Honda CG125 Burning Smell?
astroscope
PostPosted: 09:58 - 02 Aug 2010    Post subject: Honda CG125 Burning Smell? Reply with quote
HI Guys,
Just came to work today and just before turning the engine off, i smelt a little burning.
I inspected the Oil Drain Nut and put my finger under it. I saw some small amounts of oil.
Anything i can do?
I have done Oil changes myslef in the past and never changed the nut or anything else.
Is there something i may need to put between the Nut and the Engine to seal it?
Many thanks
2010 Honda FES S Wing 125
Martay
PostPosted: 10:02 - 02 Aug 2010    Post subject: Reply with quote
I think there should be a washer between the bolt and engine that seals it. This should be replaced each time. They are very cheap to come by.
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
astroscope
PostPosted: 10:09 - 02 Aug 2010    Post subject: Reply with quote
Thanks,
Do you know the name of this washer or rubber seal?
astroscope
PostPosted: 10:25 - 02 Aug 2010    Post subject: Reply with quote
Excellent,
Does this go between the Main Drain Nut and the engine?
astroscope
PostPosted: 10:28 - 02 Aug 2010    Post subject: Reply with quote
Found this on Ebay:
https://cgi.ebay.co.uk/copper-o-ring-oil-sump-plug-/170521396104?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item27b3de0388#ht_500wt_1154
Copper O ring sump plug.
is this one better?
radical
PostPosted: 10:55 - 02 Aug 2010    Post subject: Reply with quote
From memory the sump drain plug under the engine has a copper sealing washer and the oil filter drain cover on the side of the engine has an O ring.
pepperami
PostPosted: 10:59 - 02 Aug 2010    Post subject: Reply with quote
This +1
astroscope
PostPosted: 11:11 - 02 Aug 2010    Post subject: Reply with quote
AHHH!!
Mine never had the copper o ring in the main nut....
I've just done an oil change about 20-30 miles ago and now I may have to do it again just to put a new ring in it Sad
Sad Sad Sad
radical
PostPosted: 11:18 - 02 Aug 2010    Post subject: Reply with quote
Drain your oil into a container and just reuse it again, also try to get a magnetic sump plug from ebay as they do help and keep any metal particals on the plug until the next oil change. There is also a thimble filter on the CG125 located underneath the gearchange lever which should be cleaned as well on each oil change.
pepperami
PostPosted: 11:33 - 02 Aug 2010    Post subject: Reply with quote
Noted Thumbs Up
astroscope
PostPosted: 11:46 - 02 Aug 2010    Post subject: Reply with quote
I went on Ebay but could not find the Magnetic sump plug.
Also, where do i get the thimble filter and is it easy to change?
thanks
radical
PostPosted: 12:56 - 02 Aug 2010    Post subject: Reply with quote
rob yarrr wrote:
when you take out the sump plug thing,a big spring should be behind it and the thumble thing should be on the end of that
thats what its like on my model anyway
surely you will also have a sump drain plug under the bike as well as the filter on the side of the bike.
JH
PostPosted: 13:12 - 02 Aug 2010    Post subject: Reply with quote
Depends on the year of manufacture, radical.
My CG125-W for example has just the plug on the side below the gear lever. Behind this plug is the spring and 'thimble' assembly mentioned, and there's no seperate sump drain plug. However, the W ceased production in around 2000/01.
Not sure what the 2007 models had without checking the manuals.
Honda CG125-W
CBT: 7 Aug 2010
radical
PostPosted: 13:50 - 02 Aug 2010    Post subject: Reply with quote
Thanks I never knew that, its a good idea in that you get to clean your filter every time Thumbs Up
astroscope
PostPosted: 15:56 - 02 Aug 2010    Post subject: Reply with quote
pepperami wrote:
Noted Thumbs Up
Thanks for the tip!!!
should have thought of that! Laughing
I'll just have to make sure that container is nice and clean Smile
fiery tupp
PostPosted: 18:10 - 02 Aug 2010    Post subject: Reply with quote
To save draining the lot , do it cold & dont open the filler plug this will slow the flow & if you're quick you can after loosening drain plug , take it out have the crush washer in other hand fit it & bung it straight back in , still have something to catch oil .
If you can't fix it with a hammer , use your head .
JH
PostPosted: 18:52 - 02 Aug 2010    Post subject: Reply with quote
Just checked about the 2007 model (either a late ES-4, or an ES-7 - should be a label near the battery to tell which, although the models are essentially the same), and it should be the same as the W - a single large cap near the gear selector, behind which is the spring and filter.
In other words, if you watch this video, you'll the plug, spring, and mesh 'thimble' .
Cheers,
JH
Honda CG125-W
CBT: 7 Aug 2010
astroscope
PostPosted: 12:05 - 03 Aug 2010    Post subject: Reply with quote
Ahh yes,
I remember that good old video. That's where I learnt how to do my first Oil change.
This person (Alan) also tells you how to fix the starter motor.
Excellent stuff
The last post was made 15 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 119.36 Kb
