xj 600 diversion starter probs
mtr diversion
PostPosted: 21:06 - 20 Jul 2010    Post subject: xj 600 diversion starter probs Reply with quote
Hi all, got a prob with my xj 600, starter motor i think. plenty of battery, relay clicks, not cranking engine. When i push start button oil light comes on. Any ideas would be gratefully received.
Cheers MICK.
radical
PostPosted: 21:12 - 20 Jul 2010    Post subject: Reply with quote
Try bridging the 2 main terminals on the starter relay 1 terminal will go directly to the battery and the second will go directly to the starter motor, if the starter turns over then your relay is faulty. Also check your main earth connections to the frame and engine for tightness and corrosion. Have you tried starting the bike with jump leads?
mtr diversion
PostPosted: 21:20 - 20 Jul 2010    Post subject: Reply with quote
Hi radical thanks for speedy reply. Had a friend look at it, got full 12v at starter could it still be relay fault. Will check earth connection anyway.
radical
PostPosted: 21:25 - 20 Jul 2010    Post subject: Reply with quote
Yes it could well be the starter relay, look forthe 2 large terminals and bridge them with a spanner or large screwdriver and see if the bike starts although my first thought would have been the battery or loose battery/earth connections.
radical
PostPosted: 21:31 - 20 Jul 2010    Post subject: Reply with quote
another option would be to connect a car jump lead from your postive battery terminal directly to the starter motor terminal, this will bypass your solenoid and will also prove if your stater motor is faulty but do check all the battery/earth and starter motor connections first and also check that your battery is holding a voltage of around 13 volts with your ignition turned off.
mtr diversion
PostPosted: 18:23 - 21 Jul 2010    Post subject: Reply with quote
Hi all, think solved Smile . Took starter apart no travel left on brushes. Totally worn Crying or Very sad . Any ideas where cheapest parts available. I hear that honda's are the same part. Wink Wink
The last post was made 15 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 45.86 Kb
