| markrolls88 |
 markrolls88 Renault 5 Driver
| Frost |
 Frost World Chat Champion
| snowdude2004 |
 snowdude2004 Nitrous Nuisance
| markrolls88 |
| Ariel Badger |
 Ariel Badger Super Spammer
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| dextersaurus |
 dextersaurus World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 13:56 - 18 Aug 2010 Post subject: Re: going through gears so fast |
Depending on what it is, and the gearing it has, and the power it has, 55ish may be all it will do whatever the gearing.
From the fundemental defanitions of physics, Power = Force x Speed, so Speed = Power / Force
We then need to look at the forces in action, from either end.
Engine is making force; comes from the bang inside the engine, where the petrol and air burning make a pressure, which multiplied by the area of the piston gives a force, then the leverage of teh crabk-shaft, makes it a torque, that then gets multiplied by the reduction gearing through the transmission to the back wheel, where it becomes the 'motive force' pushing the bike along the road, over coming the restistive force of drag, mostly wind resistance.
Important thing about wind resistance, is it increases with speed, more importantly, it increases exponentially. Wind resistance at 60mph is something like four times what it is at 30mph, not twice.
Right. See-saw principle. On one end of the see-saw we have the engine, making force, on the other end we have drag resisting it. When the engine makes more force than drag, bike accelerates. When drag is greater than force the engine makes, bike slows down, when the force the engine makes EXACTLY balences the drag, bike travels at constant speed.
Now, the gearing on a bike controls the ratio of engine speed to road-speed.
Engine may rev from idle, say 500rpm, to the red line of say 10,000rpm.
Typical 172 rear wheel will have a rolling diameter of about 500mm, so a circumference or about 1.7m, which means that it will turn roughly 1000 revolutions per mile.
So to do 30mph, you need the back wheel to turn 30x1000 revolutions, per hour, or 500rpm.
Engine can spin up to 10,000rpm, back wheel needs to turn 500rpm, so you need an overall gearing 'reduction' ratio of 20:1 between crank and wheel, right?
Do the same maths to max out at 60, and you need half the reduction, or 10:1 between crank and wheel, so that the back wheel spins at 1000rpm. To do 100, just under 1/3 the reduction, or about 6:1
HOWEVER, the FORCE you get at the back wheel, is inversely proportional to the gearing.
Back to the see-saw, and the gearing ratio is like moving the pivot.
Low gears are like having the pivot closer to the end with the wheel on. You dont get much speed, but you get a lot of force.
High gears are like having the pivot closer to the engine. You can get a lot of speed, but not a lot of force.
NOW we have the problem; Raising the gearing will turn the back wheel faster, BUT the engine is still delivering the same amount of force.... but becouse the gearing is taller, you get less of it at the back wheel.
However, for the same speed, the drag that force is needed to over come, hasn't changed, worse, the drag at the higher speed you WANT to go at, is even greater.
SO, if the bike in question is geared correctly for top speed, raising the gearing will NOT make it go faster, becouse raising the gearing, will reduce the motive force. So more LIKELY it will actually make it SLOWER, as with the higher gearing, it will ONLY be able to go as fast as the drag it can over-come, and with less motove force at the wheel, you will only be able to over come the lower drag at a lower speed.
THAT is the 'fundemental' truth of the matter.
You could gear a moped up to go faster than the speed of sound, if you really wanted to, but without the POWER to back it up, and shove the bike through the air at that speed.... never going to happen.
Getting 'practical' though, bikes are rarely geared optimally for top speed, and when I described the fundementals, I presumed that the engine ws making a constant force at the piston top regardless of how fast it was turning.
In practice, engines have a power-curve. Force they make varies accross the rev range. At lower speeds they tend not to make much power, as the crank-speed increases it ramps up to a peak, and then it starts to trail off a bit as the engine aproaches max revs.
