| reggie |
 reggie Spanner Monkey
| chris-red |
| Blau Zedong |
 Blau Zedong Banned
| Gazdaman |
 Gazdaman I did a trackday!!!
| iooi |
 iooi Super Spammer
 Posted: 10:27 - 27 Jul 2010 Post subject: |
Hands up for rings bust in seconds......
You do realise that sometimes small is better, as it increases the speed of induction,which leads to better air/fual mix and more bang per buck. Make it bigger and while in can increase the capasity for more air flow. It does not mean it will, it won't be mixed enough, or will actually decrease power.
If it was so easy, do you not think that there would be no need for larger cc kits for bikes
Still nice try  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| chris-red |
 Posted: 11:28 - 27 Jul 2010 Post subject: |
This is on a level with the guy who used water the flush out the engine of his mustang, or the guy who ran sand through his intake to port his car.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| DrDonnyBrago |
| gearboxkart |
 gearboxkart Borekit Bruiser
| G |
 G The Voice of Reason
| smegballs |
 smegballs World Chat Champion
 Posted: 12:32 - 27 Jul 2010 Post subject: |
Yamaha is da 2 stroke powaaah masters innit tho...
I take it you didn't do any sorts of calculations at all, just went nuts
From what I've read, even if you slightly enlarge the inlet and exhaust ports, only real masters even think about touching the transfers..
If you felt that passionate about it, why not just start by cleaning up the castings, trimming gaskets to fit perfectly etc etc before going all Two Stroke Dremel Massacre on its ass..... |
| 27cows |
 27cows World Chat Champion
 Posted: 12:41 - 27 Jul 2010 Post subject: |
I've seen mods like this actually work. You'd be surprised how useless the R&D of most Jap manufacturers is...which is how the vast Honda corporation came to launch a major new bike which destroyed its motor because of a glaringly obvious yet simple to rectify fault (VF750).
Main problem you have is that the port isn't cast. Drilling a new hole rather than working with what's already there will probably cause complications. I'd be surprised if one of the rings didn't catch, but then who knows.
At least this guy is showing some spirit of adventure, instead of just getting some tedious plastic clone bike. People used to do mad shit like this quite often in the 80s. Now and then people come up with something sensational (I can remember the idea of putting a Powervalve 350 motor into an RG250 chassis being dismissed as idiotic...until someone tried it and it actually produced a bloody good bike ).
Having said that, I do think the motor will probably destroy itself after half a mile. Either that or produce about 40 horsepower and go like the clappers  ____________________ The RXS100: vehicle of choice for Chuck Norris |
| radical |
 radical Spanner Monkey
| Blau Zedong |
 Blau Zedong Banned
| reggie |
 Posted: 13:15 - 27 Jul 2010 Post subject: |
i have about 5 spair dt barrels i can aford to fuck one up!
the barrel on my bike i have cleaned up the transfers matched ports to the crank case, matched the exhaust to the it made a little improvement
i have not rased the exhaust pot at all
here are some pictures of somone elses atempt but with much better tooling
https://img219.imageshack.us/img219/239/walzedll00bsu2.jpg
this is were ive got the idear from
https://img194.imageshack.us/img194/9419/spzylauslass.jpg
tzr sp barrel
some of you sat the rings wont last/snag if thay can manage to not geting snaged im sure ther can cope not geting stuck in the side ports ____________________ when the shit hits the fan make sure its facing the other way. |
| DrDonnyBrago |
 Posted: 13:32 - 27 Jul 2010 Post subject: |
Post a video when you are done, we will all be interested in seeing it regardless of how well it worked. . |
| gearboxkart |
 Posted: 13:36 - 27 Jul 2010 Post subject: |
if you want more top end zing and narrow the power band you need to raise the exhaust port, easiest way on my rd's was to put 2 bottom barrel gaskets on and either skim the head to get the lost compression/volume back or just dont fit a head gasket ! that works on some but not all engines especially water cooled motors, i had my rd500 done by stan stephens donkeys years ago and the difference in power was amazing but looking at what he did you couldnt actually see any difference apart from all the transfer ports were polishes to a nearly mirror smooth finish, 2 strokes tuning is an art but when done properly on a decent motor is wicked, if you want decent power go look around for a 125 moto-x engine ! pretty easy to fit with a few engine mount mods and you will have a screaming demon  |
| reggie |
| gearboxkart |
| reggie |
| chris-red |
| 27cows |
 Posted: 18:54 - 27 Jul 2010 Post subject: |
| Blue_SV650S |
 Posted: 21:20 - 27 Jul 2010 Post subject: |
This is cool ...
Have you checked that the ring end pins (and chance the end gap) aren't now running over a port*???? if they are, then don't even bother running it!!
If not, then go ahead!!
You might also want to consider some transfer windows in the piston or cutting a bit of skirt off to increase inlet duration ..
You also need a free flowing 'zorst ... and some bigger jets no doubt!
*probably on the back side to be honest - not where you have been playing - but worth a check!  ____________________ The purpose of life is to fight maturity. |
| reggie |
The last post was made 16 years, 50 days ago. Instead of replying here, would creating a new thread be more useful? |
