cg 125 tapets
markrolls88
PostPosted: 16:16 - 14 Aug 2010    Post subject: cg 125 tapets Reply with quote
hi does any one know the tappet setting for a cg 125 its a 2002 model
sparky
PostPosted: 16:55 - 14 Aug 2010    Post subject: Reply with quote
google wrote:
The valve clearance should be set to 0.08mm (0.003 in) on both valves, this applies to all Honda CG125 models, there are only 2 valves.
Taken from Here
DRZ-400sm
markrolls88
PostPosted: 17:14 - 14 Aug 2010    Post subject: Reply with quote
ok so thats not my problem its rattling really loud and i have replaced the piston and rings
sparky
radical
PostPosted: 17:19 - 14 Aug 2010    Post subject: Reply with quote
Check for wear in your rocker arms and pushrods, also check for wear on the face of the camshaft and associated linkages, is your rocker gear firmly bolted onto the head and check for bent pushrods.
markrolls88
PostPosted: 18:01 - 14 Aug 2010    Post subject: Reply with quote
yea it did run low on oil it is epiclly loud and i cant work apparently i had a bent push rod but my dad bent it back but its still noisy
sparky
radical
PostPosted: 18:50 - 14 Aug 2010    Post subject: Reply with quote
I would replace the push rod, if the bike was run low on oil you can expect cam wear and possibly valve guide wear, was the big end and the main bearings all o.k when you changed the piston?
The last post was made 16 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 55.2 Kb
