Couple of questions, Battery, exhaust studs, exhaust gaskets
m0l0t0v
PostPosted: 03:13 - 16 Aug 2010    Post subject: Couple of questions, Battery, exhaust studs, exhaust gaskets Reply with quote
Righto, as some people may know I bought a dirt cheap Hornet for 475. It's an import and doesn't have a switch to have headlights, sidelights or no lights so the lights are on 24/7 unless I disconnect it... Previous owner always had them disconnected and only rode during daylight as he said it always flattened the battery...
Now earlier it died and refused to start as the battery was drained. Bump started it and all was fine... Till I got into Wycombe and it died as I pulled off (did not stall, not petrol either Razz) Anyways I had help from a friend who came round with her car and leads (wouldn't normally start a bike like this but no other choice).
Got her started... and then when I went to rev again it died...
So went home in my friends car, and used my spare Hornet battery, which I put to charge until it was on full charge. Went back to the bike and remove everything to notice the battery is different. It's the wrong way round and and it's bigger which I did notice the first time but didn't click...
Now, would the different battery sizes be of much importance? The "dead" battery is at my friends house and I'm picking it up tomorrow and will put it on the charger to see if it's that...
Now, in his quest to find the mysterious tinny sound he remove the exhaust and then the downpipes, and in doing so broke some of the studs... How hard is it gonna be to remove them? I haven't had a proper look yet... It's blowing at the moment so I've bought new studs... Fancy giving me a hand G? Razz
And lastly, exhaust gaskets... What's the difference between ally and copper gaskets? They're the same price.. any differences?
And do I need a gasket from downpipes to link pipe? As I don't think my old Hornet had one and it was fine... as I want to fit the Scorpion exhaust I had Twisted Evil
Many thanks!
Dazbo666
PostPosted: 09:34 - 16 Aug 2010    Post subject: Re: Couple of questions, Battery, exhaust studs, exhaust gas Reply with quote
Had some similar issues with my old GPZ...
The continually flattening battery suggests a problem with the charging circuit / stator etc... Does the headlight brighten slightly when you rev the engine??
As for the exhaust/engine studs, some heat, a healthy dose of penetrating oil and stud extractors and/or mole grips may help.
Failing that, I eventually used a Dremel to cut a screwdriver sized slot in the top of the stud and used that as a leverage point.
As a last resort, you may need to cut off and drill out the existing stud(s) and re-tap the hole??
Word of the day : DILLIGAF
m0l0t0v
PostPosted: 02:24 - 17 Aug 2010    Post subject: Reply with quote
It does yes. With the new (old) battery it does the same, and my previous battery did this too. But it was fine today... Neutral
Will have a look when I take the downpipes off then, see what I can do.
Anything on the exhaust gaskets?
DrDonnyBrago
PostPosted: 08:03 - 17 Aug 2010    Post subject: Reply with quote
Just buy the copper gaskets, that is what comes with most new sets of downpipes for your bike. You should be able to get away without buying a silencer gasket if the two pipes are a tight fit (my scorpion goes on without a gasket).
Teflon-Mike
tl;dr
PostPosted: 12:22 - 17 Aug 2010    Post subject: Reply with quote
Could be the Honda Rectifier bug-bare.
Similar problem on my CB750, many many reports of similar sorts of faults on VFR750's & CBR's.
BUT.... Not always the £50+ ish regulator. Often IS, but there's a chance.
Now, electronics is like greek-science to me; everything is all made up of the basic elements of earth, wind, fire and water, just in different proportions; where in electronics it's resistors, inductors, capacitors and switches!
But, THIS one I 'sort' of understand, as we had a very similar problem I had to sort out at work many years ago, where the customer kept blowing up test-rigs, and it was for the same reason.
Alternator makes alternating current; battery gives a constant 12v ish, but the alternator makes a voltage that follows a sine wave, going up from 0 to about +15v then back down to 0, and then down to -15v before coming back up to 0 again.
Regulator uses diodes that act as one-way valves to make the -15 v bit + 15v, and then theres some capacitance and inductance used to 'damp' the varying voltage to 15v down to a more steady 12v, like the battery gives....
