ZZR sticking when starting
stuartadair
PostPosted: 18:12 - 13 Jul 2010    Post subject: ZZR sticking when starting Reply with quote
Hello all,
1990 ZZR400. 90% of the time it starts first time and runs really nice. Gearbox is a little clunky but nothing out of the ordinary.
However, on occasion I'll go to start from cold and the starter turns but then sounds like it hits something and there is a clunk and the engine wont turn over. When I try and start with the clutch out its like the starter is jammed, and with the clutch in it sometimes turns but its as if the clutch isnt fully disengaged and I can feel the bike pulling.
To fix I put in first gear, rock the bike and it usually goes after that.
It only happens occasionally and only when starting from cold.
Any ideas .....
Stu
Frost
PostPosted: 19:30 - 13 Jul 2010    Post subject: Reply with quote
Sounds like clutch drag and the bike not being properly in neutral. Worn selector forks and barrel cause the problem, but the clutch drag will be making it much much worse. Give the bike a rev as you knock it into neutral to make sure its properly in there and adjust your clutch.
stuartadair
PostPosted: 20:01 - 13 Jul 2010    Post subject: Reply with quote
I'll give that a try, many thanks.
stuartadair
PostPosted: 18:48 - 02 Aug 2010    Post subject: Reply with quote
Bit of thread resurecction here but just to give you an update. I've found that if I try to start the bike when its upright and I'm sat on it with the clutch pulled in, 50% of the time it locks up and I have to rock backwards and forwards to free whatever is stuck.
Weird thing is if I start it sat on the side stand without touching the clutch, it starts perfectly every time.
The last post was made 15 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 38.46 Kb