So when you decide on the gear ratio to use, for top speed, you would want to select the reduction ratio that turns the back wheel at the speed you expect to go, at the speed the engine makes max power, not max revs, but the story would pretty much still be the same; Speed = Power / Force, so upping the gearing wouldn't get you going any faster.
BUT, second presumption, most bikes aren't geared for max speed. MOST are actually geared HIGHER.
Reason for this is that the force the engine makes is variable. Its not JUST dependant on the crank-speed, increasing as the engine turns faster, but it also varies on the throttle opening.
Close the throttle, and you choke the flow of air into the engine, you limit how much gets burned in each bang, you restrict the force the motor makes.
In practice then, 'max' power is a very particular set of conditions, a particular engine speed, under a certain load, with the throttle wide open.
But at something LESS than 'max-power', which on a 125 lests say is 10bhp, you can get say 8bhp from any number of different perameters; the engine turning a lot faster or slower than max power rpm, or running closer to max power, but on a part throttle.
AND, as said most bikes TEND to be quite significantly over-geared. Bike might only have the power to over come the drag at 60mph, but if they geared it so that it was at max power rpm at that speed, then come a hill, and a little gravity assistance, big risk of easily over reving the engine, and mashing valve gear or stuff driving the motor a lot faster than it can tolerate. So they over gear it, so that even of you got it up to about 80, still wouldn't rev the engine TOO far beyond 'safe' limits.
Other reason they over-gear, is reliability and economy. Reving the nuts of the motor under full load, will wear it out faster, and will be burning a lot of fuel. Gear it up, a 'bit' and in that 'tolerence zone' where you get 80-90% of max power, you'll still get enough force to go 'almost' 60mph, but be able to do it with a lot less revs, and more throttle.
So, NOW you understand gearing....... lets look at this ere Chinky-bike and think about whats going on!
First off, is it a cruiser, dirt-bike, commuter or 'sports-bike'?
Cruisers often have much bigger and heavier frames around thier little motors, and then have high wide bars. High wide bars spread the rider out like a parachute, increasing drag, so they wont go as fast to begin with, so they need lower gearing, but also, the heavier frame means that they take more shove to get them moving, so benefit fromlower cogs there too, so tend NOT to be geared higher. So for any given speed they will normally be reving higher.
Dirt-bikes tend to be lighter, but they still have wide bars, so again more drag, but dirt-bikes are expected to wheelie, and throttle response, and acceleration are more important in dirt-riding than top speed, so again, they tend to be geared lower.
Commuters, are the general purpose machine. Tend ot to be so heavy, wont have such high or wide bars, and will normallty be slightly over-geared, becouse ecconomy is the more significant criteria, and over-gearing, reduces acceleration, and if over done enough, top speed, and that makes the MPG figures look good.
Sports-bikes, you would expect would be geared for top-speed, thats what they sell on. BUT, on a 125 sports-bike, chances are they have taken on quite a bit of weight and bulk to give them the full-faired 'sports' styling, and if whats lurking underneathm is essentially your standard commuter model, possibly that they have been given a lower gear-set to move the added mass, brisken up the acceleration, and give that added notch or two of top speed, RATHER than any more power! Yes the fairing may inprove aerodynamics a tad, but, err not a lot!
SO... most bikes are over-geared, BUT on all but a commuter, Learner-Legal, chances are they are not AS over-geared as bigger bikes, and on a Chinese Import, NOT made to the standards of western bikes, and without as much power, probably geared a bit lower still.
Lets look at what you wrote:
| markrolls88 wrote: | i have bought this new bike its a import bike 125 i can get 50 mph out of it 60 down hill |
So, it only has the power to do 55mph under its own steam. Gravity assistance is needed for any more.
| markrolls88 wrote: | what the problem is, i go through the gears so quick its unbeleivable |
Interjecting there; not really. Always 'gets' me getting on a tiddler after the 'big' bikes, how much work you have to do. Riding the G/F's 125 not long back, remarked to her how it was one of the things that made tiddlers that bit less confidence inspiring; having to make three gear-ganges JUST to get up to 30mph.