However, aparently 0 volts in elecronics isn't always 0 volts... which is where it gets confusing.Mut its all to do with the 0v 'reference', and if you measure from the battery neg to anywhere else on the frame, you should get 0v, as they are connected, right?
Well, there's a slight curiocity in that the frame or ground rail has resistance, and if you put a voltage on a load, like a head-lamp, and then use the frame as the return, that gives you a resistor network, and you CAN actually see a small voltage between the battery neg and the 'node' where the headlamp earth is.
Then you get the curiocity that while in a DC circuit 0v is no voltage, in an AC circuit, going between +v and -v, you get 0v in the middle, but that 0v isn't NECESSERILY the same 0v as the ground rail, which can be a small voltage.......
Which was what was blowing up our customers test rigs, becouse aparently they had thier power supply referenced to 0v by attaching it to the earth in the mains cable...... 0v in the test-rig was set at the nominal 0v between the + & = peaks of the AC supply.... and the small difference between the two, was enough to blow up thousands of quids worth of sophisticated test equipment!
OR in the case of Honda's..... thier regulators.
something in the circuitry, aparently needs a 'good' earth between the alternator the remote regulator, and the battery, or any resistance in the return path can fuck up the regulator.
Put that bit in bold, becouse its basically the only bit that I actually 'get', and is of any real use!
Anyhow, sure some-one mer conversant with silicon bits and bridge circuits could explain it better, or point to the flaws in it, but, as I understand it, if the earth isn't great, then the regulator doesn't regulate properly, and of the pulses of volts going in, it fails to turn the negative pulses upside down, so that electric gets lost, and can eventually fry the regulator, while it only pushes out 'some' of the possitive pulses in, so the charge rate is about 1/3 what it should be.....
Result... you dont get the ignition light coming on, like you would if the alternator wasn't working at all, or the regulator completely 'duff'...... bike runs, and provided little load is put on the electrics, runs fine... but turn the lights on...... added load quickly flattens tha battery, as regulator isn't sending it enough juice to keep it topped up.......
and there's something to do with the THREE wires from the alternator, giving AC volts to be regulated In theory they should each be providing +/-15v ish, but with thier peaks out of phase. But again, any resistance in the wires (or more likely the connections) between them and the remote regulator, and the peaks aren't teh same size, and the average 0v they each give is slightly different, and has a similar effect.
CONCLUSION:-
If you have a charging fault on an old Honda:-
a) try cleaning all the contacts on the plugs from the alternator.
b) Try running an extra earth wire between one of the alternator bolts, the regulator body, and the battery neg. (Three ring connectors & a bit of thick wire!)
If the regulator is already 'duff' probably wont fix the problem, but could save the new one. If the regulator isn't duff, MIGHT get the regulator regulating properly again, and sort it.
For a few minutes with the emmery and a little bit of wire, worth a try at least!
Robby
Dirty Old Man
PostPosted: 14:46 - 17 Aug 2010    Post subject: Reply with quote
Had the exact same problem on my 1997 CBR600, was the reg/rec. I found a cheap chinese one on ebay for 20 quid. Sold the bike so I don't know how it lasted, but at 20 quid its worth the risk if it does a year.
Exhaust studs. Get the manifold off, the you can get the broken studs out with penetrating oil and (locking) mole grips. Don't try using WD-40 and pliers, it won't work. Some heat may help, if you get really stuck then try hammering a small, cheap (and probably imperial, something like 5/16) socket over the end to wind them out. Don't resort to an easy-out, it's easier to drill them if it gets that bad.
I prefer aluminium gaskets, assuming they are the soft aluminium wadding/sandwich type instead of copper rings. The alumium ones go in more easily and don't take as much force to clamp up. If you're heavy handed like me, then using lots of force can strip out the stud threads leading to a world of pain. It's worth using a torque wrench to do up the new exhaust nuts, assuming you are using new nuts on new studs to ensure clean threads.
Do not overtighten on first assembly. Some exhaust gases may leak on the first run. The trick is to warm it up, then leave it to fully cool down, then re-torque the manifold nuts.
Make sure everything is clean. A little emery paper around the exhaust port where the gasket sits, clean gasket mating face on the manifold and head and clean threads makes the job easier. You'll swear if you strip threads.
