The wonders of rusted rounded off screws
Willson
PostPosted: 08:46 - 24 Jul 2010    Post subject: The wonders of rusted rounded off screws Reply with quote
Hey dudes,
Just bought new throttle cables for my Kawasaki ER-5, and to my utter dismay one of the screws that holds the switchgear on is rusted and rounded off at the top.
Any ideas how I could set about removing it without damaging the handlebars or switchgear itself?
Thanks!
Willson
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
Carl_steveo
PostPosted: 09:22 - 24 Jul 2010    Post subject: Reply with quote
Have you got a dremmel???? If the answer is yes, cut a groove in the bolt and use a screwdriver to turn it out.
If the answer is no can you weld??? If the answer is yes, tac a upside down bolt on top of it and turn it off using a spanner.
If the answer is no then I have run out of suggestions lol. Thumbs Up
Current: Honda Nsr 125
Live: Sunderland
PostPosted: 09:29 - 24 Jul 2010    Post subject: Reply with quote
Great for melting the plastic switch gear.
If you can't cut a slot in it, you need to remove the screw head, then split the switch gear and use pliers to remove the stub.
neil.
PostPosted: 09:37 - 24 Jul 2010    Post subject: Reply with quote
https://www.fordprobestore.co.uk/store/images/plusgas1.jpg
+ a few hours +
https://g-ecx.images-amazon.com/images/G/02/ciu/a2/39/7672017b42a0f3ae035b1210.L._SL500_AA300_.jpg
Willson
PostPosted: 09:40 - 24 Jul 2010    Post subject: Reply with quote
Cheers for the suggestions guys,
Now off to my Dad's to try and find said tools!
I wouldn't mind, but I've got a spare lot of switchgear... but the same problem. One feckered screw.
It never rains it pours eh?
stonesie
PostPosted: 10:17 - 24 Jul 2010    Post subject: Reply with quote
You have a spare screw then?
Battery drill on slow
Sharp suitably sized drill bit
Patience and care
Combine that lot and you can drill the head off it without causing damage then tackle the remains with molegrips Thumbs Up
Just take it slow, you want to keep the temperature down to avoid melting the plastic.
Skinned
PostPosted: 14:28 - 24 Jul 2010    Post subject: Reply with quote
Depending on the extent of the rounding on the screw you can tap in a suitable size torx head bit into it and turn it out that way. I've done this on a few rounded screws and works well, wortha try before you start drilling away.
Carl_steveo
PostPosted: 16:37 - 24 Jul 2010    Post subject: Reply with quote
Only if your heavy handed and fucking blind. Laughing
Live: Sunderland
Skinned
PostPosted: 17:49 - 24 Jul 2010    Post subject: Reply with quote
Vincent wrote:
That technique only realy works for allen screws, not much use for philips screws.
As long as you got a good range of torx heads it can be used on quite a few different phiilips heads, usually on the brake reservoir when they seize. Just tap the a suitbale torx head in with a hammer and ratchet off.
It worked particularly well on the old Ford Capri I stripped as every single screw on it was rusted to hell, much like the rest of the car.
The last post was made 15 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 66.61 Kb
