Did the valve clearances on my road SV today ...
Blue_SV650S
PostPosted: 20:33 - 14 Aug 2010    Post subject: Did the valve clearances on my road SV today ... Reply with quote
.. god I hate that job!!! Mad
It is so tricky to get to the CCTs, especially the front one!! ... that and the front rocker cover means you have to take 3/4 of the bike apart to get to it!!! Thumbs Down
Still, I have set the gaps so huge now they will never need doing again ... shame it sounds like an old taxi now ... Embarassed
Anyone else set the gaps LARGE (i.e. slightly larger than even the upper end of the suggested gapping) to try and increase service intervals?!!?? Thinking
colin1
Captain Safety
PostPosted: 20:37 - 14 Aug 2010    Post subject: Reply with quote
is this a joke ?
Blue_SV650S
PostPosted: 20:47 - 14 Aug 2010    Post subject: Reply with quote
colin1 wrote:
is this a joke ?
Nope, why would it be a joke?? Confused
c-m
PostPosted: 20:54 - 14 Aug 2010    Post subject: Reply with quote
Blue_SV650S wrote:
colin1 wrote:
is this a joke ?
I think he is getting at the fact that setting them too large is just as bad as them being too tight.
Set them to the upper limit of the of the manufacturers guide but not over it.
Rob W
PostPosted: 20:55 - 14 Aug 2010    Post subject: Reply with quote
I'd go to the maximum recommended, and not over that.
TS50 > Senda 125 > ZXR400 > CB-1 > GSX-R1000 > Bandit 600 > ZXR750 H1 > GSX-R750 SRAD > '98 RR-W Fireblade > T595 Daytona > Hornet 900 > '04 Fireblade > GSX-S1000F (x2) > '23 XSR900
Blue_SV650S
PostPosted: 20:58 - 14 Aug 2010    Post subject: Reply with quote
It is not as bad as too tight ... too tight is BAD, and it will get worse ....
Too large makes very little odds (we are not talking a mile here, just an extra copula-thou' over the top to eek out the service intervals a bit more) ... and will only get 'better' over time.
A bit like buying some trousers that are too large for a kid to 'grow into' Wink
c-m
PostPosted: 21:01 - 14 Aug 2010    Post subject: Reply with quote
Too large makes very little odds (we are not talking a mile here, just an extra copula-thou' over the top too eek out the service intervals) ... and will only get 'better' over time.
Ah so we're not talking like a 70 year old hooker here, more like an out of shape middle aged women.
Carvel
PostPosted: 21:27 - 14 Aug 2010    Post subject: Re: Did the valve clearances on my road SV today ... Reply with quote
Doesn't this ring any bells.
Blue_SV650S
PostPosted: 21:54 - 14 Aug 2010    Post subject: Re: Did the valve clearances on my road SV today ... Reply with quote
eh? Confused
Carvel
PostPosted: 22:10 - 14 Aug 2010    Post subject: Re: Did the valve clearances on my road SV today ... Reply with quote
Blue_SV650S wrote:
eh? Confused
Doesn't the fact that since you've opened the gaps it's started sounded sounding like a taxi not worry you?
c-m
PostPosted: 22:14 - 14 Aug 2010    Post subject: Re: Did the valve clearances on my road SV today ... Reply with quote
loose valves mean the timing will be out, this can cause dropped valves
radical
PostPosted: 22:16 - 14 Aug 2010    Post subject: Reply with quote
What kind of valve system does the SV have ?
radical
PostPosted: 22:17 - 14 Aug 2010    Post subject: Re: Did the valve clearances on my road SV today ... Reply with quote
I agree as the valves will be opening later than they should.
Blue_SV650S
PostPosted: 22:26 - 14 Aug 2010    Post subject: Re: Did the valve clearances on my road SV today ... Reply with quote
no
I was exaggerating obviously, but there is a notable 'tick' now. ... Smile
Blue_SV650S
PostPosted: 22:30 - 14 Aug 2010    Post subject: Re: Did the valve clearances on my road SV today ... Reply with quote
what a load of old shite Rolling Eyes
ohc 4 valves per head.
why? Thinking
radical
PostPosted: 22:41 - 14 Aug 2010    Post subject: Re: Did the valve clearances on my road SV today ... Reply with quote
why? Thinking
are the valves operated directed by the rocker arms and tappets or are they shim and bucket operation ? Your valve timing wil be out if the clearances are set too wide but not to a great degree but wide clearances can cause damage to valves and rockers particuarly the rocker and tappet setups, the clearances are there to allow for expansion when the engine warms up so yours will be too loose when warm.
Frost
PostPosted: 22:45 - 14 Aug 2010    Post subject: Reply with quote
Gaps too big = noisey, insufficient oil at any point or too large may cause parts to chip / crack
Too tight = Valves held open and burning out, parts rubbing to hard and wearing down too fast.
Generally speaking too large is better than too tight. Clearances becoming too tight is likely a result of valve and seat wear, and is probably expected in a newer bike. Clearances getting bigger is likely due to cam & shim wear and is more common in older bikes from what i've seen.
I don't think there is anything wrong with making the clearances a little generous, but i wouldn't risk going too far overboard.
radical
PostPosted: 22:55 - 14 Aug 2010    Post subject: Reply with quote
by a tiny fraction.
and having massive clearances wouldn't change the valve timing one single bit. the valves just wouldn't open very much and it'd be noisy.
sv is shims iirc?
crap tastic job. tappets / locknuts ftw
your valve timng would be altered very slightly as the cam is making contact with the rocker arm slightly later due to the increased gap
Blue_SV650S
PostPosted: 23:05 - 14 Aug 2010    Post subject: Reply with quote
yes, bucket and shim. .. hence the cct faffing Wink
doing clearances on a bucket and shim is such a faff its worth trying to set them large imho ...
as for all this doomsday about out of spec (large) meaning lack of oil and damaging valves. ... I suggest you guys think more clearly about what is actually going on in there Wink
Phil_G
PostPosted: 00:37 - 15 Aug 2010    Post subject: Reply with quote
I Was always taught with my Kawasaki, as well as my Triumph 1500 roadcar to go for the middle of the manufacturer's specified range. Reason being, if you slightly over or under cook the clearance from that point, you should have a bit of leaway so it doesn't end up overly tight/loose.
I should also do the valve clearances on my pug, but with 175k miles on it and a bucket/shim arrangement, i really cba.. Embarassed
1997 Kawasaki ER 500 A1:- Once again, Its merely crap Smile
Blue_SV650S
PostPosted: 08:40 - 15 Aug 2010    Post subject: Reply with quote
going for the middle will give you the best chance of staying somewhere in spec, but hardly the most efficient way of doing things from a revisit point of view Wink
at the end of the day we are talking ~0.1mm difference here in a what 25mm 'lift'? .... it's not going to make any odds Wink
TUG
PostPosted: 10:49 - 15 Aug 2010    Post subject: Reply with quote
The only thing that makes valve clearances difficult is miss prints in manuals and stretched CCT's. Fucking VTR hahaha! Thumbs Up Cool
Haz ER-5, innit!
The last post was made 15 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.07 - MySQL Queries: 13 - Page Size: 118.34 Kb
