R & G Crash Bungs... Are they worth it?
0l0dom0l0
PostPosted: 18:27 - 25 Jul 2010    Post subject: R & G Crash Bungs... Are they worth it? Reply with quote
So after dropping my '98 yamaha fazer, and getting lucky and not causing to much damage i have been considering getting some crash bungs for it. now my friend has a daytona 600, and they are fitted with all sorts of reinforcements, and the bike has been down on them with only a few scratches on the bungs to show. no other damage.
Now my concern is, during an off, people have reported the damage to have been worse where the bungs have bent the fram etc. now on the fazer, they are mounted directly to the frame, with no reinforcement bars in place to dissipate the force, and im worried they are going to damage the frame was anything to happen.
what are peoples feelings? am i just being paranoid?
thanks
SamJL
PostPosted: 18:34 - 25 Jul 2010    Post subject: Reply with quote
I use them, but mine have a bolt wich is intended to bend before the frame does.
Some people say they can do more damage then good, and they can also hit things in the road when you drop the bike, causing it to flip and cause more damage then without the bungs. I use them, mine are quite small, and I don't intend on dropping the bike. To be honest, there more for low speed drops, or dropping the bike on your drive when turning it around, rarther then higher speed crashes!
2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX Very Happy
You'll get mixed reactions but the consensus will say fit them.
If you go down the road hard enough to fuck the frame, the chances are you would have done it with or without bungs.
Triumph Trophy Launch Edition
Spit-Fire
PostPosted: 19:24 - 25 Jul 2010    Post subject: Reply with quote
+1
opinion's are mix so its personal choice.
i can kind of see what people mean about an accident that has enough momentum for the bungs to catch and send the bike cartwheeling,
would likely leave the bike pretty beat up regardless of if they were fitted or not
they say the good die young... i say we just live faster
kawakid
PostPosted: 19:25 - 25 Jul 2010    Post subject: Reply with quote
Engine bars are better, but only suite naked bikes.
I have R&Gs on my Z and somewhat protected it when I dropped it. (The engine casing still broke, but no damage to the upper fairing or anything else). Engine casing cost £20 to fix.
I had R&Gs on my ER5 also and I crashed at about 30, the only damage was a mirror and a bent brake leaver.
I've a twin and a 4.
Ben.
PostPosted: 19:29 - 25 Jul 2010    Post subject: Reply with quote
R&G are better than any other make. The bolts bend and snap before it will do any damage to the frame. They save a lot of damage.
They are great but they will not save the bike if you have a spill at 140mph... People think they are miracle workers, they're not.
Seen loads of crashes on track where they save a lot of damage. On the road they can dig in and flip the bike etc.
So its your call. I would defintley have them.
I've crashed with them (30mph, 60mph and 100mph) and only had scrapes and cosmetic damage (maybe a snapped brake lever or foot peg). The one time i crashed without them at a considerably slower speed (25mph) it broke the crankcase and I had to take the engine apart.
Definitely a fan here.
follow my racing season
Race bike - R6
Road bike - sv650
woll
PostPosted: 19:42 - 25 Jul 2010    Post subject: Reply with quote
Out of interest do you have some? if you do is it possible to see the numbers on top of the bolt head?
jay12329
Dr. Evil
PostPosted: 19:56 - 25 Jul 2010    Post subject: Reply with quote
As I've said before all my bikes will have some sort of protection, normally R&G's
I had them on my Hornet, dropped it at high speed mid corner at copse silverstone. 80+mph like slid to the gravel at the far side of the huge tarmac run off.
Only damage was pair of bent brake leavers. Engine didn't touch down. Bike would have been well and truly written off without R&G's. And the replacement parts from R&G was <50% of the cost of a new whole set.
With the added bonus I could hang my legs over them on long m-way stints to stretch my legs.
HTH
J
PostPosted: 20:01 - 25 Jul 2010    Post subject: Reply with quote
I see a lot of people that use R&Gs that go on about how amazing they are, even when they have a bad experience.
Great marketing has gone on somewhere it seems.
Some R&G are good and some are bad. I suggest you look for pictures of the bike after it has crashed with them. For me I do not entirely trust owners opinions of them from what I've seen.
Except, in enough cases people's frames and other parts of the bike (like water pumps) have been damaged BY the bent crash bungs where they wouldn't have been without.