On a big bike, you snick 2nd at under 20, to stop it screaming, IF you use it at all, and, well, on the 750, that will take you to 50 or more. short shift to 3rd at say 25mph, and you can pretty much treat it as an auto, becouse it will chug along happily as slow as 25mph in that gear, but pull all the way to around 80!
Tiddlers need to be worked. and getting them moving DOES take a few very close up-shifts. If you have come from dirt-riding, it can be disconcerting. Bikes you might have been riding on dirt may not have had much more power (though is compers, probably so!) but the 'references' around you are a lot different, and the apreciation of speed different. 30 on the road feels pretty pedestrian, on dirst, with the bike bucking about beneath you feels pretty hairy! Always feels faster on dirt! 3
| markrolls88 wrote: | so when im in 5th gear i am screaming the hell out of it |
again, thats the nature of little bikes......
| markrolls88 wrote: | but it wants to do more |
Err.... It probably WANTS to, but facts are it cant.
Making a lot of revs to go that fast, but you haven't run out of revs, have you? As you said, add gravity assistance, it goes faster, so there are revs to spare, simple fact is bike doesn't make enough POWER to go any faster, its peaked out.
FEELS like it wants another gear, to get the engine back down onto the polateau of the power curve where theres more torque, BUT, simple fact of the matter is, if you HAD a 6th gear to cog up into, it would drop the revs back, but with even LESS power available at the lower revs, you would PROBABLY just bog and slow.
| markrolls88 wrote: | if i change the rear sprocket and front sprocket will this fix my problem |
Well, that depends on 'the Problem'
At the moment, you have this idea that it 'feels' like you are lacking another gear to change up to. And the bikes reving its nuts off at 50.
Why is THAT a problem? Its a 'fact'
The 'problem' is either, YOU would like it to be doing 50 and NOT reving its nuts off; OR you'd like it to go faster than 50. Possibly, both... you'd like it to go more than 50 and NOT be reving its nuts off.
Back up to the fundementals; 50ish is PROBABLY as fast as it has the power to go. Muggering about with the gearing PROBABLY wont make much if any difference to the speed you can go.
So, if 'the problem' is its not fast enough. Messing with the gearing is UNLIKELY to significantly solve it.
Gear-up, and you MAY get an extra notch or two; but could as easily loose you a notch or two.
If 'the problem' is the busy revy engine noise, then gearing up, MAY drop the revs a bit and make it a tad more relaxed to ride, BUT, same as for speed, only by dint of lowering the engine revs (and for the amount possible, not a HUGE amount)
| markrolls88 wrote: | as the rear sprocket looks tiny but what are the sizes i can get cos i dont have a chain tool so i dunno how to go about getting the right size chain for the sprockets |
So, that lot taken on board.... 'looks tiny' isn't very helpful! How many teeth does it have? Might enlighten us more. And if you told us what the bike was, we MIGHT even be able to find out what the standard sproket sizes are, and even what alternatives you can get..... as it is, we're a BIT in the dark on that one, and unlikely to be able to assist!
Available sproket sizes will range from 'maybe' 13T to 17T for the front sprokets, 20T to 40T for the rears. Though for any specific bike, they normally only vary by 1-2T either side of the standard fit. (some bikes have a much greater range of available sizes; something like a BSA Gold-Star that can be fettled for use in slow-speed trials to road-racing will have a HUGE range; something like a CG125 might only have a choice of two front sprokets, and perhaps two rears, giving four possible ratios) ANYTHING is possible, though, and even on a Chinese import where often you cant find ANY 'off-the shelf' sprockets, standard size or other wise, you CAN get 'custom' sprokets made to suit your needs.
Swapping the front sproket, gives the biggest difference in ratio per tooth. Swapping the rear, a much smaller difference, per tooth.
