Whether or not to go for full license
nathandenniso...
PostPosted: 20:29 - 22 Jul 2010    Post subject: Whether or not to go for full license Reply with quote
At the moment I have a full drivers license and have done my CBT and I was thinking would it be worth a shot at just going for my theory and then Mod 1 to get to grips with the first mod and If I pass, I pass but if not (most likely) I will be more aware of the test and not be going into the unknown when taking it again, have people tried this method or would you recommend a days training before going in for the 'mod's' thanks
Clanger
Stirrer
PostPosted: 20:35 - 22 Jul 2010    Post subject: Reply with quote
I can't see any reason NOT to go for a full licence, if you're old enough and can afford it, do it now!!!
nathandenniso...
PostPosted: 20:38 - 22 Jul 2010    Post subject: Reply with quote
I fit all the criteria, so going to get my theory booked for when I get back from my holiday
PostPosted: 21:29 - 22 Jul 2010    Post subject: Reply with quote
get your experience and go for a full test. check on youtube or the DSA site itself for vids of mod 1, it gives you some insight as to what you need to do to pass mod 1.
practice slow control. do u turns in side streets, if you can do a u turn in a side street with no probs then u will be able to do one on the test centre.
but i would recomend getting your test simply for the reason that a CBT lasts only 2 years. so every 2 years your gonna have to pay the guts of 90 quid if you want to stay on 2 wheels.
nathandenniso...
PostPosted: 21:34 - 22 Jul 2010    Post subject: Reply with quote
I thought they only last a year now?
Willson
PostPosted: 21:37 - 22 Jul 2010    Post subject: Reply with quote
If they've not changed them since I did mine in November, they still last two years Smile
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
nathandenniso...
PostPosted: 21:44 - 22 Jul 2010    Post subject: Reply with quote
Also could anybody answer I have seen a 'practice' of the module 1 on youtube and it seems to only take less than 5 minutes are you expected to know the order in which you do the manouvers and are you expected to do them one after another without stopping or receiving guidance from your examiner?
Kebabmonster
PostPosted: 22:09 - 22 Jul 2010    Post subject: Reply with quote
They tell you what's required often (e.g. do the slalom then 2 figure 8's then stop, or do a U turn then stop). They don't just show you the map of the course and say get going Smile
Andy.
C-Pk
PostPosted: 22:15 - 22 Jul 2010    Post subject: Reply with quote
Passed mine today mate.
It takes about 20 minutes and the examiner will tell you before each manouvre what is expected of you.
Work on your slalom and figure 8. The first is easy enough. The figure 8 can be difficult as your non use hand, ie. if your right handed, then your left. Can be difficult to do the U turn. So just be warned.
Get some good practice in. I never used an instructor. Just me and my dad. And some helpful videos online.
nathandenniso...
PostPosted: 22:37 - 22 Jul 2010    Post subject: Reply with quote
Cheers, great help I'm in the situation and doing the same, was it your first time? and good luck for mod 2
C-Pk
PostPosted: 23:00 - 22 Jul 2010    Post subject: Reply with quote
Yeah first time and Its not as scary as you might think. Just get lots of practise in. There is 22metres between the speedo and the swerve. Just close the throttle after passing the speedo and coast past the swerve. Its easy enough. The slalom and the figure of 8 are the difficult parts. And they are not too bad. just remember to always do your checks and always remember the final life saver.
PostPosted: 07:08 - 23 Jul 2010    Post subject: Reply with quote
with the figure of 8 you can make it easier for yoirself by going around the last slalom cone. There's nothing in the rules to say you can't. I'll try and explain.
say slalom are blue cones then 2 yellow cones for the figure of 8. Finish thw slalom and make your way around the 8, between the yellows then a u turn around the far cone. Make it easy by doing it wide. Cross between the yellows again and make the opposite u turn by goin round the blue cone.
its the way my training school showed me and i passed first time by using this method although it might be wise to check just in case your test centre is stricter
Kebabmonster
PostPosted: 10:44 - 23 Jul 2010    Post subject: Reply with quote
And remember you get another go at the swerve and the emergency stop if you do it correctly but weren't up to speed.
I had to do my swerve twice cos I only hit 46 kph 1st time, but I'd took it easy to get a feel for it on the day. Passed it on the second run and after trying it already, the second go was a piece of cake.
Andy.
nathandenniso...
PostPosted: 11:49 - 23 Jul 2010    Post subject: Reply with quote
You have all been great help! The only other worry I have is that I have a Yamaha SR 125, would it be suitable to do it on this bike as will I be able to get up to 32mph in time and also will I be able to do the emergency stop correctly with only one disk brake (front) thanks
PostPosted: 11:55 - 23 Jul 2010    Post subject: Reply with quote
bud. Its expected to be done at the same speed whether you are on a 50cc twist off piss off or on a 500cc bike. You'll have plenty of time to get up to speed and enough room to stop. Don't make it into a mountian with worry. Watch the vids on youtube and relax
yuri2085
PostPosted: 12:41 - 23 Jul 2010    Post subject: Reply with quote
Well, except it can't be done on a 50cc.
I believe the speed is possible for all weights on pretty much any 125CC machine but it is harder for heavier people as most people don't have the confidence to carry that much speed in the corner.
nathandenniso...
PostPosted: 13:00 - 23 Jul 2010    Post subject: Reply with quote
Considering I weigh 8 and a half stone, I'll just go careful the first time and try and reach the speed and then if I don't reach it and they give me another go I'll just go for it flat out
RussBLS
PostPosted: 16:19 - 23 Jul 2010    Post subject: Reply with quote
Do it on a 500. Then do your Mod 2 on a 500 and you can ride any bike you like providing you can get insured on it.
That's the way I did it.
Both tests weren't as difficult as I thought they were going to be. Just make sure you listen to the examiner at all times. You don't want to fail by preforming a manoeuvre you weren't asked to do. (Like the guy who's Mod 1 after me did)
Don't drop the bike either. Saw someone do that before they even got onto the tarmac.
nathandenniso...
PostPosted: 16:22 - 23 Jul 2010    Post subject: Reply with quote
My next bike after passing the test will be a 250 anyway so there is no point in doing it on a 500
nathandenniso...
PostPosted: 17:30 - 23 Jul 2010    Post subject: Reply with quote
i did it on a dual drum cg and got up to 51kph in second gear and rolled to a stop
So you're advice is to take it slowly and use as little gear changes as possible?
The last post was made 16 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 120.03 Kb
