DT 125 1983 lc liquid cool engine problems
oldmanstoner
PostPosted: 08:38 - 25 Jul 2010    Post subject: DT 125 1983 lc liquid cool engine problems Reply with quote
HI my dt was going fine until one day i rode it and when i was riding it started missing when i had the throttle fully open
then i noticed that there was oil coming out from the spark plug
My origonal thought was that the rings were shot but when i took off the head i saw they were fine but the head gasket was in three peices that means it had blown I also noticed that their was water in the crank is that from the head gasket been broken or is the water pump seal also poked i dont know too much about two stroke motors how does one do the timming on the motor when put back together as there is no timming chain or belt must the piston be TDC and thats all Shocked
JJJ
27cows
PostPosted: 09:19 - 25 Jul 2010    Post subject: Reply with quote
There's no timing to worry about - CDI. Just sounds like a case of a blown gasket. Clean everything up, replace the top end gaskets (and plug, to be on the safe side), and it should be fine, fingers crossed.
oldmanstoner
PostPosted: 11:00 - 25 Jul 2010    Post subject: Reply with quote
thanks very much I think all will go well checked water pump seal all good so it must be the head gasket well at least it gave me a chance to strip the bike and i have started redoing the whole bike
right down to polishing all the nuts and bolts and respraying the frame
JJJ
oldmanstoner
PostPosted: 16:19 - 25 Jul 2010    Post subject: Reply with quote
Thanks very much will buy from yamaha they quite cheap
JJJ
The last post was made 15 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 43.63 Kb
