Brake Calliper Paint
TQ
PostPosted: 12:24 - 03 Aug 2010    Post subject: Brake Calliper Paint Reply with quote
So I'm going to paint my brake callipers but I have absolutely no idea what sort of paint to use.
I've been looking around the web and some people seem to have got good results using a brush on specialist calliper paint, some using an aerosol calliper paint and some using regular rattle cans.
I wanted to mask off a design which will be left as polished bare metal but I'm unsure if the paint will stick to the bits around the design if I polish it before painting or if I'll strip the paint off if I polish after painting.
What does everyone think? Anyone got experience with any specific brands of paint etc....?
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
Frost
PostPosted: 14:21 - 03 Aug 2010    Post subject: Reply with quote
Brake caliper paint?
Acemastr
PostPosted: 14:32 - 03 Aug 2010    Post subject: Reply with quote
paint won't stick to polished metal, you'd have to sand the rest of the metal down, i once painted my cars calipers with bright red hammerite, came out ok, but you'd see bike calipers better so may want to spray them to get the best finish
2016 Toyota Tacoma Limited
TQ
PostPosted: 14:59 - 03 Aug 2010    Post subject: Reply with quote
Since paint won't stick to polished metal can you polish bits you've masked off after you've painted or will it strip the paint?
I'm thinking I'll get a better finish with a rattle can, does it need to be special paint or will any do?
Also trying to work out how matt black would look.
Frost
PostPosted: 15:12 - 03 Aug 2010    Post subject: Reply with quote
Lets try this again Razz
Brake Caliper Paint.
DrDonnyBrago
PostPosted: 15:19 - 03 Aug 2010    Post subject: Reply with quote
Polish it, then key the surface of the overly smooth bits you want to paint with some aluminium oxide paper. Mask off the polished bits during spraying and then clean up any edges with a bit of metal polish and very fine abrasive paper.
I'm assuming you want some lettering or similar to be polished whilst the rest is painted, the smaller the polished bits the harder it will be to keep the edges sharp. Also note that bare aluminium doesn't stay shiny for long, you'll be buffing/polishing them frequently if you want it to stay looking shiny.
TQ
PostPosted: 15:26 - 03 Aug 2010    Post subject: Reply with quote
You may well be right there. I was in two minds about leaving it bare metal or doing it in white (calliper will be black).
Frosty, however useful stating the obvious might be I was actually after people's opinion who have used the products. Have you painted callipers using halfords brake calliper paint? I looked at it but it would appear they don't do it in black.
Frost
PostPosted: 18:34 - 03 Aug 2010    Post subject: Reply with quote
Brake caliper paint is more resistant to brake fluid, which strips ordinary paint very effectively. The paint is also fairly heat proof, which can be an issue with normal paint. They do it in black and i have used it and it does what it's supposed to.
Anything near the wheels tends to get caked in salt and oxidise. Having painted parts and non painted parts will result in the oxidation going under the paint and helping to strip it off, rather like rush bubbles in a cars paint work.
If you want a shiny bit, i suggest you paint it on Wink
TQ
PostPosted: 08:23 - 04 Aug 2010    Post subject: Reply with quote
Did you use the brush on type or the rattle can type? It would appear they make both and I'm unsure which will give the best finish (and be the easiest to use).
I'm starting to think the bare metal is a stupid idea so will probably just spray it silver, mask it then paint it black. The silver won't affect the shade of black will it? i.e. I don't need to do the whole calliper silver just the bit that'll be masked off for when the black goes on.
Do you normally clear coat callipers?
The last post was made 15 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 58.9 Kb
