CSS + Firefox issue..
Sparks!
Sir Tart-a-lot
PostPosted: 10:35 - 30 Jul 2010    Post subject: CSS + Firefox issue.. Reply with quote
Does CSS not display correctly in firefox or am I doing something wrong?
I've made a website which has CSS table border properties, this displays fine in my HTML code editor (not a drag and drop one) and displays fine in internet explorer but when I open in firefox the border does not display as colour, its invisible! Other than that all nothing changes, just the border colour dissapears.
Any ideas??
Phil.
PostPosted: 10:45 - 30 Jul 2010    Post subject: Reply with quote
Can you post the code that you are having trouble with?
PostPosted: 10:46 - 30 Jul 2010    Post subject: Reply with quote
I would suspect FF is correct and IE is managing to bodge things.
Download firebug and check the style of the element to see if something has over ridden it.
Also try a few other browsers (Opera, Safari and Chrome).
Sparks!
Sir Tart-a-lot
PostPosted: 11:08 - 30 Jul 2010    Post subject: Reply with quote
Attached a test file which has the exact problem, shows fine in IE but the table border dissapears in firefox...
p.s as you can tell, I've only just started using CSS and I still suck Laughing
PostPosted: 11:27 - 30 Jul 2010    Post subject: Reply with quote
I have tried to download that and found it empty.
Can you just post the code (use [ c o d e ] tags)
Sparks!
Sir Tart-a-lot
PostPosted: 13:00 - 30 Jul 2010    Post subject: Reply with quote
CSS File
Code:
p
font-family:"tahoma";
font-size:0.9em;
text-decoration:bold;
color:white;
padding:0px 40px;
text-align:justify;
p.second
font-size:0.9em;
color:#000000;
padding:0px 40px;
text-align:justify;
table.first
border-color:#dc9541;
border-style: solid;
A:link   {font-family: arial; text-decoration: none; color:  red }
A:visited   {font-family: arial; text-decoration: none; color:  red }
A:active   {font-family: arial; text-decoration: none; color: red }
A:hover   {font-family: arial; text-decoration: underline; color: red }
A test html file
Code:
<html>
<head>
<title>supercooks</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
    <link href="style.css" type="text/css" rel="stylesheet"/>
</head>
<body bgcolor="#5a0000" leftmargin="0" topmargin="0" marginwidth="0" marginheight="0">
<table class="first" width="500" height="500" border="0" cellpadding="0" cellspacing="0">
   <tr>
      <td colspan="5">
         testtesttesttest
   </td>
</tr>
</table>
</body>
</html>
Shows a thick orange border in IE but not in firefox...
PostPosted: 13:21 - 30 Jul 2010    Post subject: Reply with quote
Set a border width for the table (ie border-width:5px;).
Also correct the minor HTML errors (ie, add a doc type), as this can lead to inconsistent handling of layouts..
Frost
PostPosted: 13:33 - 30 Jul 2010    Post subject: Reply with quote
Code:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" lang="en" dir="ltr">
<head>
</head>
<body>
<table id="first">
   <tr>
      <td colspan="5">
         testtesttesttest
      </td>
   </tr>
</table>
</body>
</html>
That's hot your HTML should look, all the stuff you have in there is style info and should be in the css file. Putting it int he HTML file you will eventually find yourself trying to over ride something with css and failing.
Sparks!
Sir Tart-a-lot
PostPosted: 13:43 - 30 Jul 2010    Post subject: Reply with quote
Simple as that Laughing thanks!
Sparks!
Sir Tart-a-lot
PostPosted: 13:44 - 30 Jul 2010    Post subject: Reply with quote
DaFrostyOne wrote:
Code:
<head>
</head>
<body>
<table id="first">
   <tr>
      <td colspan="5">
         testtesttesttest
      </td>
   </tr>
</table>
</body>
</html>
Nice one thank you, I'll go through the actual website and improve on the HTML as per your advice.
Sparks!
Sir Tart-a-lot
PostPosted: 14:13 - 30 Jul 2010    Post subject: Reply with quote
I've tried tidying my code up following your guides... once I remove cellpadding="0" and cellspacing="0" from the table itself in the HTML file then I lose the cellpading and spacing formatting on the site... Ideally id like to do this in CSS then but what I've put in doesn't work
Code:
table.second
border-width:3px
padding-top: 0px;
padding-right: 0px;
padding-bottom: 0px;
padding-left: 0px;
margin: 0px 0px 0px 0px;
PostPosted: 14:22 - 30 Jul 2010    Post subject: Reply with quote
The padding really applies to the table cells rather than the table which might be causing the issue
Have a read of this.
https://www.quackit.com/css/css_cellpadding.cfm
Frost
PostPosted: 16:23 - 30 Jul 2010    Post subject: Reply with quote
Also note the difference between an element 'class' and an element 'id'. ID's are unique and won't be repeated e.g major formatting areas. Classes are things that are be be repeated.
https://www.tizag.com/cssT/cssid.php
Messing them up is a very common cause of problems.
Paddings and margins are the bulk of what goes into css and can be a right pain to get sorted sometimes, especially when IE displays them different to firefox & chrome.
Do yourself a favour and develop it for firefox, and forget about trying to make it work for IE6! If your using something like dreamweaver you can set what display engine it uses to show the page you are editing.
If you are using dreamweaver it has features to check of code is valid css & xhtml. If not then there are some online validators:
https://validator.w3.org/
They will tell you rather cryptically where the error is. At first they will be a pain and slow you down, but you will learn how to do things properly which will save you time in the long run. good luck Razz
The last post was made 16 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 87.35 Kb
