Datatool S4-C4 alarm problem...
benandthe
PostPosted: 21:16 - 24 Jul 2010    Post subject: Datatool S4-C4 alarm problem... Reply with quote
I took my bike apart earlier today, including disconnecting my battery from the bike completely for about a hour.
After rebuilding the bike I now cannot turn the alarm off with either of my 2 key fobs!
The LED light is broken at the moment, the cable has snapped/ rusted and broken off the LED so I cannot tell anything by the light flashing.
The alarm has not sounded since rebuilding the bike, despite some gentle nudging but it sounds the alarm and flashes the indicators when I turn the ignition on.
It also sounds when I have removed the fuse but stops when I turn the ignition off.
Simply put the keys are not working to turn the alarm off!
(can the keys "unassign" themselves)
Any Ideas anyone?
Thanks!!
gixxersixx
PostPosted: 09:26 - 25 Jul 2010    Post subject: Reply with quote
Unlikely the fobs would have unassigned themselves.
When you turn the ignition on have you tried pressing the, i think its the grey button. Also when you "dismantled" the bike did you place the alarm in winter or sleep mode? Was the alarm programmed with a pin number?
We're all just born to die. So lets have some fun
gsxr6k1,pc,k&n,skimmed block,flowed head,yoshi gasket,cams,blue print,arrow system titanium can,quick shifter,gilles rear sets,ktech forks,ohlins shock,galfer waveys, -3front+4rear + other goodies
benandthe
PostPosted: 10:04 - 25 Jul 2010    Post subject: Reply with quote
I didnt think they would...
I will go try pressing the button in a second, see what that does...
And this is my first alarm, came with the bike, but I didn't realise that it was ment to be in winter or service mode before disconnecting, although it was in service mode (luckily). but it's still not working...
benandthe
PostPosted: 10:10 - 25 Jul 2010    Post subject: Reply with quote
if anyone know how to disable the alarm, please call me on 07575 948672. thanks!!
Paxovasa
PostPosted: 10:19 - 25 Jul 2010    Post subject: Reply with quote
Have a read of this as it may help explain what the problem is and how to fix it Thumbs Up
https://www.datatool.co.uk/pdfs/s4_ug.pdf
benandthe
PostPosted: 10:46 - 25 Jul 2010    Post subject: Reply with quote
already read it and reread it about 5 times, no help at all. Sad
very frustrating... the alarm wont go into service/ferry mode now, it will only arm itself by the key fob and not dis-arm....
Paxovasa
PostPosted: 10:49 - 25 Jul 2010    Post subject: Reply with quote
Possibly due to the led cable been broke it thinks someone is tampering with it and wont disarm.
Can you repair the cable so the led is working?
Sounds like the immobiliser is armed and not the alarm, if you can nudge the bike and it does not beep a warning.
What happens when you press both buttons at the same time?
benandthe
PostPosted: 10:55 - 25 Jul 2010    Post subject: Reply with quote
The LED cable has been broken for a while, I could try and fix it but dont have a spare LED as its snapped off right by the LED. (not had any issues with it not working though)
and the alarm fully activates but does not deactivate unless I turn the key/ nudge the bike and the alarm will sound and then the key dis-arms it....
and pressing both buttons at the same time does nothing... Sad
Paxovasa
PostPosted: 10:57 - 25 Jul 2010    Post subject: Reply with quote
Check the fuse in the alarm. My datatool 3 alarm blew its fuse and I could not deactivate it.
benandthe
PostPosted: 11:57 - 25 Jul 2010    Post subject: Reply with quote
I had already checked that.
I had a problem last week where one of my fuses blew because of the indicator bulb blowing, I replaced the indicators anyway instead of the bulb and sorted that problem.
It also took out the fuse in the alarm for some reason...
The alarm is now FIXED!!!
All down to one single wire that had split near the alarm itself...!!
Oh well, all done now, thanks for your help. Smile
The last post was made 15 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.9 - MySQL Queries: 13 - Page Size: 64.3 Kb
