| nitro159 |
 nitro159 Two Stroke Sniffer
| Itchy |
 Itchy Super Spammer
 Posted: 22:55 - 02 Aug 2010 Post subject: |
Heating it up a bit maybe? Or some penetrating oil?
Heat worked on my NTV pins once first time I took the calipers apart. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| nitro159 |
 Posted: 23:06 - 02 Aug 2010 Post subject: |
Annoyingly I don't have a heat source for that, and taking it off at the moment will be tricky, it's the dead of night!  |
| robocog |
 robocog Traffic Copper
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 23:15 - 02 Aug 2010 Post subject: |
I had a similar problem which was a known issue with the pins on the Bandit.
Penetrating oil did it for me, then cleaned up the caliper, pins and retaining clips with an abrasive pad before re-installing. ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| Ariel Badger |
 Ariel Badger Super Spammer
| nitro159 |
| robocog |
| nitro159 |
 Posted: 00:01 - 03 Aug 2010 Post subject: |
Hi Rob
I was aware of that (about halfway through), and the problem is precisely that, I never intended to split the caliper. The only reason I'm here at the moment is when awkwardly trying to put the calipers back on, after spending a few minutes lining up the bolt holes and bolting it on, I pushed the brake pedal and tada, the brake disc actually bent and was pulled outwards rather than the brakes "squeezing" the disc, they just caused it to bend.
Also the "inner" pad was just, hanging loosely and seemed to have no function whatsoever, not rubbing against the disc atall.
And ontop of that, if you tried to let the wheel run freely, it'd catch at about 3 or 4 points and it'd become difficult to move along until you overcame it and it was free again. It was strange and certainly didn't seem to be how it functioned beforehand.
To just clarify, the pins and plate do move around as one, meaning they DO move back and forth? Because mine do not. (I do apologise about confusing people here, I'm still learning things myself and try to refrain from having my dad show me how to do things)
Wayne |
| robocog |
 Posted: 00:12 - 03 Aug 2010 Post subject: |
Yup plate is firmly attached to the two pins that run right through it
its the end inside the rubber boots that is free
https://mygpz.co.uk/_includes/galleries/gpz_fiche/images/29.jpg
Not the same bike, but parts look the same
Hope it helps a little, couldn't find a better diagram and too late to try and scan the Haynes (assuming it has a good exploded diagram anyway!)
Regards
Rob ____________________ Needs a bigger garage... |
| nitro159 |
| nitro159 |
 Posted: 11:37 - 03 Aug 2010 Post subject: |
More good news this morning , I found out one side still "slides", it's the other side that's locked up, I found this out by sliding a chisel through at an angle and using the brake piston to power it, was hoping to break (Brake!) it free but I coincidentally put the chisel on the moving side so it shifted that side along the pin slightly, however, I tryed on the other side but... the chisel snapped, so I'm at a loss of what my next step is, I'll look for some ACF when I'm in town later, halfords should have it.
Also I hope using leverage between the sliding "frame carrier" and the piston won't break anything, if it doesn't I'll look for something stronger and attempt to use that to break it free, also I can't actually move the rubber bevel on the side that's pissing about, the clean side is no problem to move (it's in the picture, you can see the brass coloured metal).
Also if it helps... the free side is the one with the rubber bit on the other end of the pin, i.e. the outer side of it. |
| robocog |
| ZRX61 |
 ZRX61 Victor Meldrew
The last post was made 16 years, 22 days ago. Instead of replying here, would creating a new thread be more useful? |
