digital camera question
colin1
Captain Safety
PostPosted: 09:04 - 04 Aug 2010    Post subject: digital camera question Reply with quote
With point and click film cameras, like disposables or whatever, you press the button and it takes the picture that second.
Why is it that with digital cameras, the hand held ones all seem to have a delay before the picture is taken, so you cant capture the moment ?
I know that SLR digital cameras take a picture instantly, but I dont want one.
I just want a cheap digital camera that takes an instant snap. I'm thinking £50 or less. Any suggestions ?
Fawbish
PostPosted: 09:31 - 04 Aug 2010    Post subject: Reply with quote
Its not that they dont, its that most people dont take into account the focus part of the photograph.
A throwaway has one focus point, no motors to make sure its autofocused or whatever.
If you want to 'capture the moment' most cameras will need semi depressing and then pointing at what u want to 'wait for the moment'. Then you should pretty much get an instant photo when needed.
Ichy
PostPosted: 09:33 - 04 Aug 2010    Post subject: Reply with quote
Film cameras use light to burn the image onto the film. Digital cameras obviously use a lot of electronics to replicate the same effect. A number of automatic processes, exposure, focus, etc take place before the image is captured, then you have a chunk of data to process. The extra cost of expensive digital cameras may not improve the image but may be aimed at speeding up the entire process.
I'm using a Samsung ES15 as a point and shoot at the moment, works well enough and sells for around £50 - £60.
colin1
Captain Safety
PostPosted: 09:35 - 04 Aug 2010    Post subject: Reply with quote
I'd prefer a fixed focus (and fixed everything else) that can take instant snaps that might be a bit iffy, than one that takes a pic a second later.
So does your samsung take an instant pic like a film camera, or have the pause I'm talking about ?
Itchy
PostPosted: 09:37 - 04 Aug 2010    Post subject: Reply with quote
I have a samsung thing, you can considerably increase the speed (as long as it's switched on) by turning all of the automatic things off autofocus/flash/face recognition etc. Still takes about half a second to take the snap though.
You just have to be ready and anticipate things to happen.
Ichy
PostPosted: 11:44 - 04 Aug 2010    Post subject: Reply with quote
Not instant, on standard setting with flash it takes roughly 1 second, I've not seen a pocket digital that did. My DSLR is very quick, burst mode gives 8 fps, but I still wouldn't say it was instant.
PostPosted: 11:56 - 04 Aug 2010    Post subject: Re: digital camera question Reply with quote
As above - cheap cameras can be instant because they don't have to 'do' anything bar the mechanical action. Older film SLRs and various compacts did have autofocusing mechanisms which did take a bit of time.
Most not-silly-cheap cameras these days are much better, but I can remember being frustrated using Dusty's Fuji/minolta thing that was around a second - which was terrible for bike photography!
You might find this list helpful, it seems quite up to date:
https://www.cameras.co.uk/html/shutter-lag-comparisons.cfm
PostPosted: 12:40 - 04 Aug 2010    Post subject: Reply with quote
I bought a cheap Sony camera a few years back because it has the shortest shutter lag. Its pretty good, I can't remember what model it is though.
Downside is you have to use Memory Stick instead of SD cards. You also still have to pre-focus with a partial button press to get the best results.
_Will_
PostPosted: 15:58 - 04 Aug 2010    Post subject: Reply with quote
An SLR is instant as its a mechanical action - Single lens reflex, the shutter exposes the image onto a sensor the shutter speed is usually dictated by the user or part of a pre programmed set.
Focus speed depends on lens/camera quality, if not half depressed or in continuous focus mode/manual/lock the camera will have to apply focus to the set of tasks.
Cheap digi cameras choose their settings for what they think is best, this means it has to meter and focus before choosing shutter speed which all creates shutter lag.
This will worsen in poor light as if is uses an af lamp it needs to light its subject before the line of tasks above.
A dslr in auto will not be instant if it has to focus and meter itself.
Suffering Bike Withdrawal.
The View Askew
PostPosted: 16:07 - 04 Aug 2010    Post subject: Reply with quote
The shutter opening time is the time needed to take a picture, after the shutter closes, the photo has been taken, the only other variable is the time taken to focus.
Film cameras have a delay if AF is selected, manually focused lenses will shoot instantly with manual flash.
£50 will buy you rubbish, use your phone, at least it ain't 35mm.
colin1
Captain Safety
PostPosted: 16:27 - 04 Aug 2010    Post subject: Reply with quote
ah this is the technical lingo
shutter lag, so I can just compare specs to find one with a short shutter lag
flat spot
PostPosted: 17:55 - 04 Aug 2010    Post subject: Reply with quote
I've got a Panasonic FX550. From DPreview.com ..........
