down gear grind?
captainbenson
PostPosted: 07:59 - 14 Aug 2010    Post subject: down gear grind? Reply with quote
yesterday i was riding braking and changing down gears from about 30mph, brought my cluth in, went to change down, as my foot went down it made a grinding noise and heavy vibrations on my foot, it was as if my clutch wasnt in, put in panic i let my clutch out and got a surge of power and my back wheel skidded about.
Its a Honda CG 125,
any ideas of what it could be?
any help would be cool thanks Very Happy
woll
PostPosted: 08:18 - 14 Aug 2010    Post subject: Reply with quote
The clutch adjusted right?
The back wheel locking up suggests that you've dropped it down a gear too early.
27cows
PostPosted: 08:25 - 14 Aug 2010    Post subject: Reply with quote
Another CG with problems Shocked
Could just be time for an oil change or you could be low on oil.
el_oso
PostPosted: 08:33 - 14 Aug 2010    Post subject: Reply with quote
surge of power from a cg Shocked
you sure the clutch was pulled all the way in and the cable housing was still seated correctly.
change your oil if you haven't changed it recently and look for bits of metal and stuff in the old stuff
Duke 390
Car: Jeep Wrangler 4.0L
c_dug
PostPosted: 09:48 - 14 Aug 2010    Post subject: Reply with quote
Has it only done it once? Just sounds like you gave it a half hearted press downwards and it hasn't gone into the gear properly and kicked it back out, used to happen quite regularly on my NTV.
The last post was made 16 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 43.19 Kb
