gs500e lost all power
ssruk
PostPosted: 22:01 - 30 Jul 2010    Post subject: gs500e lost all power Reply with quote
hi my 91 gs500 has just lost all power no lights or anything the only thing thats got power is the alam
yes fuse had gone so changed it
batt is full i charged to be sure
im lost from there what can kill all electrics
anyone got any clues
(02)hyosung crusie 2(sold) (89)cbr 600f (91) gs500ex
cb1rocket
PostPosted: 15:10 - 31 Jul 2010    Post subject: Reply with quote
You need a multimeter and check for continuity. Check the wiring loom, I bet it has melted somewhere if the mainfuse has blown
MaybeGuy
PostPosted: 15:11 - 31 Jul 2010    Post subject: Reply with quote
doesnt the alarm have its own supply anyway? check the main fuse, not just in the fuse box. its usually on the starter solenoid
smegballs
PostPosted: 16:00 - 31 Jul 2010    Post subject: Reply with quote
Also make sure that the battery terminals are tight, loose terminals can cause intermittent total electrical failures.
ssruk
PostPosted: 16:21 - 31 Jul 2010    Post subject: Reply with quote
iv just took the hole loom out to strip it and rebuild it so will be looking out for any burnt or striped wires
and gs 500 only has 1 fuse on the starter there is a pop out resistor
ssruk
PostPosted: 16:22 - 31 Jul 2010    Post subject: Reply with quote
the alarm runs from the bikes power but it also has back up link to battery which i removed the link to the battery and it still worked and indicators flashed
ssruk
PostPosted: 16:24 - 31 Jul 2010    Post subject: Reply with quote
battery tight and terminals was cleaned still nothing
smegballs
PostPosted: 16:50 - 31 Jul 2010    Post subject: Reply with quote
I'd see if you are getting 12V at the battery positive up at the ignition switch.
cb1rocket
PostPosted: 16:54 - 31 Jul 2010    Post subject: Reply with quote
it could quite likely be a break somwhere along the wire - as said you need a multi meter and properly trace where the connection has broken. I'm sure there are more than 1 fuse on that bike. Its not in the same place as the main fuse. There is usually another 5 somewhere
ssruk
PostPosted: 17:34 - 31 Jul 2010    Post subject: Reply with quote
https://electricwiringdiagram.com/wp-content/uploads/2009/12/wiring-diagram-schematic-suzuki-gs500e-motorcycle.jpg only one on starter at bottom
link to diagram
ssruk
PostPosted: 21:14 - 31 Jul 2010    Post subject: Reply with quote
after ripping the loom apart i have come to see that the people that had this before me has took it out and tryed to bodge it together so im going buy a new loom i have maneged to get it to work again but id rather spend £30 for a new loom then bodge it together again i just go to figger out how to fit the costom lights to it as they are gsxr 600 lights the old 89 twin ones
hmmmnz
PostPosted: 09:40 - 01 Aug 2010    Post subject: Reply with quote
funny considering they didnt start making the 600 untill 1992
so ill assume you mean gsxr750 Very Happy
pretty easy to have 2 sets of lights, your biggest problem is hiding all trhe wiring that is in the large single round stock headlight,
and of course mounting said gsxr headlights,
are you using the whole gsxr fairing??
in my opinion, every other head light bar the stock one just looks stupid on a gs500,
if you are hell bent on the twin lights,
then pull all the wiring back under the tank, and just have 2 sets of wires going out from the 1 connector to the headlights,
the humans are dead
I kick arse for the lord
ssruk
PostPosted: 14:38 - 01 Aug 2010    Post subject: Reply with quote
yes its got gsxr fairing on and as for lights iwhen i got i was told gsxr 600 but i never looked in to it so it may well be 750 lights
anyways yes the bike has a mounting for the twins and wires are hidden under the faring https://ssr4life.darkbb.com//users/1213/19/13/60/album/photo012.jpg
https://ssr4life.darkbb.com//users/1213/19/13/60/album/photo011.jpg
a few pics to give you idea of bike if you any more about the fairing and so on then please tell as i dont know about them just how to ride them im a honda man to trueful its the 1st non-honda iv had
evoboy
PostPosted: 19:06 - 01 Aug 2010    Post subject: Reply with quote
Dont think its a GSXR fairing or lights.
Looks like a standard fairing that they did on some models of GS. (Slingshot?)
APT Motorcycles
ssruk
PostPosted: 19:41 - 01 Aug 2010    Post subject: Reply with quote
logbook says its a gs500ex witch on google search there naked
hmmmnz
PostPosted: 22:05 - 01 Aug 2010    Post subject: Reply with quote
it looks like a "spec II" aftermarket fairing,
anyway back to your problem
1st check that you have 12v at the red wire on the ignition switch
if so then with the key "on" check that you have 12v coming out on the orange wire,
the orange wire feeds everything, if there is damage too the wire or the ignition, then you won't be able to turn on the lights or even start it
the humans are dead
ssruk
PostPosted: 22:17 - 01 Aug 2010    Post subject: Reply with quote
like i say i had it running but the loom is held together with tape so just going replace hole thing just waiting for it only cost 30 quid so its ok
cb1rocket
PostPosted: 10:23 - 02 Aug 2010    Post subject: Reply with quote
I would of repaired the loom, replacing the loom could crop up more problems, just my 2p worth
ssruk
PostPosted: 11:40 - 02 Aug 2010    Post subject: Reply with quote
i dont its in a bad state id ill hook up pics of it later
ssruk
PostPosted: 12:01 - 02 Aug 2010    Post subject: Reply with quote
https://ssr4life.darkbb.com//users/1213/19/13/60/album/photo013.jpg
the loom all the white black and red is tape thats got 2 or 3 wires going to 1
https://ssr4life.darkbb.com//users/1213/19/13/60/album/photo016.jpg
4 orange solderd on to one
https://ssr4life.darkbb.com//users/1213/19/13/60/album/photo015.jpg
6 black and white go into 1 and about 3 inch down the loom they go back to 6
https://ssr4life.darkbb.com//users/1213/19/13/60/album/photo014.jpg
and wtf is this lives right next to batt
The last post was made 15 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 106.85 Kb