They often also bend before they are any use.
In other cases, the flexible nature of the bolt will put considerably more stress on the threads, stripping the engine mounting bolt leading to a very costly repair.
Some R&G designs are good, other are likely to cost you money. They certainly don't seem to be any use in high speed stuff.
I've had my engine mounts stripped and seen others where they have caused damage.
Given the choice, I'd find some really solid ones. There are some possibilities for more damage (maybe more so on the road than track), but the ones I had on my race SV I was really impressed by - maybe a total of 20 crashes in the time I knew the bike (luke had it after me) and still doing the job.
0l0dom0l0
PostPosted: 21:23 - 25 Jul 2010    Post subject: Reply with quote
thanks for all the replies.
i guess as pointed out, if the crash was bad enough to brake the bungs off etc, then it would of done a lot more damage without.
i think for £60 they are worth a shot. seeing as im going to have a pretty heavy load alot of the time too, with a heavy bike, me, my girlfriend and a top box, the chances of another drop are fairly high to be honest.
i guess R & G would have tested them and made them to reduce the amount of damage as much as possible. the cheaper alternatives dont offer the same protection.
any more opinions are welcome Smile
PostPosted: 21:55 - 25 Jul 2010    Post subject: Reply with quote
Not with R&Gs - they can often break off way before, leaving you with at best a bung to replace and an extra dent in the fairing and worse, a damaged engine mount that if you got a garage to replace could easily be into four figures!
I doubt they do test them that much personally.
grandmasterbo...
PostPosted: 01:16 - 26 Jul 2010    Post subject: Reply with quote
i have then on the cbr 125 onley got them as it was a chrimbo prezzy there ok i kinda use then as leg rests on long rydes when legs get sore if onley they were loner theyd be more comfortable ha cost £70 then £20 for honda to dril the faireings and fit them as a bouns they polished the bike alro hah
suzuki CS50 roadie (exploded) Gilerea Runner VX 125 (sold)
CBR125 rw6 (crapped itself and died) YBR 125 2004 (its okay)
supZ
PostPosted: 11:43 - 26 Jul 2010    Post subject: Reply with quote
i've had em on all my bikes and wouldnt be without em.
i have dropped the blade (accidently stalled it pulling left off my drive and ended up in a very bad position so couldnt hold the bike up so had to lower it and roll off) and all i have to show for it is a little scuff on the crash protector. no scratches on fairing, mirrors, engine casing anything Smile
about a year and a half ago i came off the track at a high speed at cadwell (80mph+ lowside) on my road bike at the time (CBR600F) and although i will admit the crash bungs 'caused' more damage as they dug into the curbing and flipped it up in the air, they did their job of protecting the bike! one side of the fairing was actually ok apart from some scratches but the main thing is the bolts took the energy out of the impact, bend in and saved the frame and engine!
that bike has now been rebuilt and is my current trackbike!
for the sake of £60 they saved me having to buy a whole new bike as the engine would have surely split and spewed oil everywhere had those protectors not been there, and on the blade they've saved me a big fairing bill because of a silly drop.
worth every penny imo
CBR954RR - Daily toy
CBR600RR - Trackbike
angryjonny
PostPosted: 11:50 - 26 Jul 2010    Post subject: Reply with quote
Pretty much agree with the consensus here.
My R&Gs were an immediate add-on to my FZ1 because at some point I will be stupid enough to try and ride it away with the disk lock on and drop it. I would quite like to get away with that if I can.
There's not going to be any real statistics on whether they do any good in a big crash. For every person who claims they saved their bike there will be someone else who claims they bent the frame. It's all opinion. My plan to avoid major damage to my bike in a big crash is to try not to have a big crash.
PostPosted: 11:53 - 26 Jul 2010    Post subject: Reply with quote
Are you sure the bike would have been written off?
Even in my bike racing crash (bike flung in to the air pretty high, spinning fast), the frame and engine were ok.
Split crankcase may well be cheaper to replace than a crash mushroom in some cases - and often are still damaged anyway if it does hit other bumpy bits.
PostPosted: 12:00 - 26 Jul 2010    Post subject: Reply with quote
Massive fan here, crashed loads and they have always saved the bike, they are a bargain at twice the price IMO. I have had at least 6 crashes with RG's and half the time the paint work has been untouched and every other thin it has been slightly scuffed or minorly cracked.
