How would you compare a bike to a car BHP wise
kneedown
PostPosted: 13:31 - 10 Aug 2010    Post subject: How would you compare a bike to a car BHP wise Reply with quote
I was talking to my friend whos bang into cars, he started going on about this car hasd this BHP and that cars got that.
He asked how much BHP does your bike have, it has like 100hp or there abouts probably a little less.
So was wondering how could you rate a bike to a car, for example you have a car which produces 300BHP what would be an equivalent bike, in other words what would you compare an R1 (for example) to car wise
any thoughts
Silver
PostPosted: 13:40 - 10 Aug 2010    Post subject: Reply with quote
Simple answer is power to weight ratio.
DrDonnyBrago
PostPosted: 13:46 - 10 Aug 2010    Post subject: Reply with quote
That ^
Takes a mighty impressive car to match the power to weight ratio of a modern sportsbike.
PostPosted: 13:50 - 10 Aug 2010    Post subject: Reply with quote
DonnyBrago wrote:
That ^
+1
thats why tractors with 500bhp only do about 30mph tops...... .they weigh so much it takes all that power just to get the beast to move.
my bike has a 115 claimed bhp and a dry weight of 205kgs. (heavy by modern bike standards) but it will still eat and shit a subaru off the lights and hold its own against a porsche
PostPosted: 13:52 - 10 Aug 2010    Post subject: Reply with quote
Subaru's are hard to launch off the line, due to being AWD, but that is beside the point! Wink
PostPosted: 13:56 - 10 Aug 2010    Post subject: Reply with quote
like i said... can leave them behind at the lights! Wink
angryjonny
PostPosted: 14:02 - 10 Aug 2010    Post subject: Reply with quote
Quick Google search reveals the following:
My bike has 150bhp. At 208kg that works out at 721bhp/ton.
My car has 192bhp. At 1500kg that works out at 128bhp/ton.
Obviously - proportionally I add a lot more to the weight of the bike than I add to the weight of the car, and I can corner faster in the car without dying etc. So BHP/ton isn't really a sensible way of measuring how fast something is (realistically I think the bike is about 15mph faster than the car) but it gives an idea how overpowered modern sports bikes are.
johnsmith222
PostPosted: 14:07 - 10 Aug 2010    Post subject: Reply with quote
My ZZR600E has a better power to weight ratio than a mates tt supra. My bike is slower so power to weight ratio doesn't mean your bike is faster. Especially when you consider the only times you're going to be going from 0 to 60 is at traffic lights etc.
I know which one I'd rather have, and it isn't the ZZR. Cool
PostPosted: 14:18 - 10 Aug 2010    Post subject: Reply with quote
Power to weight affect acceleration but the weight is pretty unimportant to top speed while aerodynamics is important. Bikes tend to have lousy aerodynamics (mostly salvaged by being smaller so giving a half decent cda despite a lousy cd figure).
You can't really have an equivalent between bikes are cars for power.
Frost
PostPosted: 14:20 - 10 Aug 2010    Post subject: Reply with quote
Don't forget to factor in rider weight. An extra 80kg of body weight is sod all to a 1500kg car, but it is a lot on a 120kg bike!
P.
PostPosted: 14:25 - 10 Aug 2010    Post subject: Reply with quote
From experience...the bike wins.. only because my wallet isnt endless... and the Supra's tank is Sad
PostPosted: 14:30 - 10 Aug 2010    Post subject: Reply with quote
another point that needs mentioned is how that power is put into momentum.
a 4 wheel drive car has all 4 wheels in use turning that horsepower into forward momentum. as seen on various motoring program, 2 wheel drive or front wheel drive sports cars are all but useless in power delivery.
a bike has 1 wheel to use getting the power converted into forward momentum, that single tyre has a surface contact area of about the size of a 10 pence piece.
theres just way too many variables to consider to draw a comparison between car and bike bhp l
Chalky.
PostPosted: 14:42 - 10 Aug 2010    Post subject: Reply with quote
That's more to do with the gearing Wink
Yes, but the 4WD car is also wasting a lot more power in comparison to the 2WD ones in tranmission losses through the diffs etc.
With bikes the problem isn't grip as the weight is so low, it's more about keeping the front wheel down.
PostPosted: 14:55 - 10 Aug 2010    Post subject: Reply with quote
CHR15 wrote:
why are 4wd cars hard to get off the line fast?
