Compression gauge...
dextersaurus
PostPosted: 12:47 - 17 Aug 2010    Post subject: Compression gauge... Reply with quote
Okay guys, i feel retarded as hell right now.
Just bought a compression gauge to see what's wrong with my GPZ, and i can't for the life of me figure out how it works.
It's got the wee release bit so you can reset the needle next to the actual reading bit, and then a long hose witha valve, and loads of connectors.
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190373995171&ssPageName=STRK:MEWNX:IT
That's it.
i've tried threading it into the spark plug hole, and turning it over, but i don't get a reading.
Someone help me Sad
Dunc
DaveH
PostPosted: 12:56 - 17 Aug 2010    Post subject: Reply with quote
Should just screw into the spark plug hole, making it air tight, then turn it over on the starter.
If there is no reading, try a little oil down the plug hole to see if it reads any better then.
Not sure what you mean by the wee release bit - is it open and the air is escaping here?
This any good, can't view it at work
https://www.youtube.com/watch?v=9U8iNb21arw
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
PostPosted: 13:01 - 17 Aug 2010    Post subject: Reply with quote
Normally screw in and then crank over on full throttle. Normally the thread has a rubber O ring to help seal it so you don't need to screw it in too tight.
steven_191
PostPosted: 15:01 - 17 Aug 2010    Post subject: Reply with quote
I have the same one. Screw the adaptor in with the o ring as mentioned to make it air tight. Push on the hose and crank it over at open throttle. There is a pressure release at the base of the gauge which would be the first place to check for leaking. Maybe the gauge is knackered. If you turn it over a few times then press the pressure release and nothing comes out then there is no pressure. Either a leak in the hose or guage or your engine needs a rebuild. Try it in all cylinders and compare. Might need to replace the kit if you can't sort it out
Ariel Badger
PostPosted: 23:58 - 17 Aug 2010    Post subject: Reply with quote
Open the throttle and then try.
The last post was made 16 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 45.51 Kb
