Cb350s burning oil
rob_scott92
PostPosted: 22:35 - 20 Jul 2010    Post subject: Cb350s burning oil Reply with quote
hey guys,
After riding the 350 for a couple of months, i've had a little problem regarding oil.
It is definately burning oil, i know that, but its getting to the point where i'm actually a little worried about it. Its only got a small dipstick and to check the oil it says in the manual to run the engine for a minute, turn it off, let it settle and then check the level without screwing the dipstick in. The thing that worries me is that with the slightest difference of angle change (Flat surface or leaning very slightly to the right) the level shows full to not even touching the end of the dipstick.
Its got to the point where i'm topping it up every couple of days, i think in 3 months i've gone through 2 litres + just topping it up Shocked
I understand it could be more than one thing doing this, it has got 45K miles on it too.
Valve seats, valves and piston rings. Anything else to consider? and anyone got any experience doing these things on the cb350s or similar (250 superdream???) Finding parts could be an issue and finding money even harder.
Would using a thicker oil burn less? Its got proper 10w40 motorcycle oil in at the moment.
any help appreciated
Rob Thumbs Up
First bike: 1982 Suzuki Gs 125 'The beast MK1' Wink > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p
Frost
PostPosted: 22:48 - 20 Jul 2010    Post subject: Reply with quote
Thicker oil will burn slower. Valves and valve seats won't cause oil to burn, stem seals & rings will. Run it for a bit and see if anything leaks out when its warm.
You can normally see and smell if oil consumption is a problem, if not just keep topping it up and using it. i have a superdream that used to chug a fair bit of oil, always ran fine though.
Robby
Dirty Old Man
PostPosted: 14:07 - 21 Jul 2010    Post subject: Reply with quote
Depending on how much you want to get stuck in, stem seals normally come in a pattern gasket set, which is about £25. This means you can strip the top end, check the ring end gap, regrind the valves and fit new stem seals.
The only problem is that the camchain may run between the cylinders, which can make it more difficult to dismantle.
rob_scott92
PostPosted: 14:13 - 21 Jul 2010    Post subject: Reply with quote
From the manual it does seem that the cam chain does run between the cylinders, although in the manual it doesn't mention a cam chain, only a 'balancer chain'. I started a thread about it on here once to be told they are not the same thing Thinking
It doesn't leak at all which is a novelty really, my 125 used to leave a little puddle of oil everwhere i parked up which got a little annoying Laughing Its nice not having that to worry about now.
Perhaps on the next oil change i'll put some thicker oil in Wink
rob_scott92
PostPosted: 14:14 - 21 Jul 2010    Post subject: Reply with quote
Also gaskets! There arent any on ebay or wemoto which means i'll have to go to a bike shop to get them Sad A little expensive i imagine Rolling Eyes
rob_scott92
PostPosted: 14:30 - 21 Jul 2010    Post subject: Reply with quote
david silvers ?
Shifty
I completely forgot about them! I'm so used to discarding them as i'm used to getting parts for the suzuki Laughing
I shall check now Thumbs Up
rob_scott92
PostPosted: 14:37 - 21 Jul 2010    Post subject: Reply with quote
No gaskets whatsoever Sad although there are quite a selection of spares on there, just no gaskets Laughing
radical
PostPosted: 18:23 - 21 Jul 2010    Post subject: Reply with quote
To save on gaskets you could change your valve stem oil seals ( there are six) without removing the head from the engine and see if that cures the problem first, failing that it is going to be the piston rings and /or cylinder bore.
Moo.
PostPosted: 18:27 - 21 Jul 2010    Post subject: Reply with quote
Wont he need a valve compressor to the the circlips off for that? Very Happy
A2 Passed 18/6/10
radical
PostPosted: 18:49 - 21 Jul 2010    Post subject: Reply with quote
No, they are split collet which can be removed by pressing a ring spanner on the spring cap but you need to tie up each valve incase they drop down, its a lot easier to do with the head removed but if you cant find a head gasket then it can be done this way.
smegballs
PostPosted: 18:56 - 21 Jul 2010    Post subject: Reply with quote
Don'y just look on their site, email them with what you want and they will get back to you with the part numbers. Then do a part number search and they will have what you want.
This is what I did for some CB500 parts recently. Oh yeah and have the VIN ready to email them as it speeds the process along a bit.
PostPosted: 19:54 - 21 Jul 2010    Post subject: Reply with quote
Do a compression check, both wet and dry to get some idea about the rings.
There are tricks to doing the valve stem oil seats without taking the head off. Bodge job is to feed rope through the plug hole into the cylinder, the turn the crank to wedge the valves closed with the string (make sure you do it in such a way that both valves are closed) and then you should be able to slightly compress the valve spring and remove the collets. A more professional method is to connect a supply of compressed air to the plug hole and use that pressure to hold the valves closed.
The Superdream engine does have a central cam chain.