Oh, lots of tea breaks. This is not a job to get irritated with.
Can you tell I've stripped a few exhaust stud threads in my time?
m0l0t0v
PostPosted: 15:29 - 17 Aug 2010    Post subject: Reply with quote
I know Honda's in general have a problem with reg/recs. But I've got 2 spares, one I bought which I thought needed replacing, but turns out it was my own fault! So have that new unused one. Then I have one from the old Hornet which I know was working fine. I'll see how it goes with this new battery, as the other battery may just not be holding it's charge anymore Thumbs Up If the battery does charge up then I'll look into the alternator/earths and then reg/rec, as there's not point frying the other 2!
What penetrating oil should I use/buy? And yes I'll be buying new studs, though I couldn't find any stainless ones Sad
https://cgi.ebay.co.uk/Honda-CB600-CB-Hornet-Alloy-Exhaust-Gaskets-New-x-4-/360186388909?pt=UK_Motorcycle_Parts#ht_500wt_928
https://cgi.ebay.co.uk/EXHAUST-GASKETS-HONDA-CB600-HORNET-set-4-/190324281559?pt=UK_Motorcycle_Parts#ht_500wt_928
These are coming up, doesn't say aluminium, but "alloy" Confused
May just get copper ones to be sure. My neighbour will have mole grips soi will borrow them, don't know who has a torque wrench though Neutral
Thanks Thumbs Up
Serendipity
PostPosted: 16:04 - 17 Aug 2010    Post subject: Reply with quote
I’ve tried various penetrating oils, but the one that seems to work best (for me anyway) has been PlusGas. Not many places stock it, but Isaac Lord on Desborough Road sells it. Not cheap though. I think it was about 8 quid for the can I bought.
I’m still tidying up the mess I made after breaking studs on my 1994 CBR600. Pain in the arse!
I have torque wrenches and can either pop round or offer a loan.
Let me know... Thumbs Up
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
m0l0t0v
PostPosted: 16:46 - 17 Aug 2010    Post subject: Reply with quote
You're a star. Will let you know when I get a chance/studs and gaskets come Thumbs Up
Robby
Dirty Old Man
PostPosted: 22:39 - 18 Aug 2010    Post subject: Reply with quote
Stainless studs are a poor idea. Stainless and alloy react, causing the alloy to corrode and produce that white alloy cruddy dust.
You want the alloy exhaust gaskets, as in your link.
Teflon-Mike
tl;dr
PostPosted: 00:26 - 19 Aug 2010    Post subject: Reply with quote
Stainless is also an EVEN bigger PITA to drill out when they shear, which being more brittle due to the high nickle content in the allow that makes them stanless, they do more easily!
WONT have stainless fasteners on my bikes; learned that lesson the hard way a VERY long time ago!
m0l0t0v
PostPosted: 04:39 - 19 Aug 2010    Post subject: Reply with quote
Good thing I haven't ordered the gaskets then!
Will do so now. And ordering normal studs. Thanks guys Thumbs Up
DrDonnyBrago
PostPosted: 07:36 - 19 Aug 2010    Post subject: Reply with quote
Alloy vs copper has been asked before - I would still recommend copper Smile .
https://www.bikechatforums.com/viewtopic.php?t=167253&view=next
https://www.z1ownersclub.co.uk/forum/viewtopic.php?t=14425&sid=70204dbc8809de6c9598ee736c2b4998
m0l0t0v
PostPosted: 12:07 - 19 Aug 2010    Post subject: Reply with quote
Hmmm fair. Well it's a bit late now.
It'll do. Razz
Robby
Dirty Old Man
PostPosted: 12:51 - 19 Aug 2010    Post subject: Reply with quote
Indeed. If you want shiny bolts on a bike that you want to keep a long time, then a better bet is chromed steel, or painted/polished and then lacquered steel.
Japanese fasteners used (in the 80s) to be high quality cadmium plated ones. They eventually rust, but after a clean up they will go another 10 years without getting too bad. Modern ones don't seem to be as good, but it probably shaved a tiny amount of weight and a large amount of cost going for plain fasteners instead of coated.
The last post was made 16 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 104.1 Kb
