ccm 404ds - (suzuki drz400 engine) starting problems
Hunnibeast
PostPosted: 16:18 - 25 Jul 2010    Post subject: ccm 404ds - (suzuki drz400 engine) starting problems Reply with quote
Hey,
I believe the engine is a DRZ400E engine used in the CCM 404DS bike. I had some issues with exhaust valve clearances closing up. I've put in the new shims and put it all back together using the official Suzuki DRZ400 workshop manual.
However now it won't start on the leccy start, it will bump start and run absolutely fine but it dies when it gets down to idle speed and like I said it just won't start on the starter. Inlet valves were on the verge of being too tight but still within limits.
any ideas? idle jet?
any help is much appreciated,
cheers guys
Jesse
Suzuki TS50X, Yamaha DT125R, CCM 404DS
unspec
PostPosted: 16:22 - 25 Jul 2010    Post subject: Reply with quote
You don't say how it behaves when you are trying the electric starter.
Is the battery good? If not I'd look at the charging system.
Hunnibeast
PostPosted: 16:31 - 25 Jul 2010    Post subject: Reply with quote
well I've tried jump starting it from a car which I've done in the past and has worked.
It just turns over with little or no life at all.
cheers
unspec
PostPosted: 17:48 - 25 Jul 2010    Post subject: Reply with quote
cheers
So the battery was dead. I'd check the generator, regulator/rectifier and the battery itself.
The last post was made 15 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 39.32 Kb