They're just more tricky to launch quickly than 2WD cars.
Too little revs and it bogs down, which is pretty easy given you don't usually have enough power to spin all 4 wheels at once off the line. Put a pretty big strain on the drive train too.
Or you can slip the hell out of the clutch and risk killing it.
loply
It's difficult to compare due to aerodynamics, however, if we're talking sub-130mph then a modern 1000cc sports IL4 is roughly equivelant to a good 500hp car, in terms of acceleration.
Oddly, even an IL4 600 isn't far behind, you definately need over 400hp in the car to be in the right league.
Beyond 130mph though and the situation changes, though the car would need about 8 miles to take advantage of it's slippery slopes and catch the bike.
Yamaha SZR660 Caution to the wind, the throttle pinned!
calyx
PostPosted: 15:20 - 10 Aug 2010    Post subject: Reply with quote
Ducati 1098(160bhp) vs Skinny Gallardo (530bhp)
https://www.youtube.com/watch?v=GheILCh29-k
Show him this.
Boris - London
panrider_uk
PostPosted: 15:25 - 10 Aug 2010    Post subject: Reply with quote
Might have something to do with gearing too
Mark
WishayKillie
PostPosted: 15:29 - 10 Aug 2010    Post subject: Reply with quote
Show him this.
Always thought they should have used the 1098R (180BHP and a few kilo's lighter and a whole host of other things) rather than the standard 1098. At least then it would have been top of the range vs top of the range.
PostPosted: 15:34 - 10 Aug 2010    Post subject: Reply with quote
Show him this.
It'd have been interesting to see it done in the previous style with 'ghost' vehicles to be a bit 'fairer', but even then the bike was showboating all the time and could have gone a bit faster Rolling Eyes.
Cheeseybeaner
PostPosted: 15:47 - 10 Aug 2010    Post subject: Reply with quote
Is it? I would have thought if it could maintain better traction on a variety of surfaces that would not be a waste given the abundance of power it obviously has anyway.
PostPosted: 16:06 - 10 Aug 2010    Post subject: Reply with quote
Not putting the power down, but a 4WD transmission loses more power compared to a 2WD one though pumping loses and stuff in the transmission.
That's why engine figures at the crank are always higher than at the wheels, because of loses in the transmission. These loses are higher on 4WD cars.
PostPosted: 16:24 - 10 Aug 2010    Post subject: Reply with quote
4wd does eat a load of power, but how much is going to vary. Launch hard and you will probably struggle to spin the wheels and will make very good use of the power that reaches the wheels (although your clutch might suffer). However you have a load more gears to drive which uses some power up, plus the transmission is probably trying to keep each wheel spinning at about the same speed so they will be fighting each other a bit (how much is gong to depend on how good the diffs are and how they are set up).
Good few years back I was with someone who had their 4wd car dynoed on a 4 wheel dyno. It made about 85hp, yet the claimed crank figure was 137hp, and you would expect quite a bit over 100hp from the lower spec engined 2wd version of the car. However that is a fairly crude 4wd system (front and rear diffs, with just a viscous coupling in the middle).
Frost
PostPosted: 16:54 - 10 Aug 2010    Post subject: Reply with quote
https://www.nahblog.com/wp-content/uploads/2010/04/fat_biker_1.jpg
Power to weight Laughing
Generally in a straight line a bike will win on acceleration up to about 80 against a really hot car, up to about 100 against something good, 120 something alright and spank everything else. Top speed wise bikes are pretty crap. Braking wise bikes are also a bit pants.
When it comes to corners even an average car will give a superbike a run for it's money. 5th gear did another test that was bike vs car:
https://www.youtube.com/watch?v=eDTLtwSS7fc
GSXR Vs westfeild
https://www.youtube.com/watch?v=q5DMmRp8KVI
Nissan GTR Vs Ducati 1098
Spit-Fire
PostPosted: 17:01 - 10 Aug 2010    Post subject: Reply with quote
0-60's etc, have always been helpful in putting the difference between
"car vs bike" in prospective for my car driving mates.
i think bhp, power to weight, etc is irrelevant.
(telling some one who drives a 250bhp hot hatch that your bike has 110bhp, isn't going to translate which is "faster" very well)
price is also a big factor also,
they say the good die young... i say we just live faster
The last post was made 15 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 135.13 Kb
