Quick questions about roundabouts with more than three exits
ajag
PostPosted: 14:09 - 08 Aug 2010    Post subject: Quick questions about roundabouts with more than three exits Reply with quote
Hello all,
I am new to the forum, a pleasure to meet you all!
I am about to take my mod 2 test on Friday, and right off the Test center there is a roundabout with more than two exits so I wanted to check with you guys before I go ahead and fail because of it Smile
If I got 2 exits to my left, one ahead and one two the right, I am sure the procedure is to turn on your left indicator right before taking the second exit to the left or the one straight ahead, immediately for the first left exit and right indicator for the right exit.
However, What happens if there is one exit to the left, one straight ahead and two to the left?
Assuming you want to take one of the exits to the right, you enter the woundabout with your right indicator on and switch to your left indicator right after passing the exit before the one you want to take?
Al the publications I have found refer to standard 3 exit roundabout so wanted to check.
Thanks for your time.
Regards,
Alejandro
aaronb74
PostPosted: 15:33 - 08 Aug 2010    Post subject: Reply with quote
It should be exactly the same no matter how many exits - you should generally indicate right if going right, and then indicate left when you pass the exit before the one you want to take (or indicate left immediately when taking the first exit).
Hope this helps.
Current bike - 2006 ZX6R
Alexio
PostPosted: 16:07 - 08 Aug 2010    Post subject: Reply with quote
Hope this helps.
Indeed, the only time you should indicate left before you actually get on to the roundabout is if you are going to take the first exit. Otherwise, put the right indicator on and then left before your turn, making sure to do a life saver left or right depending on which lane you are in.
ajag
PostPosted: 17:35 - 09 Aug 2010    Post subject: Reply with quote
Thank you very much guys, this really makes it a lot easier. Not sure why they just don't explain it this simple on book or during training.
Also, I noticed you both said indicate right, until right after passing the exit before the one you want to take.
Everyone has told me that if I am going straight I don't need to indicate at all until I pass the the exit before the one I want to take. Is this true? I would hate to fail due to this.
I am taking my exam tomorrow on the Croydon center. any other tips that are particular to this location?
Thanks!
Bloke
PostPosted: 19:22 - 09 Aug 2010    Post subject: Reply with quote
Has your instructor not taught you basic highway code stuff?
Surely you covered this in your CBT. Shocking tbh.
The 12 o'clock rule - Think of the roundabout as a clock face and you're the number 6.
If an exit off of the roundabout is lying beyond 12 o'clock, indicate right as you approach and enter the roundabout, continue to indicate right as you go around the roundabout until you have passed the exit before the one you wish to take, then indicate left to signal you are exiting the roundabout.
If the exit is before 12 o'clock you will NOT indicate until you are "exiting" the roundabout BUT...
If the exit is the very first exit. You indicate left before joining the roundabout and continue to do so as you take your exit.
In my rubbish drawing... Yellow = Left indicator. Black = No indicator. Pink = Right indicator. Smile
https://www.bikechatforums.com/download.php?id=74195
2008 VFR800 VTEC
ajag
PostPosted: 19:56 - 09 Aug 2010    Post subject: Reply with quote
Hello Bloke,
Thanks for taking the time to explain and draw this. This was explained to me during the CBT and in other opportunities, but the wording changed everytime. However, the most important reason I asked is because in all the examples around (publications and in training) we dealt with roundabouts that had only 3 exits.
I am taking the test in Croydon and right after leaving the test center there is a roundabout like the one I described. I would be gutted if I failed on this and right starting my MOD2.... again... The first time I took it my instructor decided to explain to me and the other pupil how to deal with these outside the test center right before going in and he got confused in the process. I just wanted to be 100% sure before failing again. MOD2s are very expensive Sad
Bloke
PostPosted: 20:37 - 09 Aug 2010    Post subject: Reply with quote
ajag wrote:
Hello Bloke,
Fair enough mate. Not your fault. It's not rocket science and your instructors should have the ability to at least get a standard way of explaining it. Smile
Mod2's are incredibly expensive. Failed mine by losing my balance at a junction, having to put both feet down (Minor so far...) and what actually cause the "Serious" fail was rolling across the give way line in the process.
2 Minors 1 serious. Fail. 2nd time around I decided to "f**k the nerves", concentrated on the ride I was blabbing everything I was doing to myself but the 30 minutes flew and it was no trouble. 3 minors picked up in the first 5 minutes but passed Very Happy So just don't stress, you know this stuff.
2008 VFR800 VTEC
ajag
PostPosted: 12:13 - 10 Aug 2010    Post subject: Reply with quote
Hello guys,
I am happy to report I passed the MOD2 test. Finally I don't have to worry about that stuff again.
Thank you all so much for your help. I really appreciate it and it did come in handy.
Cheers,
Alejandro
PostPosted: 13:02 - 10 Aug 2010    Post subject: Reply with quote
Congratulations Thumbs Up
Triumph Trophy Launch Edition
Alexio
PostPosted: 13:41 - 10 Aug 2010    Post subject: Reply with quote
ajag wrote:
Hello guys,
Cheers,
Alejandro
I agree, no need to worry about indicating now Laughing
I say just ram her in to third gear and hope for the best Wink
Bloke
PostPosted: 18:30 - 10 Aug 2010    Post subject: Reply with quote
ajag wrote:
Hello guys,
Cheers,
Alejandro
Congratulations! Very Happy
2008 VFR800 VTEC
ajag
PostPosted: 11:29 - 11 Aug 2010    Post subject: Reply with quote
Thank you all! Smile
The last post was made 16 years, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.57 - MySQL Queries: 13 - Page Size: 77.55 Kb
