psi ... down ...
dodgydog
PostPosted: 15:43 - 08 Aug 2010    Post subject: Reply with quote
Shouldn't lose that much when you finish pumping it up.
You don't have one of those tyre pressure indicators on the valve cap do you?
I've seen a few of those that were faulty.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
PostPosted: 16:22 - 08 Aug 2010    Post subject: Reply with quote
Check the tyre valve isn't leaking first. It costs nothing to spit on it Thumbs Up
Frost
PostPosted: 16:48 - 08 Aug 2010    Post subject: Reply with quote
Probably the valve that has gone, they do go sometimes. It's certainly alot cheaper to check than to buy a new tire.
PostPosted: 17:21 - 08 Aug 2010    Post subject: Reply with quote
Swap the valves front and rear, see if the problem moves. Your valve might only be opening at speed by the way so watch out for that.
L-Jam
PostPosted: 18:03 - 09 Aug 2010    Post subject: Reply with quote
Roflprovider wrote:
... there was some glass at the top of my acess alley .. have cleared it now, but it may of happened when i dropped the bike the other day at 1mph trying to avoid said glass ....
So you were travelling at 1mph but instead of braking you dropped it?
Do you do this at junctions to come to A more abrupt stop too?
Journalist, student, egotist.
Resident Yank
PostPosted: 21:29 - 09 Aug 2010    Post subject: Reply with quote
It doesn't take much glass to puncture a tire. I noticed the tire on my bike was low, aired it up and after a few days sitting in the garage it was completely flat. Checked the tire over and saw nothing wrong. Another much closer inspection revealed a small slither of glass in the tire. I took the tire and had the puncture patched. A week later it was flat again. Another close check of the tire revealed a second piece of glass. Replaced the tire and a month later got a nail right on the edge 2 days before my first trackday. Slightly annoying.
Snooping in from the US, don't kill me.
weegieblue
PostPosted: 21:38 - 09 Aug 2010    Post subject: Reply with quote
I had this problem today! The front tyre has been losing a bit of pressure very, very slowly. This morning I got up and was about to head off for work but the front was really spongy so I decided against it. Went to the tyre place today when i got in from work and they had a look. Turns out a tiny bit on the inside of the rim had corroded, and this was allowing the air to escape. He just scrubbed it with a wire brush for me and voila - no more leaks, and only a fiver.
Happy days! Smile
_______________
Suzuiki EN 125-2a - July 2010 to August 2010
Suzuki SV650s, 1999 model - August 2010 - now
Dazbo666
PostPosted: 21:59 - 09 Aug 2010    Post subject: Reply with quote
...or some water with some washing up liquid in it Thumbs Up
Word of the day : DILLIGAF
PostPosted: 20:21 - 10 Aug 2010    Post subject: Reply with quote
Bike on stand - wheel turning - pour it on, or apply with a brush/sponge.
iooi
PostPosted: 20:26 - 10 Aug 2010    Post subject: Reply with quote
Rapdude wrote:
Over it, or wheel in a container ... ?? Confused
If you can get the wheel off then get it in the sink, when her indoors is out of the way Wink
Other than that, brush water onto the wheel as you rotate it and watch for the bubbles.
The last post was made 15 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 105.61 Kb