For 1 tooth difference on the front sproket; you SHOULDN'T need to change the chain, or split it. Circumference of the chain is set by the circumferences of the sprokets + 2x the distance between them (roughly!)
Add 1 tooth on the drive sproket, and that will hook one more link onto it, but that will pull the rear wheel HALF a link further up the adjustment slot. Ie; unless you are SERIOUSELY muggering the ratio's about and making a BIG change to the rear sproket, should be within what you can 'adjust' out on the chain.
GENERALLY, sproket sizes are around 15T front sproket, 30T rear sproket. MOST bikes run a final drive ratio AROUND 2:1 reduction.
Rough Reckoner I gave earlier was that on a 'typical' bike you'd have about a 500mm rolling diamter back wheel, and if the engine revved to 10K rpm geared for about 100mph, it would have about 6:1 OVERALL reduction between crank & wheel.
So if the overall reduction is 6:1, and the final drive sprokets are giving around 2:1, then the transmission, will be giving about 3:1 reduction.
IF you have a 15;30 pairing, you can increase the ratio one of two ways. Either fit a bigger front sproket, or fit a smaller rear sprocket.
Going up one tooth on the front sproket would give you a 16T30T combination. Reduction Ratio would be 30/16 or 1.8:1 instead of 2:1.
That's an increase of +10%, so for the same 'buzzy' revs you have now, you MIGHT get 55mph IF the bike has the power to pull it (which we doubt) or, more likely, it will drop the revs back 10% so if you are maxed out now at say 8000revs, it should knock them back to 7,200rpm, for the same speed... provided theres enough power THERE to go that fast. More likely, you'll knock the revs back a couple of hundred rpm, to say 7,600, and maybe gain 1-2mph......
No HUGE difference, really, is it?!
Make a bigger change, and the fundementals are the same, Speed=Power / force, so upping the gearing REALLY dramatically, going to say a 17T/26T pairing for +30% ish, would probably NOT get you any more speed, in fact, reducing the engines mechanical advantage like that would be like trying to go up a 1 in 3 hill (Steep!) the whole time, and see you having to use 4th as your main driving gear to get anything like close to your previouse top speed, and with probably as many revs!
BUT, thats the facts of the matter.
First, though, identify the problem. I suspect that if its going faster, then changing the gearing WONT solve it, becouse its NOT a gearing problem, its a simple power problem!
Next, IF armed with the facts about gearing, you still reckon its worth the doing, then go ahead. BUT on a chinese-take-away, you will rpobably struggle to find suitable alternative sproket sizes, but if you can, just upping the gear-box sproket one tooth, probably as much as you want to do, and you shouldn't need to mess with the chain to do it. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| danjameswhitt |
 danjameswhitt Nova Slayer
| pa_broon74 |
 pa_broon74 World Chat Champion
| markrolls88 |
| 0ddball |
 0ddball World Chat Champion
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| N cee thirty |
 N cee thirty Banned
| flumpy7 |
 flumpy7 Could Be A Chat Bot
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 00:15 - 19 Aug 2010 Post subject: |
| flumpy7 wrote: | Bloody hell give the 125's a break, they're meant for pootling around town not moto GP. Get a bigger bike if you wanna do bigger speeds with less gearing. Changing sprockets is not gonna make enough of a difference on that size bike anyway. |
Being fair, 125's are built for LEARNERS and commuters, and if the lads on a provisional licence, he cant legally ride a bigger bike. His 'old' 125 that looked a lot more utiliterian, managed 'national speed limit' velocities, this thing that LOOKs like it ought to be faster, has turned out to be not much quicker than a tuned moped!
