Hispania RX50 Rear Caliper
kipper641
PostPosted: 17:22 - 15 Aug 2010    Post subject: Hispania RX50 Rear Caliper Reply with quote
siezed is what it is and nothing is shifting it Sad
Tried a G clamp,hydraulic pressure and air.
Tried sourcing a new one but 100 quid is a bit steep.
SH ones are like hens teeth.
So does anyone know if this was fitted to any other bike ?
Or do you have one lying around ?
Many thanks
Keith Farr
kipper641
PostPosted: 17:34 - 15 Aug 2010    Post subject: Reply with quote
Does not look like it Sad
Keith Farr
kipper641
PostPosted: 22:47 - 18 Aug 2010    Post subject: Reply with quote
Tried everyting, hydraulic, Air, Grease gun nothing would move the jammed piston.
Finaly gave it to one of the Fork Lift engineers at work and voila he freed it all up.
At a loss to explain why it was so stuck, anyways all re assembled just need to bleed it to see if there are any leaks.
If so anybody know where to get new seals ?
Keith Farr
kipper641
PostPosted: 18:35 - 04 Sep 2010    Post subject: Reply with quote
Ah there you all are Smile
More tales of woe, refitted caliper.
No pressure despite copious bleeding.Fitted new master cylinder piston.
Still cannot get any pressure, occasionally feels tight on the pedal,bleed then no pressure again.
Pedal travels full stroke with no resistance.
No signs of any leaks, new copper washers fitted to banjo bolts.
Has me completely stumped ?
Willing to listen to any suggestions.
Many thanks
Keith Farr
The Artist
PostPosted: 18:48 - 04 Sep 2010    Post subject: Reply with quote
You bleeding it properly?
Quote Me Happy
PostPosted: 18:51 - 04 Sep 2010    Post subject: Reply with quote
Try reverse bleeding it using a syringe to pump fluid back through the bleed nipple to the reservoir.
The last post was made 15 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 50.55 Kb
