Questions regarding a CZ125
Hex
Party Boy
PostPosted: 13:16 - 19 Jul 2004    Post subject: Questions regarding a CZ125 Reply with quote
Got a friend with a few problems with an old CZ he's picked up.
This things a pre-mix bike and he's been told that it should be a 40:1 mix and it's using a NGK B8HS plug.
Now when running it occasionally stops, the plug though sparking is sparking across to the outside opposed to the electrode.
He's been told his mixture is a bit rich (I've not seen the bike/plug so can't really say, just after a few ideas of things he can look at).
Is the plug the correct one? Is it too hot/cold? Anyone know what it should use and also the gap for the plug?
Also would 50:1 of a modern pre-mix oil work ok on this bike?
Cheers peeps
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
PostPosted: 19:14 - 19 Jul 2004    Post subject: Reply with quote
I doubt it is that sensitive to the 2 stroke oil mixture level, but that sounds like a shot spark plug to be, possibly haveing been cleaned up too often with a wire brush (which you should not do as the brush leaves traces of metal on the porcelain and so causes it to short across that).
Hex
Party Boy
PostPosted: 20:13 - 19 Jul 2004    Post subject: Reply with quote
New plug, its been through a couple apparently.
Is it the right temp for the plug?
I was thinking its maybe just fowling them up due to oil mix been out, and maybe gap been wrong on it.
Wouldn't happen to know what standard setting for the carb is would you? Don't even know if its adjustable to be honest.
Skvara
PostPosted: 21:58 - 19 Jul 2004    Post subject: Reply with quote
Well if it is CZ there is no need to be precise with mix ratio!!! If you give too much oil, it will be just more smoky. You can give there the cheapest oil!!! Wink What CZ is it????
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
Hex
Party Boy
PostPosted: 23:49 - 19 Jul 2004    Post subject: Reply with quote
Skvara wrote:
What CZ is it????
All I've been told is its a CZ D/L 125?
Skvara
PostPosted: 21:50 - 20 Jul 2004    Post subject: Reply with quote
and year??? I've got CZ 175 (1969) and it is good moto, but my NSR 125 R(1999) is much better Smile JAWA and CZ aren't the same!!! It is quite the same, but JAWA is better in some ways!!!
Hex
Party Boy
PostPosted: 21:53 - 20 Jul 2004    Post subject: Reply with quote
1980 think I was told?
PostPosted: 23:13 - 20 Jul 2004    Post subject: Reply with quote
Given the comment above about one that was played with using a 6 plug, I would suspect a BR8HS might be a touch too cold.
Hex
Party Boy
PostPosted: 23:21 - 20 Jul 2004    Post subject: Reply with quote
Looking through that link above I came across a table and came to the same conclusion.
Will have to see if a change of plug helps.
Cheers peeps.
There is a gap of 1 year, 275 days between these two posts...
imust bemad
PostPosted: 19:21 - 22 Apr 2006    Post subject: Reply with quote
i have a cz125 that i am giving away the frame has been stripped down theres no tank or seat
The engine is in a box stripped down i was going to rebuild it but ran out of time..................oh yeah i have fitted new piston rings and top gasket Laughing
I live in brighton england if anyone wants it
P.S i also have a hayes manual for it as well
ive been to hell and back.....................................and i like it!!!!!
The last post was made 20 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 72.48 Kb
