Bike only runs right without air filter
cbpaul
PostPosted: 21:05 - 25 Jul 2010    Post subject: Bike only runs right without air filter Reply with quote
As title my CB250N superdream wont rev over 5500rpm unless I take out the air filter and it runs spot on . I washed out the air filter to remove the oil and have to open the air screws 4.5 turns to run ok but not 100% book said 1.5 turns. I have stripped the carbs many times and cant find a problem and I know running without air filter will run lean any ideas Confused
yuri2085
PostPosted: 21:23 - 25 Jul 2010    Post subject: Reply with quote
Perhaps the fuel mix is rich?
-which is what rob was getting at.
cbpaul
PostPosted: 22:53 - 25 Jul 2010    Post subject: Reply with quote
Thks guys as for the needle there is no adjustment i.e extra groves in needle. and yes the mixture is very rich with filter giving shooty plugs . I have unscrewed mixture screws nearly to the point of falling out so I think it can get any air when running on main needle.
yuri2085
PostPosted: 22:57 - 25 Jul 2010    Post subject: Reply with quote
If you still have a problem you may find you get more knowledgeable help in the workshop section.
Frost
PostPosted: 23:05 - 25 Jul 2010    Post subject: Reply with quote
Don't open the air screws 4.5 turns, your just hiding the problem. Open them up 1.5 like the manual says, then start looking for the actual problem. Provided that the air filter isn't clogged, put it back in.
Check the needle heights are as they should be. Take the carbs off and scrub them clean (the insides that is) Poke the jets through with a bit of wire or a needle. Check the diaphragms for splits and holes, like wise the airbox and inlet rubbers. Grease up the seals and reassemble it. If that fails to fix it, then it's time to look at more complex and expensive causes.
iooi
PostPosted: 07:42 - 26 Jul 2010    Post subject: Re: Bike only runs right without air filter Reply with quote
Isn't the filter supposed to be oiled........
cbpaul
PostPosted: 13:13 - 26 Jul 2010    Post subject: Reply with quote
New air filter and yes it should be in gear oil I will try a second set of main needles and reset air screws and see what happens . I might have to get a used pair of carbs to see if that does the problem.
Bru
PostPosted: 13:28 - 26 Jul 2010    Post subject: Reply with quote
Running rich.. sounds like your bypass valves are leaking. On the lhs of each carb body is a small cover, hiding a rubber diaphragm and spring (which can fly out). I'm sure you've seen it, having stripped the carbs already.
Have you inspected the diaphragms closely? Any creases could hide holes; any holes will cause the valve to fail, and allow excess fuel downstream of the jets, so causing over-rich running. I believe you can buy replacement bypass valve kits for around £10 on Wemoto or similar.
Your 'air' screw is actually a mixture screw, which really does meter a mixture of fuel and air from two separate channels. So, opening the screw allows more air and fuel into the engine.
fiery tupp
PostPosted: 18:28 - 26 Jul 2010    Post subject: Reply with quote
If you are going to poke the jets you need to use copper wire ordinary wire or needles can cause damage .
If you can't fix it with a hammer , use your head .
Pretendra
PostPosted: 10:32 - 02 Sep 2010    Post subject: Reply with quote
Has the problem been solved, if not try checking the float height. which should solve this problem.
Pretendra
cbpaul
PostPosted: 19:37 - 02 Sep 2010    Post subject: Reply with quote
No luck yet I set the floats at 15.5 mm is that right about to give up bikes all ready to go such a pain .
Mad
Pretendra
PostPosted: 07:46 - 03 Sep 2010    Post subject: Reply with quote
I had the same problem on my bike, initially i went by the book 'Haynes' and had set it to 15.5mm as u mentioned. but the problem persisted, after trying all the stunts possible to lean the mixture i started increasing the float height and now it runs good at a float height of 20 - 21mm. this is provided you have checked your ignition system and is working fine.
i wonder why this happened and for sure people at haynes are not bums to put those figures in, guess could be because of incorrect float needle dimensions..... i may be wrong. but hey my bike is running much better than before. earlier my plugs used to foul and short because of rich mixture and did not rev, but had a good lower end.
Now this i what i experienced, you could try increasing the height in increments and see what happens whats there to loose. though over leaning should be avoided.
Bru
PostPosted: 07:51 - 03 Sep 2010    Post subject: Reply with quote
Have you taken each bypass diaphragm out and checked them? A crack in the diaphragm will run your engine extremely rich, and no amount of fiddling with the carb needles and jets will remedy that.
Float height will account for some, but not much of your described symptoms.
cbpaul
PostPosted: 20:16 - 03 Sep 2010    Post subject: Reply with quote
Thks pretendra I will try the float trick this weekend as for a bypass diaphram thay are only fitted to the cb400n. I have 4 sets of carbs and no luck but i will keep trying. swapped cdi stater and coil but no change. what bike do you have Pretendra? Smile
Pretendra
PostPosted: 08:23 - 04 Sep 2010    Post subject: Reply with quote
i agree bypass diaphrams are on the 400's. I have a CB250N superdream. which was in a crappy state when i bought it, after 6mth's of restoration, engine rebuild and paint work it was road running.
I too had electrical problems, my magneto stator coil was not producing enough primary current for the CDI. i got a good salvaged stator coil from ebay and replaced the HT coil with a new one.
Bru
PostPosted: 11:03 - 04 Sep 2010    Post subject: Reply with quote
Interesting. Sorry if my advice was based on incorrect information; I found a parts drawing on cmsnl.com, for a 250N which shows bypass valves on the carbs.
cbpaul
PostPosted: 23:09 - 04 Sep 2010    Post subject: Reply with quote
Thats alright Bru no problem I need all the help I can get thks again. Good to see you have got your bike sorted Pretendra have you got any photos as I am a bit of a superdream nut Laughing . I have 1 250NA and 1 400NB AND 2 400NCS must be mad. Going to work on bike sunday and play with the carb floats again wish me luck. Smile
Pretendra
PostPosted: 07:56 - 05 Sep 2010    Post subject: Reply with quote
Bru theres nothing to be sorry about, that pic on cmsnl.com is misleading. It had kept me wondering for quiet some time wether my bike has one or not when i had initilly seen the exploded view.
then i read some where that it had come only on 400s to prevent misfire during diceleration.
garyd
PostPosted: 08:30 - 05 Sep 2010    Post subject: Reply with quote
Could the "air screw "actually be a fuel screw???
CRF230 all you need
Pretendra
PostPosted: 16:12 - 05 Sep 2010    Post subject: Reply with quote
I think to a certain extent garyd is right. I guess logicaly since the screw is located at the end of pilot circuit it restricts the flow of premixed airfuel which happens at the pilot jet immulsion tube, if the screw was at the opposite end it would have controlled the amount of air that went to the pilot circuit.
According to Haynes manual for a CB250 it should be set to 2 turns.
But again the pilot circuit operates only untill the throttle is shut, as soon as the throttle butterfly opens the main jet comes in to effect.
cbpaul
PostPosted: 17:30 - 05 Sep 2010    Post subject: Reply with quote
Bike looks very tidy Petendra I like the front mudguard what have you used. Didn't get time to work on bike today but I will let you know what happens you say you changed stater do you test with a volt meter when running. Just got to up load photos so I will have them on 2nite thks paul.
cbpaul
PostPosted: 17:33 - 05 Sep 2010    Post subject: Reply with quote
Forgot to say jet size 105 main 72 secondry as haynes book dose'nt say is this right.
The last post was made 16 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 123.32 Kb