If I was a teen-ager and had just handed over £1500 of my money for that thing, and found out it was that dog-slow I'd be a bit pissed myself! Unfortunately THAT is Chinese motorcycles!
https://img2.auto24.ee/auto24/320/225/18423225.jpg
(Though, having googled the thing... err sorry Markrolls, but if I WAS a Know-not-a-lot teenager, having seen how pug-bludy-ugly the thing is, I wouldn't have handed the £1500 over in the first place! I think I would have had to have been frog-marched into the dealers by a large older relative, before signing the HP agreement.... and after riding the thing and discovering it only did 50.... I'd probably let the Repo boys come and get it back! No help I'm afraid... but JEEZ.... looks like some-one had an old CG125, a photo of a GSX600F and the tooling of the old Jailing 65 WWII BMW boxer-copy!)
Anyway, reason its so pug slow (dont think theres an excuse for it being ugly!) to do with manufacturing standards, material grade and quality control, WHY they dont work as well as the Jap or Euro bikes, but basically THAT is why they are so cheap.
And it IS a pisser. Basically you buy a learner-legal motorcycle EXPECTING it to be 'fit-for-purpose', by which you expect it to be capable of passing a motorcycle test on, which IF the dang thing wont do the national-speed limit (60 on main roads, and 70 on duel carriageways) which usually DO form part of the test, and where you ARE expected to reach the posted speed-limit, and demonstrate you can make due progress, the bike obviousely ISN'T. (MAY be grounds to go back to the dealers, IF they sold it to you with L-Plates fitted.... might be an argument you cant win, and I dont know Trading standards would help, but they MIGHT do 'something' for you)
Learner-Legal power limit of 11Kw is specifically designed to be 'just' enough to be able to get a motorbike sized vehicle up to around 70-80mph, IN ORDER that it is capable of coping with the range of speeds of traffic on UK roads.
A) to provide allow the machine to be a 'viable' means of regular transport for a low budget commuter.
B) to allow the unqualified learner rider to experience the range of traffic conditions, including the higher speeds of major arterial roads, AND be able to demonstrate proficiency in those conditions to an examiner.
Give him a chance Flumpy; A 50mph bike just wont cut it, will it! Its not like the lad is looking for ways to 'de-restrict' a CG125 so he can keep up with his mates on ZX6's! He JUST wants the bike to do what it bludy well ought to!
Unfortunately; answer is; it wont. Its a lemmon!
Markrolls, this is why we SO often discourage people fro buying Chinky-Takeaways! They JUST dont cut it, for what WE in the west expect a 'tiddler' to do.
Had the exact same problem with the Snow-Tigeress, my 'other half'. Her hassles with a Chinese built AJS 'Raptor' was what actually brought us together, but thats another story.
Thing was, she bought the 'Cruiser-thing', becouse it was just four years old, Taxed, Tested, a smart ride-away bike, for just £400, after her TZR had been stolen. There was more 'niggles' than JUST it not going more than 55mph, but most of those were due to it being just the 'wrong' bike for her. Cruiser style wasn't really her bag, and the size and shape just didn't 'fit' her, but the 55mph top speed was the ONE critasism to which there was no answer.
She rode it for a year, and it provided pretty good service as a commuter hack, provided she stayed off main-roads and duel carriageways, and lived life in teh slow-lane.
Though I have to say that It wasn't SUCH a bad bike. I think the original sales invoice she got with it declared it had cost a shade over £2K to buy new, in what 2005, so it was one of the more expensive Chinky-bikes, and it was one of the better built ones. Had a derivative of the old Honda CB125T parallel twin engine in it, with a single carburettor, like the CM customs, but where they did 60-65ish, this thing refused to go over the double nickle.
I had a look and a tinker with it, to see if there was any 'obviouse' way of getting a bit more useful power out of the darn thing, and the single Keihn carb looked a likely candidate to be swapped for a pair from an older CB, but after fiddling with the ignition and poking around the cylinder head at the valve clerances, basically came to the conclusion that to make the thing work like a jap bike, would be a case of completely rebuilding the motor and stuffing it with Jap internals; cheaper to buy a jap-motor, easier and cheaper still, flog the thing on and buy a Jap 125!
