Road legal land speed record
Silver
PostPosted: 12:21 - 02 Aug 2010    Post subject: Road legal land speed record Reply with quote
Barry Beadle will travel to The Bonneville Salt Flats in Utah, USA, in an attempt to break the speed record for the bike. The current record is 247mph. Mr Beadle is the only Briton to enter the meet, and will join a line-up of 134 riders.
https://www.witneygazette.co.uk/news/8305881.Witney_biker_Barry_aims_for_speed_record/
A couple of amusing points;
heavily modified street bike, which has 500 brake horse power – two and a half times that of a normal motorbike.
Normal bikes have 200bhp! Shocked
He has already tested the bike at Elvington airfield, in Yorkshire, where he reached 213mph.
...on tarmac instead of sand. Can he really hope to go 34mph faster?? Probably not, I suspect he's in it for the experience. Would be pretty cool after all.
PostPosted: 12:34 - 02 Aug 2010    Post subject: Reply with quote
Elvington is far shorter than Bonneville. This weekend some friends were at Elvington and the best they were managing in 1.2 miles was ~213mph. Same people were managing about 10mph less in 1 mile at Honington.
Problem is more down to traction. The tyres can only transmit so much thrust and you get to the point where that is less than the amount of thrust needed to do a speed. Added to which the more power you have from a certain engine the more peaky the delivery is (and the more likely you are to have to suffer problematic turbo lag). Keeping it in the ever smaller window of thrust the tyres can transmit gets difficult if the turbo wakes up and gives you 100hp suddenly after you have backed off and opened the throttle again to recover grip.
Silver
PostPosted: 12:52 - 02 Aug 2010    Post subject: Reply with quote
Are you saying he wouldn't get to top speed at Elvington? If he would then surely he would need masses more power to propel the bike another 34mph (where wind resistance becomes a huge factor)?
D O G
PostPosted: 13:05 - 02 Aug 2010    Post subject: Reply with quote
I think the short track at Bonnevile is 4 miles long, the long one is 7 - so much longer to build up speed.
It'll depend on the quality of the salt too - if it is nice and hard then is can be very grippy - I've heard tales of cars and bikes laying rubber down on the salt.
All depends on the amount of moisture in it, unsuprisingly.
Silver
PostPosted: 13:08 - 02 Aug 2010    Post subject: Reply with quote
Sorry, I wasn't necessarily doubting that it was possible at Bonneville (where all the top speed runs seem to be done), more that, I guess, the ideal surface would be tarmac and that he was a long way off the speed at Elvington.
Teflon-Mike
tl;dr
PostPosted: 13:24 - 02 Aug 2010    Post subject: Reply with quote
34mph is a lot to find, but british tracks dont give us much help.
I think that the longest 'closed' strip in the country is in the middle of BAe Stevenage, and is about four miles long. Only trouble is, its a military air-base.... they dont let civvies down it very often!
Surface differences? I really dont know. Hard packed salt is pretty smooth, but it isn't solid....
What keeps niggling the back of my mind is the discrepancy between ET's on drag bikes brought over from the states, that haven't made the same times here as they did there, even with the same riders.
Remember whey back when, some-one brought, I think it was a double Z1 motor bike over, that had consistantly ran on the 9's on the US strips, to be the 'first' UK drag-bike to break the 10sec barrier (it was probably a class thing, I was never that 'up' on straight liners), and it took them about a season to even get close to threatening it, when the bike should have done it straight out the crate.
Best of luck to him, though.
PostPosted: 13:51 - 02 Aug 2010    Post subject: Reply with quote
With 500hp, not much chance of hitting top speed there. Best speed I know of there is Frank (the Flying Dutchman) who managed 265.4mph a few years ago on a turbo busa, but couldn't manage the same in the other direction (water injection problems). Having spoken to them they are not sure how much power they have (comment was their dyno doesn't read that high), but pretty sure that they could go quicker given more space.
Jack Frost has managed similar speeds at Elvington using ~500hp (boost turned down).
Problem at Bonneville is that there is less grip (with Frank you can hear him keep opening the throttle, having the revs go through the roof as it breaks traction then backing off again at well over 200mph, and that is on tarmac) which is a major problem. However the place is far higher which is a double edged sword. Means less air pressure so less power, although that should be possible to compensate for with higher levels of boost, but less air pressure also means less wind resistance.
500hp is enough for 270~280mph on a 'busa given enough space (enough for a lot more if you do some playing with the aerodynamics) and a reasonable surface. However that requires about 700 lbs of thrust, and rule of thumb is that overcoming rolling resistance takes 1% of the vehicle weight as thrust (so say 5lbs), even if the surface multiplies that by a factor of 10 it is a tiny amount compared to wind drag at those speeds.
D O G
PostPosted: 13:52 - 02 Aug 2010    Post subject: Reply with quote
US tracks are much better prepped than UK ones (they spray loads of 'glue' type shit on the tracks) - and used much more too, so the grip level is significantly higher because they have more cash to spend on the glue stuff, so apply it more frequently and use better stuff. Add in the heat and there's your answer.
