| craigdiver |
 craigdiver L Plate Warrior
 Posted: 09:36 - 16 Aug 2010 Post subject: Rear sprocket question |
I have a chinese 125 which sits at around 8000rpm at 60mph, I use the bike for commuting and would like to bring the revs down a bit for economy. my rear sprocket is a Crocodil 428-38T (38 teeth). A friend has suggested I can bring the revs down or increase speed by 5mph by changing to a 37 tooth sprocket (or less). I understand that it will reduce acceleration.
Has anyone any experience of going down 2 teeth, will it give better economy or will the engine just working harder at lower revs use the same fuel and wear the engine the same?
Any advice appreciated........
Craig ____________________ 600 Km on the clock and rising! |
| paddlesat16 |
 paddlesat16 Crazy Courier
| craigdiver |
 Posted: 11:03 - 16 Aug 2010 Post subject: |
Assuming it has the power to pull the higher gearing, then yes a smaller front sprocket will mean less revs for the same speed. However going from 38 to 37 teeth is going to mean doing you are doing ~7800rpm at 60mph rather than 8000rpm.
I wouldn't be certain that it will happily pull much higher gearing. Also using higher gearing to get better fuel consumption is only going to work if you can still sit in top, rather than be forced to change down all the time.
Going down 2 teeth on the back will probably mean that the chain needs to be shortened.
Increasing the size of the front sprocket has a similar effect as reducing the size of the rear sprocket (just that the front has FAR less teeth so a one tooth change is a far bigger percentage change).
| craigdiver |
| DrDonnyBrago |
 Posted: 13:16 - 16 Aug 2010 Post subject: |
All comes down to what they are designed for. Rpm is a limiting factor based on how quickly things move up and down (and to a far less extent how quickly things rotate). How far they move up and down and how heavy they are basically determines how many revs you can use. Your cars pistons probably weigh twice as much and move twice as far, putting far more strain on things for the same revs.
Honda sold the CBR250 a while ago as a normal road bike which had a red line at 19500rpm.
The last post was made 16 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