Except that proved some-what vexing; and no-one wanted to part with sensible money for the thing! I mean, a five year old bike, with 12moths Tax and Test on it, nice shiney and well looked after for £300?
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/100_0067.jpg
Wouldn't sell!
So I suggested we'd hang on to the thing (we didn't have much choice really, no other fucker wanted the damn thing, it seemed!), and she use it JUST as a commuter getting about town.
For her training & test, we figured she'd just have to use a school bike, so she could actually do the excersises set, LIKE get up to 60 on unclassified roads, and 70 on the duel carriageway!
So I sorted out as many of the other niggles as I could for her, and all of a sudden some fcker DID want the damn thing, only they didn't want to hand over ANY money for it, and wheeled it off the drive one night!
None of which is much solace to you, other than there may be a twokker out there daft enough to risk a slap on the wrist from his probation officer, who'll nick the thing for you...... you may like to get a cheap chinese disc-lock to encourage them.... they bend open with little encouragement if the lock actually 'catches' when you push the button in...... (how twoker 'got' the cruiser thing!)
Other than that, you can TRY flogging it on, but, your unlikely to get anything like a sensible sum for it; its now second hand, lacks all the benefits of being a brand-new bike, and has a book value about half what you paid for it, and even THAT depends on you finding some-one mug enough to NOT know these things just dont shift!
Or just 'live' with it as long as you can or HAVE to bear it. save up for a better bike. Do your training, and test on a school bike, and hope that when you have enough dosh together to get something more useful, there will be some-one mug enough to give you a bit of money for it to add to the pot.
You MIGHT go back to the dealer, as said, and 'try it on' with them, that the bike is 'no good' and suggest that its 'not fit for purpose' and that a top speed of 50mph isn't enough to be able to do all thats asked of you on test and get a licence, and you might try and get trading standards on side, BUT I suspect that its not a strong argument, and they'll argue that 11bhp is the 'limit' for a learner legal bike, not a specification.... But who knows, old addage goes that you oil the squeeky hinge first, make enough fuss as a disgruntled customer, they may offer you 'something' to shut you up, even if its only a free service!
Physically, I doubt that there is MUCH you could do to make the thing tolerably faster. Certainly nothing quick, easy and simple, though servicing it so you dont loose what little performance it has would be good.
Motor-wise, I suspect that many of these things have pretty poor cams in them, and thats where the main restriction lies. They will have been made, moset likely out of lower grade, steel, on 'old' tooling, and the cams just wont have as much valve lift on them as Jap parts. Likely they are deliberately softer profile to compensate for low grade steel in the valves and valve springs, so they dont wear out or break. So hotting one up a bit, would be a case of at least tearing the head off, if not pulling the whole motor apart. Doing some old fasioned cylinder head porting, skimming the head to get higher compression, then putting it back together with a new cam, or the original cam 'sprayed up' and re-profiled by a UK tuner, with all new valve train, valves and springs, so it stands some chance of surviving, THEN looking at the ignition and carburation......
You are talking some seriouse money to do that though..... and for where you are at, money the bike just doesn't deserve! Better off saving that towards something bigger and better, post test, while you suffer this thing, with the flaws it has, including the 50mph top speed...
Not nice news, definitely a bitter pill to swallow, BUT unfortunately, you have made a pretty BAD mistake, choosing that bike. So having bought a lemon, make lemonade, get what use you can out of it, and learn from the experience! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Frost |
| markrolls88 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 13:02 - 19 Aug 2010 Post subject: |
| markrolls88 wrote: | i got it second hand with less than a thousand miles on the clock for 400 quid |
Thought you said somewhere it was 'new' & cost £1,500?!?
Oh well, you didn't.... I'm just loosing my marbles!
So £400 & 1000 miles on the clock......
Ah Well, at least you haven't had to take the £1,100 'hit' on the original purchase price!
But now you know why it was such a 'bargain'!
