| Pete. |
 Pete. Super Spammer
 Posted: 21:23 - 21 Jul 2010 Post subject: YZF125r Cylinder |
I just had cause to look at the cylinder of one of these. I was surprised to see that the piston runs directly on the plain alloy barrel casting - no coating, nothing. I've seen nitrided alloy barrels and that coating is harder than coffin nails - can't even touch it with a normal cylinder hone, have to use a diamond hone.
This has really surprised me, I wonder when they will start to suffer from worn-out barrels? Are any other bikes the same? ____________________ a.k.a 'Geri'
| Kickstart |
 Kickstart The Oracle
| Paulington |
 Paulington World Chat Champion
 Posted: 22:06 - 21 Jul 2010 Post subject: |
Fairly soon I'd wager.
Pretty incredulous considering they charge £4100 for the plastic fantastic monstrosities! . ____________________ "Four wheels move the body, two wheels move the soul."
CBT: 27/08/08. Theory: 04/09/09. Module 1: 16/09/09. Module 2: 01/10/09. |
| P.addy |
 P.addy Red Rocket
| Paulington |
| Pete. |
 Pete. Super Spammer
| Kickstart |
| Pete. |
 Pete. Super Spammer
 Posted: 19:11 - 22 Jul 2010 Post subject: |
Standard '09 engine never been opened before. A foreign object got sucked into the inlet and wedged under an inlet valve, which then suffered a piston-strike and got bent, so I stripped off the top-end. Inspecting the barrel I noticed a couple of very shallow dints in the wall so I put a 3-legged hone in it for about 5 seconds to knock-off any high spots. Marks are still there but very slight so I don't think they are going to be an issue. So long as it runs and doesn't smoke the guy's not going to care really. ____________________ a.k.a 'Geri'
| P.addy |
 P.addy Red Rocket
| Frost |
 Frost World Chat Champion
 Posted: 23:27 - 22 Jul 2010 Post subject: |
So is it actually a case of alloy barrel vs steel rings?
Maybe its some new alloy which is harder than normal? maybe there is some fancy oil system in there to keep the whole thing lubricated to hell? |
| TUG |
 TUG World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 20:02 - 23 Jul 2010 Post subject: |
Marketing blurb IMO. This barrel has NO plating on it.
As for 'forged' pistons, well I supposed that forged could mean counterfeit  ____________________ a.k.a 'Geri'
| Frost |
 Posted: 20:23 - 23 Jul 2010 Post subject: |
Yeah, maybe the barrel used to be plated?  |
| Pete. |
 Pete. Super Spammer
 Posted: 20:36 - 23 Jul 2010 Post subject: |
The bike has done well over 20k miles but this is the second engine. the original engine ate itself at 18k miles from having the skirt fail on the fancy forged piston
Nickel-plated barrels are harder than hell. You'll often still see the original honing marks on them after 20k miles of use. In comparison to a nikasil barrel, the walls of this one are soft as butter. ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
 Posted: 20:53 - 23 Jul 2010 Post subject: |
I did wonder if the piston was coated, but as Keith said the rings would still wear the barrel - I'll fetch some pics of the piston and barrel tomorrow. ____________________ a.k.a 'Geri'
| Carvel |
 Carvel World Chat Champion
| stonesie |
 stonesie World Chat Champion
 Posted: 21:13 - 23 Jul 2010 Post subject: |
Ah good old NikaSil, be sure to use good quality low sulphur petrol and avoid constant short trips, even BMW had big problems with it and moved on. |
| Pete. |
 Pete. Super Spammer
The last post was made 16 years, 115 days ago. Instead of replying here, would creating a new thread be more useful? |
