Aprilia Rs125
Ricky12345
PostPosted: 19:55 - 03 Aug 2010    Post subject: Aprilia Rs125 Reply with quote
Hi im looking for some help.
I have an aprilia rs125 which was in perfect running order when I parked it up
I finally gained access to the bike after an 8month argument with my physco ex.
The bike it turning over and not seezed
The battery is new
Bump starting is not working
Kill switch is on
Side stand kill switch has been disconnected
Would appriciate any help
Many thanks
PostPosted: 20:15 - 03 Aug 2010    Post subject: Reply with quote
Do you get a spark? Have you used fresh fuel?
fiery tupp
PostPosted: 21:28 - 03 Aug 2010    Post subject: Reply with quote
Try cleaning the carb , after 8 months jets will probably be varnished up .
If you can't fix it with a hammer , use your head .
Benson_JV
PostPosted: 22:32 - 03 Aug 2010    Post subject: Reply with quote
As Kickstart said, check for a spark, perhaps replace the plugs after trying new fuel.
Glenben92
PostPosted: 05:18 - 04 Aug 2010    Post subject: Reply with quote
Probably oil build up on the plug. The petrol evaporates but the oil doens't, so you end up with oil all over the plug which kills your spark. clean it and try to burn as much oil off as possible over the stove (remember to wrap the plug up coz you need to get it HOT) OR you could just replace it all together. also put fresh fuel in the tank and a bit carb cleaner goes down nicely.
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
Redoko
PostPosted: 13:13 - 04 Aug 2010    Post subject: Reply with quote
Have you considered turning the killswitch off.
The View Askew
PostPosted: 18:42 - 04 Aug 2010    Post subject: Reply with quote
He said it is disconnected.
swanny
PostPosted: 19:14 - 04 Aug 2010    Post subject: Reply with quote
the bike wont start at all until you connect the side stand switch.. even if its taken off it wont start as the circuits not complete.. this happened on my fzr400
try that..
M SWANNY.. see a sig !
The last post was made 15 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.72 - MySQL Queries: 13 - Page Size: 55.51 Kb