Flip
PostPosted: 12:01 - 26 Jul 2010    Post subject: Reply with quote
These can also bend the frame. A worry I have is they can act like a ski for the bike and the bike will slide away.
Spit-Fire
PostPosted: 12:21 - 26 Jul 2010    Post subject: Reply with quote
sorry but... how do you know this?
(unless a bike mag has tried that i dont know about?)
surely the only way to know which crash protection works better then the others, is to go and roll your bike down the road several times with several manufactures produces and put together some form of fact based statistic.
or its just speculation/guessing/assumption?,
which like G said is likely to be a product of good marketing.
id like to believe they do help (not being brand specific)
but has any one discussed the other options as well as the bungs? eg;
exhaust protectors
engine case protectors,
bar ends
shark fins
fork protectors,
cotton reels etc etc
maybe a combination of products works better,
or you (r&g would love this) need the whole shah bang
to have full protection?
PostPosted: 13:00 - 26 Jul 2010    Post subject: Reply with quote
Yea for being able to ride home, I think decent engine case protectors or armoured engine cases are well worth it - and personally I'd go for these before crash mushrooms I reckon.
supZ
PostPosted: 13:06 - 26 Jul 2010    Post subject: Reply with quote
oh im sure it would have been written off Smile
it managed to do a flip in the air and landed upsidedown
virtually every panel smashed or scratched, screen, clocks, front bracket all smashed in, rear subframe bent, hole worn in can, clipon broken, left controls smashed..
considering i only bought it for £1200 im sure that would have been a write off in insurance terms.
on the plus side tho, engine, downpipes, frame, forks, wheels and brakes were all fine. the good old girl even started first turn of the key once i got her recovered back home. Very Happy
i cant see alternate realities so i cant comment on what would have happened without em, would the bike have flipped without em? would the engine casing have smashed without em? would the frame have survived without em?
i just dont know
PostPosted: 13:27 - 26 Jul 2010    Post subject: Reply with quote
exhaust protectors
bar ends
shark fins
fork protectors,
I have R&G sliders exhaust protector and now Front Bobbins, it cost me £70 for the lot (should be about £100 RRP)
My last slide done the road cost me £100 to fix and that was the bike back to 99% what it was before (gear lever has a scuff) and most of that was oil from when it went through the engine casing. My freshly painted body work was untouched.
My bike is a minter, how many mint bikes can you slide down the road and get it looking good as new for under £100?
The cheap makes don't the have bendy bolts the R&G's do, which can lead to more damage.
PostPosted: 13:37 - 26 Jul 2010    Post subject: Reply with quote
Sorry, more are you sure the mushrooms actually did anything useful at all? I thought you were suggesting they had saved some bits.
While I don't dispute it can happen I have NEVER seen damage from stiffer bolts. I have OFTEN seen damage from bendy bolts.
The R&G designs that seem to work the best are the ones that don't bend much in my experience.
Personally I would avoid an R&G model that is known to bend.
Spit-Fire
PostPosted: 14:37 - 26 Jul 2010    Post subject: Reply with quote
wouldn't the bending bolts only help in some crashes? not all?
and are you sure not one other manufacture that makes them, including the factory accessory, has clocked on to
"hey erm..., stiff bolts might actually cause more damage"
seems like that is a very easy design correction
Bendy
Mrs Sensible
PostPosted: 14:51 - 26 Jul 2010    Post subject: Reply with quote
I've had/have them on most of my bikes in the last 5 years.
I like them because I know they're gonna help with low speed / stationary drops. I consider a 0mph cack-handed drop the most likely scenario for me, so something that gives the plastics and mirror a chance of staying off the deck is a good thing.
Higher speed stuff, I'm not assuming they'll help. I'm not even assuming they won't make things worse. I've seen cases that appear to have gone each way, though without re-running the accident you can never know exactly what would have happened with/without. But if they're fitted for lowspeed, they're fitted for highspeed so... see what happens. Out of 2 CBR crashes, they helped on 1 and didn't make a blind bit of difference on the other (which admittedly was mostly through gravel and mud).
What I do like a lot are armoured engine covers, as I'm considerably more concerned with making a hole in the engine that I am with scratching up or trashing fairings. These covers - https://www.gbracing.eu/ - are the dog's danglies.
The last post was made 16 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 137.87 Kb
