TZR 125 engine help
pilot300
PostPosted: 12:04 - 06 Aug 2010    Post subject: TZR 125 engine help Reply with quote
Hi guys I have a 1990 tzr 125, it looks like a i need to do a re-bore however its is nikseal coated so going to be a little pricey. Im wondering are there any 250 two stroke barrel and pistons which would fit onto the TZR engine? something like a yamaha SR250 perhaps?
PostPosted: 12:16 - 06 Aug 2010    Post subject: Reply with quote
Not really. Ones from a TZR250 (250 2 stroke twin) might be similar (not sure) so you could possibly use one but it would probably be at best just as cheap and easy to sort out the 125 barrel (even assuming the 250 barrel needed no mods).
SR250 is a 4 stroke and certainly not usable for this.
Why do you think you need a rebore? Nicasil is very hard wearing so only likely to need major work if the barrel is scored. They can be replated for ~£100.
pilot300
PostPosted: 12:20 - 06 Aug 2010    Post subject: Reply with quote
im picking the bike up on sunday. it has no compression so expecting the worse. it could just be a set of rings. i would of like perhaps a larger capacity two stroke if i could though for more power. are there any larger capacity 2 strokes out there? as the largest bore kit you can get is 150cc (which actually works out to be 134CC once you've done the maths)
regards
duncan
PostPosted: 12:33 - 06 Aug 2010    Post subject: Reply with quote
Not really. SDR200 engine (or DT200) are pretty much the same and should fit easily, but they are pretty rare (to the extent that plenty of SDR200s probably now have TZR125 engines in them).
There is a 170cc kit for the TZR125.
Which model of TZR is it that you are getting? If an early shape UK one (rather than an Italian market one) then there are over size pistons available as they do not use a plated bore.
pilot300
PostPosted: 13:02 - 09 Aug 2010    Post subject: Reply with quote
Hi there
Got the bike yesterday and took engine out. The piston and rings have had it and scored the barrel. I was under the impression they were nikosil barrels although mine seems to have a sleeve. Also with barrel and piston off ive noticed the big end bearing needs replacing too. So for re-bore and piston plus a crankshaft and con rod im looking at £130 im looking at complete engines for a little less then this.
Would a newer engine with the power valve already in place fit straight in or will i need a similar year engine? Also can the power valve easily be fitted to these engines? and finally can you recommend any good motorcycle breakers in the west midlands?
cheers guys
Billing
PostPosted: 13:15 - 09 Aug 2010    Post subject: Reply with quote
As Keith said, only the later TZRR's had nikasil plated barrels, not the UK 2RK bikes. The YPVS kit is getting hard to get hold of, but if you get one and all of the seals etc then it's a piece of piss to do, I fitted mine with the engine in the frame in about 20 minutes from start to finish, you only need to take one side panel and the fuel tank off to fit it Very Happy
PostPosted: 13:22 - 09 Aug 2010    Post subject: Reply with quote
£130 is pretty cheap for a rebore and crank rebuild.
Think the later engines have different mounts, but not sure or sure on when they changed.
Your engine has the power valve in it, just nothing to operate it. You could get kits to fit from Yamaha years ago, but these are rare now and expensive if you can find them. You need the control unit, servo unit, cables and a few minor bits for the housing on the barrel.
pilot300
PostPosted: 15:49 - 09 Aug 2010    Post subject: Reply with quote
on the bright side ive found different parts across ebay so looks like will b able to rebuild my engine for less than £50 including postage of all parts. Found a complete power valve kit but he wants £125 for that. bearing in mind the bike including new engine parts will owe me £210 is the powervalve gain really worth the £125?
regards duncan
PostPosted: 15:53 - 09 Aug 2010    Post subject: Reply with quote
Afraid only you can answer that. You can get the same top end power by pegging the power valve in the open position, but you will say goodbye to any bottem end or mid range power.
pilot300
PostPosted: 10:33 - 11 Aug 2010    Post subject: Reply with quote
Thanks for the reply guys. Im currently looking for parts to re-build my engine myself. ive located new barrel, piston and rings fairly cheaply. the problem im having is a replacement crank & conrod. I jave a couple which im wondering if they would fit, they are as follows:
DT125 twin shock from late 1970's
DT125 3md from 1989-1992
XT125 2005
YZ125 2002
I have a 1990 TZR 125. from things ive read i think the DT125 3md would fit. am i right?
Kind regards
duncan
Billing
PostPosted: 11:21 - 11 Aug 2010    Post subject: Reply with quote
I'm not sure any of those will, the stroke on the later DT engines is different to the TZR's. The early ones ('87-'89) should be ok as the engines were the same, it was the carbs and gearboxes that were different
pilot300
PostPosted: 11:15 - 19 Aug 2010    Post subject: Reply with quote
Hi guys
Thanks for all the advise, in the end i replaced the engine and the bike is now running nicely, except for a knackered alternator got got the replacement from the old engine.
Got a question about the YPVS, i've found one from a 4dl engine stupidly cheaply, not sure the owner knows how much its worth but was wondering if this would fit my 2RK engine?
best regards duncan
The last post was made 16 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.99 - MySQL Queries: 13 - Page Size: 75.59 Kb