At least, that is my understanding.
Spit-Fire
PostPosted: 15:24 - 02 Aug 2010    Post subject: Reply with quote
(exuse my ignorance on the subject)
has any body attempted a land speed record on any thing other then a busa?
most modern thousands are in same ball park power wise, and weigh less, so why not turbo one of them?.
they say the good die young... i say we just live faster
PostPosted: 15:36 - 02 Aug 2010    Post subject: Reply with quote
Modern thousand might be close on stock power, but are far too weak to take the tuning required and lack the decent aerodynamics needed, and lacking in space to hide away a turbo.
Stock 'busa might only be 150hp or so (early one, current ones are more powerful), but with a turbo the engines will put out about 250hp without any changes to the internals, and far more than that if you are prepared to change pistons, rods, etc. The basic 'busa engine is very tough. Try that with a GSXR1000 and you would probably need a strong bin bag to take the pieces home, let alone trying for 500hp.
Weight is virtually irrelevant for top speed (has a tiny effect by increased rolling resistance)
Frost
PostPosted: 16:17 - 02 Aug 2010    Post subject: Reply with quote
I think there is a level of grip that is needed to accelerate within a given distance.
On a runway you have more grip, but less distance. This means you have to use more of the power at lower speeds to accelerate to hit a high speed before you run out of runway.
On the salt flats you have less grip, but more distance to accelerate, so you can build up more slowly and still hit a higher speed.
Eventually the grip level will become a limiting factor, but wheel driven cars have hit over 400mph on the salt flats back in the 60's, so there has to be a reasonable grip level there.
PostPosted: 16:48 - 02 Aug 2010    Post subject: Reply with quote
Unfortunately their drag factor is probably FAR better than that of a 'busa, hence they might well need less thrust for those speeds. 'busa has a cda of about 3.37 and so needs about 565 lbs of thrust to hit 250mph. If you could reduce the cda down to about 1.3 then the same thrust (and so the same grip requirement) would get you to 400mph.
D O G
PostPosted: 17:20 - 02 Aug 2010    Post subject: Reply with quote
CHR15 wrote:
also, how does a guy who works for a drug addiction charity afford a bike like that....
It's a front for his dealing...
Frost
PostPosted: 19:19 - 02 Aug 2010    Post subject: Reply with quote
The car that did it had 4,500bhp, so it's aero wasn't that good!
PostPosted: 19:57 - 02 Aug 2010    Post subject: Reply with quote
A couple of world-class US bike racers have visited Santa Pod and declared it to be at least equal to their best tracks and far better than many. Where the Yanks win-out is with track-time and experience, and the fact that at least some of them are on a downhill-slope Smile
Frost
PostPosted: 20:17 - 02 Aug 2010    Post subject: Reply with quote
I would have thought that weather plays a part too. The UK is likely to be wetter, colder and have a different humidity. Colder air is denser giving more drag, and colder tarmac is less grippy.
PostPosted: 20:29 - 02 Aug 2010    Post subject: Reply with quote
Whereas Santa Pod is slightly up hill.
weegieblue
PostPosted: 20:45 - 02 Aug 2010    Post subject: Reply with quote
Aye, but only one way Wink
_______________
Suzuiki EN 125-2a - July 2010 to August 2010
Suzuki SV650s, 1999 model - August 2010 - now
PostPosted: 20:59 - 02 Aug 2010    Post subject: Reply with quote
It IS the important way though. No advantage having a down-slope on the return road Very Happy
Rob W
PostPosted: 21:08 - 02 Aug 2010    Post subject: Reply with quote
Wonder if they get a lot of gardeners there?
Thinking
Ariel Badger
PostPosted: 21:28 - 02 Aug 2010    Post subject: Reply with quote
At Bonneville you get a five mile run up to the timed mile and 6 miles after that to brake.
Here is the 125cc Buddfab taking a record run
Click and enjoy
Rob W
PostPosted: 21:32 - 02 Aug 2010    Post subject: Reply with quote
Ariel Badger wrote:
At Bonneville you get a five mile run up to the timed mile and 4 miles after that to brake.
Click and enjoy
Fcuk me!
186 from a 125!
Shocked
Ariel Badger
PostPosted: 21:39 - 02 Aug 2010    Post subject: Reply with quote
This is the 50cc Buddfab
click
Ariel Badger
PostPosted: 21:45 - 02 Aug 2010    Post subject: Reply with quote
CHR15 wrote:
he'd probably gain 10mph, by getting rid of that giant beard!
Big beards make you go faster Wink
Frost
PostPosted: 21:46 - 02 Aug 2010    Post subject: Reply with quote
Have you seen the bikes though? No way are they anything like street legal.
https://t2.gstatic.com/images?q=tbn:Isd-OpY71FQfkM:https://img238.imageshack.us/img238/2826/buddfabstreamlineray1.jpg&t=1
The engines are seriously fiddled with too. Aren't they supercharged or something?
The last post was made 16 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 141.2 Kb
