=[YAMAHA YB 100 RATTLE]=
Seb
PostPosted: 21:09 - 09 Aug 2010    Post subject: Reply with quote
=[It's dead Jim]=
2010 Triumph 1050 Sprint ST
radical
PostPosted: 21:58 - 09 Aug 2010    Post subject: Reply with quote
Sounds like the big end has died a death, to repair you will need to split the crank and replace the crank pin or oversize (machine) the existing crankpin and fit oversize bearings, that said you will need to replace the wee end and the main bearings plus crankcase seals to make it worth your while, is it worth it depending on the overall condition of the bike? there is no cheap fix.
PostPosted: 22:06 - 09 Aug 2010    Post subject: Reply with quote
the con rod will move side to side a little, but its if you can make it move angle wize to the plane of the crank. If you can move it so that it is anything but vertical in the plane of the crank pin, then it is the big end I suspect. If not, then it might just need a rebore.
On my RD350 it rattled a lot, and it turned out the bores were worn oval and the piston was rattling up and down the bore. This is a recipie for disaster because eventually the piston skirt will shatter.
I'd say we need more information before we make a decision as to whether or not you need a bottom end rebuild. Personally I'd probably take it to a garage to have it looked at, at the very least. Even if you do the work yourself, it is better to get a professional to diagnose the issue rather than asking random people off of an internet forum.
27cows
PostPosted: 22:10 - 09 Aug 2010    Post subject: Reply with quote
If the big end had gone, normally you'd see evidence (in the form of swarf) around the big end area. It'll be worth checking the amount of side to side movement with a feeler gauge to see if it's within tolerances (I've had readings way over on similar engines and they've still been fine - worth bearing in mind). A big end will usually knock rather than rattle - and quickly become terminal.
Could be bore wear. Make sure neither of the rings is stuck in their grooves. Also worth looking at the small end.
kingsknight
PostPosted: 13:54 - 20 Aug 2010    Post subject: Reply with quote
bad times Sad I hate that feeling when you know your bike is fucked. Riding along then.... bad sounds..... stop..... its fucked Sad
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
pepperami
PostPosted: 14:29 - 20 Aug 2010    Post subject: Reply with quote
I`ts a YB100 so all is not lost Smile .... there are still a good few of them around, so you should be able to get the bits Smile .
they are not a complex bike so it should`nt? be to difficult to do? hopefully?, possibly? maybe?
The last post was made 16 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 73.23 Kb
