Help with excel (open office)
c_dug
PostPosted: 20:43 - 12 Aug 2010    Post subject: Help with excel (open office) Reply with quote
Hi guys.
I'm doing an excel sheet at work. At the moment I have a row of cells dividing the two cells beside it and giving the answer e.g.
=B4/C4
and then conditional formatting turning the background of any figure over 15 red and any below green.
This is all good so far.
However for divisions including zero it is leaving #DIV/0! in the box, which then gets coloured green too.
How do I make is so that boxes containing #DIV/0! remain white?
If I get an answer before 9 tonight it will be awsome Thumbs Up If not then whenever is still good.
Thanks
c_dug
PostPosted: 20:57 - 12 Aug 2010    Post subject: Reply with quote
I'm confused. Upload the spreadsheet so I can have a gander.
benvanwell
Surely you can just have an if statement to check if C4=0 first:
=if(c4=0, display whatever and format white, b4/c4 and conditional fomatting).
I'm sure you get the gist.
I would do it properly but I'm now trying to get my head around where everything is in 2010...
Currently Riding: Triumph Sprint ST 1050
Previous: GSF600s, GS500, BMW F45, CG125
Frost
PostPosted: 21:55 - 12 Aug 2010    Post subject: Reply with quote
https://www.timeatlas.com/5_minute_tips/general/preventing_excel_divide_by_0_error
c_dug
PostPosted: 22:21 - 12 Aug 2010    Post subject: Reply with quote
Can't upload the spreadsheet, contains data the company probably deems as sensitive.
I may do another one as an example if I can be bothered, that's a little too much like work for me to be doing at home though!
I'm not sure if it will make much difference but what we have at work technically isn't excel its "open office calc" it's more like excel from windows '98. All the same formulas work though, in fact, I haven't used '98 in quite a while but I wouldn't be surprised if this actually was excel from '98 just re-branded.
How do I upload a spreadsheet? I have nothing better to do I may as well throw one together, it wont take 10 minutes.
herulach
PostPosted: 22:22 - 12 Aug 2010    Post subject: Reply with quote
amend your formula to IF(ISERR(B4/C4),"-",B4/C4)
That will stick a dash in the cell if you are getting an error. Then you can amend the conditional format to show that up seperately.
YBR 125>FZS600
c_dug
PostPosted: 22:32 - 12 Aug 2010    Post subject: Reply with quote
Sweet, thanks.
Tried making the formula but it turns out the latest excel is smart enough not to read the #DIV/0! error as less than 0.
thanks everybody
c_dug
PostPosted: 13:31 - 15 Aug 2010    Post subject: Reply with quote
Hi guys,
Still having no luck with this, the open office forumulas are different to the excel ones.
Openoffice is giving me an if statement prompt think which shows:
=IF(Test;then_value;otherwise_value)
Not sure what that is trying to get me to do exactly, however it does provide an IF statement creator from which I made:
=IF(B6/C6=0;"none";B6/C6)
Im still getting the #DIV/0! messege so I'm guessing I've done some of the formula wrong, assuming openoffice swaps commas for semicolons but keeps the rest of excel's rules, can you see any mistakes in my forumla?
Any other suggestions?
Thanks
bazza
PostPosted: 17:34 - 15 Aug 2010    Post subject: Reply with quote
Code:
=IF(ISERROR(B6/C6=0);"none";B6/C6)
That'll be £5.00 to https://www.helpforheroes.org.uk/donations.html please.
herulach
PostPosted: 07:38 - 17 Aug 2010    Post subject: Reply with quote
If you're doing it that way, then you need to check if C6 = 0. B6/C6 will never = 0 so you're always putting the division there.
YBR 125>FZS600
c_dug
PostPosted: 17:21 - 17 Aug 2010    Post subject: Reply with quote
Couldn't get the formulas to work so in the end I used 0.00000001 instead of 0, that way it rounds down to zero anyway.
The last post was made 16 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 68.7 Kb
