Lifan LF 125-j keeps cutting out
plymouthcg125
PostPosted: 07:39 - 22 Jul 2010    Post subject: Lifan LF 125-j keeps cutting out Reply with quote
Hi its that bloody lifan again, right the bike will not idol properly it will stay running for say 20 seconds an suddenly cut out it sometimes its a bugger to start on the electric start, i have done the spark plug and oil yesterday an i rode it out to the moors and i noticed a slight difference as it would ride a little better but if im at the lights i cant let the throttle go if i do it just dies after a few seconds of idling, i recently changed the throttle cable also it just seems so annoying.
another thought that crept up is that it has a metal ht cover on the spark plug "common on Chinese bikes apparently" i have been recommended to change that so im in the process of looking. would that have anything to do with it or am i on the wrong lines completely?
Yiben YB 125 Strider 2007 | Honda CG 125 2006 | Lifan LF-125J 2007
My new Forum ---> Join today all you Honda CG Enthusiasts --->> www.hondacg125.co.uk
PostPosted: 10:09 - 22 Jul 2010    Post subject: Reply with quote
check the tick over screw. i had the same prob on my lifan and fiddlin with the screw on the carb fixed it. it ran at a slightly higer revs on idle but not noticable
stonesie
PostPosted: 10:27 - 22 Jul 2010    Post subject: Reply with quote
Get some brake or carb cleaner and spray all around the inlet rubber pipes and gaskets with the engine running, IF there is a leak it will suck the cleaner into the engine and you will hear the engine note change as it burns Thumbs Up
plymouthcg125
PostPosted: 11:11 - 22 Jul 2010    Post subject: Reply with quote
thank you both i must say when i got it it did rev pretty high anyway so a mate of mine fiddled with the idel screw an lowerd it its only since that teh bikes been playing up
Martay
PostPosted: 12:17 - 22 Jul 2010    Post subject: Reply with quote
I had a hoation 125, and that was always a bugger on the leccy start. Would start first kick on kicker.
As has been said, check the inlet rubber for leaks. I had a poor idle, which was an air leak around this area.
I also changed the metal spark plug cap. Only about £3 for an NGK one. Mine would arc in the wet Sad
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
The last post was made 15 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 46.08 Kb
