| Stowelly |
 Stowelly Traffic Copper
| skatefreak |
 skatefreak World Chat Champion
| Stowelly |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Stowelly |
| taz4626 |
 taz4626 Renault 5 Driver
| alains |
 alains World Chat Champion
| dextersaurus |
 dextersaurus World Chat Champion
 Posted: 11:59 - 18 Aug 2010 Post subject: |
Maybe it's the springs?
How old is the bike? been off-roading?
Heavier oil, and replace the bushes too...
When did you last cahnge the oil? Fork oil has a tendancy to oxidise, so releasing the air from the forks could have a noticable difference.
But i do stick to my thought that it's the springs. The bike will probably have taken quite a beating in it's time... You never know who's been trying to wheelie it
Dunc |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 14:34 - 18 Aug 2010 Post subject: |
If the fork seals have been done recently, I presume the foks have been stripped.
Two thoughts occur to me, and they may be completely off the wall, but worth a though.
If its the last 'bit' of travel, where the springs are almost completely decompressed so not offering much spring force to return them, then 'something' wrong in the damper could be causing them to stick.
Who 'did' the forks, and could they have been assembled wrong?
When stripped, were the damping internals completely cleaned?
Were the fork sliders painted or anything?
Wondering if there are, or should be 'top-out' buffers on the ends of the damper rod, so that the damper rod cant be stretched or damaged at full stretch. If these have been put back on wrong, could be fighting the spring at the top of the stroke.
Next up, depending on which way up the damper internals are and where they work, sediment from oil fork-oil could have collected in the damping holes or grooves, giving a higher damping force at that point.
On the CB125 forks and many more, there's also a taper groove down the bore of the fork leg, so that at the top of the fork stroke, the oil has a smaller passage to squeeze through than when its heading towards the bottom, if the damper rod is has been re-assembled with something missing, or not tightened up right, possible that the damper seal is sat over the end of that relieve groove so giving an inordinately high damping force at the end of the travel.
MIGHT be worth just going back over whats been done, checking, and double checking against the book, cleaning everything meticulousely.
Amazing how so many times a 'quick rinse' can be more unhelpful than not cleaning.... dislodhing that 'little' bit of shit that wasn't doing any harm, and putting it somewhere it will! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 16 years, 74 days ago. Instead of replying here, would creating a new thread be more useful? |