"The multi-task image-processing engine Venus Engine V supports super-fast response time. The shutter release time lag is as short as approx. 0.007 second and the camera's quick response makes it easier to capture sudden, spur-of-the-moment photo opportunities. In burst shooting mode, the DMC-FX550 can snap approx. 2.3 shots per second at 12.1-megapixel large full resolution. And in High-Speed Burst shooting mode, it fires off an incredible approx. 10 shots per second. You also get unlimited consecutive shooting which lets you keep shooting until the memory card is full. Flash Burst mode makes it possible to take continuous shooting with continuous emission of flash."
It's the '98 R1 of the camera world. Mr. Green
Frost
PostPosted: 18:05 - 04 Aug 2010    Post subject: Reply with quote
Thats pants. It takes the picture AFTER you have pressed the button, what if your not quick enough? Some modern cameras now constantly take in data and buffer it. When you press the button it can take a still from the instant you press it, or any time before. Some fancy image processing can even pick the best frame for you.
There's clever isn't it?!
Silver
PostPosted: 18:09 - 04 Aug 2010    Post subject: Reply with quote
Shutter lag is not caused by the camera focusing, choosing exposure settings etc. You can prove that by half pressing the button on a digital camera so all of those calculations are performed prior to taking the final picture. That's not to say that these calculations don't introduce lag too, it's just that they can often be avoided. It's more to do with the electronics within the camera processing the information. That's why SLRs and, to a lesser degree, digital SLRs don't suffer as badly because the mechanism is mechanical and not electronic.
Basically, you get what you pay for. You really want to spend £50? Even if you find something with low shutter lag you'll find it lacking in other (more important areas), be that a poor lens, bad image quality, terrible low light performance etc.
It's £140, it's more like the CBR125 of the camera world... Razz
colin1
Captain Safety
That does indeed sound the bollocks, but probably out of my price range. Particularly frosty's.
colin1
Captain Safety
PostPosted: 18:12 - 04 Aug 2010    Post subject: Reply with quote
You get what you pay for, I only want to pay £50. I accept, that it wont be as good as a £130 camera.
Mostly I'm curious on the subject, I'm not desperate to get a camera. I'm encouraged that flat spots £130 camera has such a low shutter lag.
If there are any in my price range that were anything like as good, I'd be pleased.
Silver
PostPosted: 18:16 - 04 Aug 2010    Post subject: Reply with quote
Just don't get caught up in the "more megapixels is better" marketing ploy - it's not (necessarily).
Anyway, if you want an excellent reference for prices from various websites have a look here:
https://www.camerapricebuster.co.uk/
Clanger
Stirrer
PostPosted: 18:31 - 04 Aug 2010    Post subject: Reply with quote
That's why in any action shots, I sit there and snap away loads of times in anticipation of getting the decent shot...and more often than not got some brilliant pictures...!! Including dolphins leaping out of the water, lazers shows, fireworks... Thumbs Up
The View Askew
PostPosted: 18:58 - 04 Aug 2010    Post subject: Reply with quote
Yeah ignore megapixels, its the size of the image, and has literally nothing to do with the quality of it.
Think of it as a borderline, and the megapixel figure contributes nothing to within that border, it would just be black.
Cramming huge images onto a tiny sensor is just idiotic, and panders to conning the ignorant public who are just too happy to masturbate over MEGAPIXELLZ!!!ONE!!1.
I blame mobile phones for this.
Frost
PostPosted: 19:18 - 04 Aug 2010    Post subject: Reply with quote
Megapixels can be good depending on what you want. But they are certainly not the gold standard for determining how good a camera is. Generally speaking anything 5+ is as good as you will ever need it to be. The only advantage to lots of megapixels is that it gives you greater digital zoom (zoom without moving the optics like a telescope).
flat spot
PostPosted: 21:29 - 04 Aug 2010    Post subject: Reply with quote
And that's why I suggested it. Can you find any faster for that price? It was a £300 camera when it came out last year. Ahh well 'tis only money. Sad
PostPosted: 23:02 - 04 Aug 2010    Post subject: Reply with quote
Another vote for ignore megapixel count. No point having twice the number of pixels if the lens is so bad that light from a point can randomly be on several of them.
Seen decent A2 size prints taken from under 3mp images.
The last post was made 16 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 120.45 Kb
