| killa |
 killa Won't Shut Up
 Posted: 07:53 - 04 Aug 2010 Post subject: Oh joy, Brake problems again... |
The bike: Kawasaki ZX7R
The problem: Tokico 6 pots on front and single on the rear.
I sent the bike in to have the front brake pads replaced and system re-bled, and rear pads replaced.
The front apparently went pretty well, I have had them refurbished about 6 months ago now with new seals so i knew they weren’t bad.
The rear unfortunately was a bitch of a job. This is because I’ve been through two sets of fronts in the time it took to wear out a set on the rear. They couldn’t get the pins out so they had to force one out and the other was knocked out by drilling a small hole behind it to push it through.
The pads were replaced but they said the seals are a little swollen due to being pretty old now, so my rear brake is binding, only slightly.
I took the bike out from the garage and went for a spin.
So the back brake is binding, after a mile I got off the bike to check it out, the disc was hot enough to melt the hard plastic on my gloves knuckle.
Now the front seemed fine but when i got back to my place i bent down to check the discs, the front right disc wasn’t hot at all, but the left one was really hot!
I haven’t bed them in at all in the distance i travelled but i want to know if i should not ride the bike until i sort out a few things, or just see how i go with them like this. ____________________ Cleverly disguised as a responsible adult.
Bike:- Yamaha TRX850 | Killas Biking History | Killas Gaming History | Killas autmotive history |
| Ichy |
 Ichy World Chat Champion
 Posted: 07:59 - 04 Aug 2010 Post subject: |
There is a risk that the rear brake will lock up, I know from experience .
Are you sure the front was bled correctly? Its not unusual for the disc to get really hot so I wouldn't be too worried about the left hand side unless it was binding. Personally I'd pump the brakes a few times, hold the lever in and just crack the nipple open on the right just to be sure. Just remember to wrap a rag around it before you open up the bleed nipple just in case! |
| Ingah |
 Ingah World Chat Champion
| Ariel Badger |
 Ariel Badger Super Spammer
| Blau Zedong |
 Blau Zedong Banned
| TUG |
 TUG World Chat Champion
| Frost |
 Frost World Chat Champion
| swanny |
 swanny Spanner Monkey
 Posted: 14:28 - 04 Aug 2010 Post subject: |
kwak brakes always seem to fail or rust if you use your bike in all weathers..
if your back brake is catching.. do not use it, if you need to, take off the caliper,
force the cylinders back in the caliper by using a small piece of wood and some clamps, to do this relieve the pressure by taking the top off the fluid reservoir, or simply open the bleed valve ( this is a bit messy but if you do it when the clamps in place its easier..
if it goes back in your fine..ideally you need to give it a proper clean and replace the pistons and rubbers, or if you can clean them up so that they are spotless, any lines etc run your nail over and if your nail snags they need replacing..
if you need your bike desperately, make sure the pads are off the disc with ample room to move and then disconnect the caliper, so that you cant use it..
the front discs means ones not been bled 100% or the pads are worn differently, best bet is to bleed them first, then see if you have the same problem,
it could be that the pistons are also catching on the front, so repeat what i said for the front one thats catching, under normal riding conditions front discs shouldnt be getting warm,
hope this helps, but might not... ____________________ M SWANNY.. see a sig ! |
The last post was made 15 years, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