Pretty much the same conclusion though; not worth chucking any money at to make it any more useful; get your money's worth from it putting what miles you can on it, suffering the lowly top speed, save your pennies to use swchool bike to do training & test on..... get big bike whern qualified, and ritcher in experience and pennies! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| markrolls88 |
| Frost |
 Posted: 01:00 - 20 Aug 2010 Post subject: |
The 400's are all old, abused, expensive for what they are and in high demand. People (usually young ones) want sports bikes as they look cool and go faster, so they have got to be good in every way, right? Not always. Truth is they aren't what most people expect, they are unfomfortable, a pain in the arse to ride at times, difficult to work on, a target for theaves, a good way to attract police attention, fast enough to cost you your licence in a heartbeat, and cost a fortune when dropped.
I'm not saying don't get one, i'm just saying there are other bikes out there that won't cost a fortune to insure, might be a better choice for your only mode of transport. Getting a non sports can still be cool and fun (cruiser, supermoto, naked, retro, whatever), have fewer draw backs, more beginner friendly power wise and give you more choice.
So if your hearts set on a sports bike, go for it. If not, have a look around and try not to base it 100% off looks like most people seem to. Try sitting on a few bikes at a dealers and see what you think about the size, weight, seating position etc.
In terms of specific bikes: Bandit, CB500, diversion, er6, hornet are all great all rounders that will be sure to please until you decide what exactly you want out of your next bike. |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 01:42 - 20 Aug 2010 Post subject: |
Pretty much of a mind with Frosty on that question.
I'm NOT a sports-bike fan, to begin with, and I DONT think that they are a great tool for a newly qualified rider, in any capacity.
they are just to compromised for speed & style.
The 'conventional' bikes work a lot better, as a road-bike and every-day machine, and TENT to be an AWFUL lot less hassle and expense to run.
My 'eldest' is the typical 'wont-listen' hot-head, and after I got him a C50 at 16, has gone through a succession of bikes between 125 cc and now 900, that suit his sense of 'style' and aspirations of 'performance', but unfortunately NOT his bank-balence or ability, that he has variousely, blown up, thrashed to oblivion, crashed or simply had laid up waiting his Student loan to come through so he can either get it fixed, MOT'd or Insured, or as often as not, all three!
As a young rider, on a budget, as your sole and every-day means of transport....
I HAVE to say, that being BORING pays!
Something like a CB500 is NOT glamourouse; it is NOT fast, and it is about as exiting as a wet weekend in Grimsby, with your best mates glamourouse girlfrends Fat ugly sister for company!
BUT, a wet week-end in Grimsby, with a real life, wet, willing woman, no matter HOW fat and ugly, is a LOT more entertaining than a sunny bank-holiday in Skegness, with a wallet emptied by a fit-blonde who has just dumped you, becouse you cant afford another drink..... let alone the petrol to get home!
Also, fat ugly girl that goes all the way, tends to be more satisfying than fit-blond that wont.....
Which is a pretty reasonable analogy of what riding a 33bhp restricted sports 600 is like..... you just KNOW it has SOOOO much more to offer, but you aren't allowed to do more than fiddle with the bra-straps!
somewhere in the middle though lies a compromise; and its called a GPz500S, or an SV650.
Both 'sporty' twins; GPz has already been lauded, and I have to say they are a good little bike, with teh attraction fo a lower price tag than an SV, and lower tax and insurance, being smaller capacity. BUT older, and oft abused by LOTS of post learner loons; they CAN give grief. But then can ANY older and cheaper bike.
