replacement set of screws for the carbs on the GPZ? the ones on it are.... old to say the least - need different screwdrivers for each screw.
They are keihin carbs, and the replacement screws i bought don't fit as they are all too small.
Dunc |
| Casper |
 Casper World Chat Champion
| dextersaurus |
 Posted: 18:40 - 20 Jul 2010 Post subject: |
Tried that and the tank seems fine, the breather isn't blocked.
Also, i cleaned the choke bits today, it's not that - They are definately moving freely.
The battery is charging now, so i'll go tomorrow to fill up the tank with fresh petrol, and see what happens then.
Also going to stick the new air filter in and change the oil, see how that affects things...
Dunc |
| el_oso |
| dextersaurus |
| c_dug |
 c_dug Super Spammer
 Posted: 14:24 - 21 Jul 2010 Post subject: |
Either that or when I was doing my TDR a while back I used a carb specialist in manchester somewhere, im sure they will stock the original screws (or ones that fit) I found them online, I made a post on the TDR forums about them so i'm sure i can find the website again if you can wait a day or two?
They were really good and very helpfull with advice  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| c_dug |
 c_dug Super Spammer
| dextersaurus |
| Kickstart |
| dextersaurus |
 Posted: 15:18 - 22 Jul 2010 Post subject: |
Since there is only two of them, the left is connected to the left and the right to the right.
There can't be a lot of things that's stopping the bike from running.
Cleaned the carbs, now it just backfires and coughs
Cleaned the Plugs - got a nice strong blue spark
Changed air filter/oil
Probably be checking the valve clearances tomorrow though...
Anything else?
Dunc |
| Kickstart |
 Posted: 15:23 - 22 Jul 2010 Post subject: |
Double check the wires to the coils, and try a strobe light on it to check the timing is right, but I would suspect it will be fine (although on an older one with the self destructing flywheels you might have odd ignition problems if some bits of magnet go astray).
If you check the valve then the first thing to check is probably the cam timing. Also worth doing a compression check while you are at it.
| dextersaurus |
 Posted: 15:28 - 22 Jul 2010 Post subject: |
Cheers keith, i'll get on that and post up when i know more  |
| dextersaurus |
The last post was made 15 years, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