PostPosted: 20:48 - 21 Jul 2010    Post subject: Reply with quote
Oh, almost forgot. Selenia do a (car) oil designed for older engines to cut down oil use. It is a 20W60 fully synthetic.
radical
PostPosted: 22:05 - 21 Jul 2010    Post subject: Reply with quote
good call with the rope, I use Elmlea cream from an areosol into the plug hole as its enough to keep the valves closed until you turn the engine over, its nice to know new tricks Thumbs Up
PostPosted: 22:20 - 21 Jul 2010    Post subject: Reply with quote
Laughing . Love it
rob_scott92
PostPosted: 13:05 - 22 Jul 2010    Post subject: Reply with quote
I actually do have a valve spring compressor and have actually used it before Laughing Although saying that, it wasn't on a bike, it was for a car engine that was stripped so.....
Come to think of it, i never did finish that little project Crying or Very sad
I'll leave it for now i think, at least until i have some experience with in depth stuff like that. If i didn't need the money i'd strip the Gs down but sadly it needs to go. Rolling Eyes
Now thats out the way, i'm still not overly sure on the whole balancer chain thing. From the thread i wrote a while back i think it was 'radical' who explained it partially, though unfortunately i still dont understand Laughing
On the gs theres the chain that goes from the crankshaft to the camshaft 'Cam chain'. I know this because i've seen it/replaced it. This is why i think i'm having trouble understanding the honda, because i cant see it, i cant understand it Laughing
Am i right in saying that there should be more than one balancer chain (think thats what radical said)?
Also, if balancer chain and cam chain are indeed not the same thing, then how comes there is no mention of cam chain in the manual for t'honda? Just balancer chain even though it is a chain that operates the valves? Thinking Sorry for the newbyish post but i must know hahaI
Thanks dudes Thumbs Up
Robby
Dirty Old Man
PostPosted: 16:02 - 22 Jul 2010    Post subject: Reply with quote
The camchain runs from the crankshaft to the camshaft. If you take off the rocker cover (top cover on the cylinder head) you'll be able to see it.
The balancer chain (if you have a balancer, you probably do) runs from the crankshaft to the balancer shaft(s). These bits are all in the bottom end.
The balancer chain is rarely replaced, it has less load to deal with and runs in a better oil supply. Cam chains do occasionally need replacing, but only after a very long time (100k miles plus on vaguely well maintained bike). I'm replacing one at the moment, but only because I doing a full engine strip and rebuild. The chain has done 30k (on the clocks, which may be lieing) and 30 years and still looks new. Tensioners tend to give up more regularly than cam chains.
If you do decide to strip the engine, there may be a way to get the cam chain out without splitting it. If the cam chain sprocket bolts onto the camshaft, they it can probably be unbolted and slid sideways to drop down half an inch or so. This, combined with removing the tensioner, may be enough to slide the camshaft out from under the chain.
PostPosted: 16:14 - 22 Jul 2010    Post subject: Reply with quote
Tensioners see to be currently regarded as the things to replace, but chains suffer too. One on my old Superdream lasted 60k which was good for one of those (but that might have been the 2nd chain). GPZ900R ones were meant to be good for about 20K. 1980s Honda cam chains were notorious for short lives.
There are other chains as well. Some bikes use chain primary drive and these can have no tensioner (as they need to take a load in both directions), and these can be short lives.
fiery tupp
PostPosted: 16:58 - 22 Jul 2010    Post subject: Reply with quote
You could try . https://granbymotors.co.uk/spares.php?lnk=Honda
Or...... https://www.fowlers.co.uk/parts/from_fowlers_web.html
They are pretty quick & not that expensive .
If you can't fix it with a hammer , use your head .
Frost
PostPosted: 18:13 - 22 Jul 2010    Post subject: Reply with quote
Thumbs Up Thumbs Up for Granby. I needed some gearbox gears for an import SRX 600, chances of me finding them were never going to be good... Granby had them in the post for the next day, seriously top blokes Thumbs Up
PostPosted: 18:19 - 22 Jul 2010    Post subject: Reply with quote
Another vote for Granbys. They were quick and helpful at sorting out a few spares for my import TZR250.
rob_scott92
PostPosted: 20:35 - 22 Jul 2010    Post subject: Reply with quote
Wow thanks for the detailed reply robby Very Happy Very helpful Thumbs Up here, have a cookie Karma
Thanks for the links also, i shall take a look at them as finding any parts for this bike could prove difficult.
Just one last thing though, Cam chains need adjusing every so often right? (Thats what kinda started all this off Rolling Eyes ) How do i adjust it??? Are there some that are self adjusting? as i said before, theres no mention of the cam chain at all in the manual. Can anyone shed light on this? I could scan part of the manual if that'd help.
Thanks again Thumbs Up
rob_scott92
PostPosted: 20:41 - 22 Jul 2010    Post subject: Reply with quote
Also,
Well there is quite a pronounced smell, what kind of smell should make me stop riding immediately to prevent damage? Shocked
Although i have been told today that i worry waaaaaay too much about my bikes and should just ride it and enjoy. I like this way of thinking Mr. Green
PostPosted: 21:11 - 22 Jul 2010    Post subject: Reply with quote
Think it is a semi automatic cam chain tensioner. From memory on the back of the cylinders. Think you just undo the tensioner a bit and then tighten it again. But this is from vague memory so please check.
Think they used to get lazy and the bodge then was to take off the cam cover and push down on the tensioner blade while doing the tensioner.
The last post was made 15 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.38 Sec - Server Load: 1.46 - MySQL Queries: 15 - Page Size: 139.47 Kb
