DT 50MX
triggs1968
PostPosted: 19:44 - 03 Aug 2010    Post subject: DT 50MX Reply with quote
Hi all, my son has got a 1986 DT 50 MX. He was out for a spin when the engine started loosing power and died on him, he noticed that he had no 2 stroke oil left in the tank(numpty) and pushed the bike home. I have had a look at it topped up with oil, bled it through but the bike wont start. Looking on futher got a good spark from the plug but after kicking for a while there seems to be no fuel going to the engine. I have stripped the carb and reassembled it. No blockages and fuel runs into it ok. Tried to bump it and still the plug is dry. Any help would be great. Thanks
Dave. Yes he is a plonker
27cows
PostPosted: 07:30 - 04 Aug 2010    Post subject: Reply with quote
Will almost certainly have done some damage to the piston and bore, though that doesn't explain why fuel isn't getting through.
triggs1968
PostPosted: 07:59 - 04 Aug 2010    Post subject: Reply with quote
Thanks, do you recommend stripping the engine or is there anything else i can try first?
Ichy
PostPosted: 08:13 - 04 Aug 2010    Post subject: Reply with quote
Would that not be because the rings might be busted, therefore no vacuum to draw fuel through the reed valves?
Ichy
PostPosted: 08:18 - 04 Aug 2010    Post subject: Reply with quote
You need to remove the barrel to take a good look for any damage. Shouldn't be much work, remove the exhaust and sparkplug, then 4 nuts on the top of the cylinder head. Lift the barrel up slowly and when there is enough room stuff some rags in the hole in the crankcase, just in case. Only then should you lift the barrel completely free of the piston.
Just be aware that if the rings have broken that they may have fallen into the crankcase.
27cows
PostPosted: 12:13 - 04 Aug 2010    Post subject: Reply with quote
Could be. Though if the rings had broken, you would have expected a seizure.
Top end definitely needs to come off to assess damage. It might be possible to get away with a careful clean up of the piston and bore surface with emery cloth/wet & dry paper. Happened to me once on my RXS100 and the motor survived. Top end went on to do about 20,000 more miles Laughing
Robby
Dirty Old Man
PostPosted: 13:16 - 04 Aug 2010    Post subject: Reply with quote
As said, strip it and see. The good thing is that's an extremely simple engine to work on, and parts are cheap.
triggs1968
PostPosted: 18:44 - 04 Aug 2010    Post subject: Reply with quote
Thanks everyone for the help. He has melted the piston rings to the piston so buying a new top en kit.
Thanks again
Dave.
27cows
PostPosted: 05:50 - 05 Aug 2010    Post subject: Reply with quote
This is why it's always a good idea to have a nice simple engine, particularly in your early days on the road Wink
The last post was made 15 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 64.21 Kb
