Starter motor for nsr!
taylornsr
PostPosted: 19:08 - 20 Aug 2010    Post subject: Starter motor for nsr! Reply with quote
Hi guys, i've got a problem with the starter motor on my bike and need it replaced. I've found a couple available online but they're all from older models of the bike like 93 nsr 125R-K.
I wonder if anyone can tell me if this starter motor will fit my 2000 RR model?
And before anyone asks i'm sure it's the starter motor as i've replaced the battery and starter relay and have taken the starter motor apart and its defo dead!
taylornsr
PostPosted: 19:11 - 20 Aug 2010    Post subject: Reply with quote
ps. i didn't mention but my bike is a honda nsr 125 yr2000!
alains
PostPosted: 18:56 - 21 Aug 2010    Post subject: Reply with quote
all starters are the same . instead of spending £60+ to change your starter why dont you repair it . 99% of the time it's a brushers & spring problem or a clogged comutator on the rotor
download my file https://www.geneva-racing.ch/~alains/NSRtips.doc
and look starter maintenance bottom page 9
you need :
- 1 set of brushers 32101KY4901
- 2 springs 31204KG8004
- 1 Oring 31309KG8004
cost peanuts hhtp://www.davidcilverspares.co.uk
skatefreak
PostPosted: 07:56 - 22 Aug 2010    Post subject: Reply with quote
I will second that,
The starter on my 2001 NSR125 seemed pretty foo-bar, went through alains doc and used the manual for reference and it was pretty straight forward.
What exactly did you find when you took the starter appart?
Best regards
-Jvr
taylornsr
PostPosted: 11:27 - 22 Aug 2010    Post subject: Reply with quote
Cheers for the advice, i'll have another look at the starter and see what i can do with it with it with these links
Stowelly
PostPosted: 13:03 - 22 Aug 2010    Post subject: Reply with quote
managed to fix my starter with nothing more than the spring from a pen cut in half Razz
alains
PostPosted: 18:17 - 22 Aug 2010    Post subject: Reply with quote
how long it will stay and mind the disaster which is hanged over your head Rolling Eyes
Stowelly
PostPosted: 21:53 - 22 Aug 2010    Post subject: Reply with quote
true true, but the spring was stronger than the stock one, and the brushes have a lot of life left in them, not too much can be bad about a spring!!
alains
PostPosted: 08:27 - 23 Aug 2010    Post subject: Reply with quote
if spring is too hard you will dig you comutator , then the starter is worn !!
The last post was made 16 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 58.06 Kb