But that would be my starting point, & a GPz was the only time Hot-Head eldest kept things together for any length of time!
four years of hot-headed-ness, he eventually listened to reason and got rid of the nail of a CBR6 he had completely failed to get on the road, but STILL managed to crash, and 'encouraged' to get a 'sensible' bike, got a GPz5S from a dealer, on 12months finance!
fourteen months later, it was incredibly still alive, despite his best efforts to kill it through neglect and abuse, though a timely MOT half way through helped! when the restriction lapsed on his licence and he lost his head again and traded it in for a 'cheap' RF900, that only needed 'a bit of tarting up'... it never got, being ridden into the ground, and crashed (frequently!), layed up whenever the direct Debit for the insurance bounced, or something critical, like the exhaust fell off or a spark-plug popped out the head..... and he was back to his 'usual' self, moping about grumbling he had to CYCLE to Uni on a push-bike or WALK to the train station to go see his girl-freind, and moaning that he'd be in the bad-books with HER becouse he was broke and couldn't take her out as promiced......
ANYWAY...... thats all pretty much irrelevent, other than to illustrate the ideas, about being a BIT concervative in your first 'big' bike.... and why playing it safe and boring CAN be more fun!
MEANWHILE, you have a test to get passed, before you need worry about such things! So put your attensions into that one, for now. See what the state of things is after you have the licence in your back pocket. To save the pennies for a 'decent' enough Big-Bike, you MAY have to suffer it a while longer after you have lost the L's... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 02:04 - 20 Aug 2010 Post subject: |
thought just crossed my mind; thinking big-bikes / small bikes, costs and practicality & 'stuff'.
THIS is my 'little baby':-
https://i178.photobucket.com/albums/w269/teflons-torque/XX-Forum%20Posts/DT125.jpg
Thirty something years old, and looking like a nail, its waiting for a little attension to get it streetable. But when done, it will probably not LOOK a lot better, but it will be very mechanically sound and a very useful little tool for hooning about town and down the tracks and trails and back-lanes; and it will have cost me under £500 to put it there, and be cheap as chips to keep it there!
On a restricted licence, dirt bikes make a lot of sense, and CAN be a LOT more fun than a 'boring' commuter or 'sporty' twin.... ANd a lot cheaper to run, especially if you go for a smaller one.
Designed to be thrashed and crashed, they tend to be a lot more rugged than road-bikes, and can take a LOT of abuse.
And steeping OUT of the fast lane, or by-passing it all together; you can get some pretty big adrenaline kicks knocking about on the loose-stuff..... 30mph on the road, is seriousely pedestrian, but 30mph on the rough, the bike bucking beneath you, FEELS so much more exiting, like the sort of thrill you wouldn't get trying to get your knee down on a twisty lane tackled at WELL over the national speed limit!
Old Honda 650 'dominator' is a pretty useful and under rated dirt-donk.
https://images03.olx.ca/ui/1/34/52/8143252_1.jpg
Unloved these days as its 'old hat', and the XR is 'so much better', BUT as an every day bike? Has a LOT going for it, most especially the price tags; you can get a pretty good one for around £750, ready to ride.
650cc it IS a 'big-bike'. doesn't need much restricting to make 33bhp complient, and you can pretty much exploit what performance it has, on road or on dirt, where you CAN get the sort of thrills a restricted road-bike wont deliver.
On road, big enough and comfortable enough to tackle longer hauls, great round town, really manouverable, and easy to manage.
But seriousely cheap to run, and keep on the road, curtecy of low-tech, low stress single pot motor, and designed to be dropped, would take a pretty seriouse desaaster to see it really dent your wallet should you come a cropper.
I know sports-bikes are what ring your bell..... BUT thought I'd just chuck up some food for thought.
If, on a restricted licence and budget, you would struggle to get all you hope for out of a 'big-bike', and sitting it out on a compromise, frustrating, THIS kind of thing (dont HAVE to be an old DT or Domminator) can give you all the benefits of the 'compromise bike' and some 'thrills' to at least vent your frustrations in substitute for a pure sprots-bike until you are off restriction and beyone that, have the budget to achieve your aspirations, rather than fuel your frustrations! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Digitalize |
 Digitalize Nearly there...
| markrolls88 |
The last post was made 16 years, 23 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.33 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 169.99 Kb
