Whining noise
Chalky.
PostPosted: 10:09 - 18 Aug 2010    Post subject: Whining noise Reply with quote
Rode to work this morning and noticed a whining noise from the bike.
It's just had a new chain, related?
I'm thinking wheel bearing?
Any thoughts? Couldn't tell if it was front or rear.
95 cbr600
cheers
doggone
PostPosted: 10:21 - 18 Aug 2010    Post subject: Reply with quote
I wouldn't expect a whining noise from a bearing, but if you've had the wheel out this is likely the source somehwhere.
Chain definitely not too tight? - check when you are on it as it tightens when the suspension goes down (I lay over the bike which looks funny but works).
Is it possible to overtighten the spindle? Neutral
Chalky.
PostPosted: 11:31 - 18 Aug 2010    Post subject: Reply with quote
Hmm not quite sure.
Got a long ride planned on Friday... Confused
DrDonnyBrago
PostPosted: 11:39 - 18 Aug 2010    Post subject: Reply with quote
CBRs often have whiney clutch baskets, where is the noise coming from?
Just when moving or when revving in neutral/clutch pulled in as well?
Chalky.
PostPosted: 11:40 - 18 Aug 2010    Post subject: Reply with quote
It was all the time whilst moving mate, clutch in or not
dextersaurus
PostPosted: 11:50 - 18 Aug 2010    Post subject: Reply with quote
Maybe it's the turbo? Wink
Uhh, whining noise could be a lot of things....
It could be the cooling fan bearing on it's way out... Does it do it when cold?
Also try the rear sprocket carrier... No more than a tenner to replace, and known for making all sorts of wierd noises.
Whining while moving sounds like a dry bearing to me.
Dunc
hmmmnz
PostPosted: 14:27 - 18 Aug 2010    Post subject: Reply with quote
tell your mrs to get off the bike, that should sort it
the humans are dead
I kick arse for the lord
Skudd
PostPosted: 15:32 - 18 Aug 2010    Post subject: Re: Whining noise Reply with quote
It wasn't made in Pakistan was it? Rolling Eyes Laughing
Frost
PostPosted: 16:58 - 18 Aug 2010    Post subject: Re: Whining noise Reply with quote
You sure thats not the misses on the back?
Amreet
PostPosted: 17:05 - 18 Aug 2010    Post subject: Reply with quote
how tightly have you got the chain? In noticed a whining noise coming from the rear end after adjusting the chain on my bike a while ago, slackened off a TINY bit more and it was gone soyou could try slackening your chain a touch and see if that helps?
Chalky.
PostPosted: 19:33 - 18 Aug 2010    Post subject: Reply with quote
It wasn't the missus but I did try curing it by treating the situation the same... punching the bike didn't work.
Does it any temperature.
It's as it was Chris, it's noticable enough that I don't think it's the wax.
Will try slackening off the chain slightly, but it seems to be about right.
Thanks for your help people.
Chalky.
PostPosted: 22:45 - 18 Aug 2010    Post subject: Reply with quote
Chain did nothing.
I'm pretty sure it's coming from the front wheel
Chalky.
PostPosted: 23:06 - 18 Aug 2010    Post subject: Reply with quote
Defo whining
Only noticable at 40+, increases in noise as speed increases.
Noise when front brake applied fully, 1/2 and not at all doesn't change (except for the speed change of the bike)
Chalky.
PostPosted: 23:13 - 18 Aug 2010    Post subject: Reply with quote
Doesn't make a difference, can hear the noise more though dur to the engine revs dropping
c_dug
PostPosted: 23:56 - 18 Aug 2010    Post subject: Reply with quote
This may sound stupid but are you sure its not a cable rubbing on the front wheel?
It's coming from the front and it's louder (Probably just easier to hear) when the revs have dropped off.
DrDonnyBrago
PostPosted: 08:03 - 19 Aug 2010    Post subject: Reply with quote
Dude... The avatar... Goatse Sick Sick Sick Sick
c_dug
PostPosted: 11:53 - 19 Aug 2010    Post subject: Reply with quote
I did attempt to make it safe for work Laughing
The last post was made 16 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 88.81 Kb
