How thick are brake discs
Ingah
PostPosted: 03:04 - 21 Aug 2010    Post subject: How thick are brake discs Reply with quote
I just wondered if anyone happens to know or have a good estimate of how thick brake discs are when they're new and unused (if it helps, it's for the single front disc of my CB500).
I know that the minimum thickness (for my CB500) is 4mm, and i'm trying to work out if it's worth buying a used 5mm disc to replace my slightly-warped-probably-at-the-wear-limit one, or whether that would be wasting cash that could be going towards a new/newer one.
-- Ingah
rodeobob
PostPosted: 05:40 - 21 Aug 2010    Post subject: Reply with quote
Not sure about in the UK but here in Aust the brake disc is meant to have the minimum thickness stamped on it. If it does not it is not for road use.
You can look up anything you need to know here.
https://www.metalgear.com.au/
Cheers, Bob.
DT200R '91
DT175 '91
Various IT/DT175 engines for 'projects'
Robby
Dirty Old Man
PostPosted: 08:28 - 21 Aug 2010    Post subject: Reply with quote
I would worry less about the thickness and more about the nature of the wear and level of warping.
You should be able to tell how worn it is by the depth of the wear lip - the pads never fully cover the face of the disc, so you get a raised lip around the inside and/or outside. Compare this with the thickness in the middle for an idea of wear. Scoring is bad too, once a disc is score or ridged it'll never wear flat again.
I would go with the used disc. New ones are very expensive, used ones are cheap. Some people have had success machining car disc to go on bikes. Given the price of car discs and the price of decent machining this seems to make sense.
A new disc is £90+. A car disc in a suitable diameter will be £20 or less. I just paid 80 quid for an engineer to do a hell of a lot of work on a cylinder, so machining a disc down should be cheaper.
May work out even cheaper to buy a wheel with a disc and used tyre on ebay. Then you have a wheel and used tyre to sell and recoup some cost.
rodeobob
PostPosted: 08:54 - 21 Aug 2010    Post subject: Reply with quote
Sorry but i beg to differ.
It is all about the thickness.
If the disc wears too thin and the pads wear right down, the pads can fly out and trash your whole world. Seen the aftermath of this on a KX250. Ruined the caliper the disc and the rider.
Second, never ever machine up any car disc for a motor bike. They are made out of different grade steel. Car discs can be big and heavy and are made out of far crapper grade of steel. Machining them down below their stated minimum thickness weakens them considerably. Very very bad idea. Im sure the machinist would tell you so.
Hence your 70 quid difference.
Car discs are cast, very few motorbike discs are and if they are its highly likely that its a totally different grade of material.
If you are fitting a new disc fit new pads as well.
Sure they are expensive, both good pads and discs. But would you like nice brakes that stop you reliably, or would you rather crash into stuff and fall off all the time???
Cheers, Bob.
DT200R '91
DT175 '91
PostPosted: 09:05 - 21 Aug 2010    Post subject: Reply with quote
Cheers, Bob.
That's more about the pads being worn down the the discs. I can't see a thin disc forcing out good pads unless it breaks in which case it must be very cheap or VERY worn.
rodeobob
PostPosted: 09:24 - 21 Aug 2010    Post subject: Reply with quote
If i remember right im sure some of the old bikes dont have pins.
Not sure what was up with the KX, only one pad came out.
On an old bike with a 6mm+ disc if its allowed to get that worn.
Dont know why you guys are picking points.
The point im trying to make is, cut corners and you die.
Need a better reason to do it right???
Bob.
DT200R '91
DT175 '91
Robby
Dirty Old Man
PostPosted: 09:31 - 21 Aug 2010    Post subject: Reply with quote
Or you use the back brake on the extremely rare occasion that the front fails.
It is possible to spit out a pad, but only on certain types of caliper that don't use a retaining pin and only then if the caliper is damaged or the retaining clips haven't been used or are damaged. You would also need to have the pads worn down to the metal.
I agree that the best long-term solution is a decent new brake disc, but seeing as you can buy 5 part worns for the price of one new one its worth saving money. Also, on my bike new discs aren't available so to use new discs I would need to use one from a different model, meaning lots of messing around with different calipers and caliper brackets to make it work.
PostPosted: 09:59 - 21 Aug 2010    Post subject: Reply with quote
Bob.
And what I am trying to say is I can't see a thin disc kicking pads out of you caliper.
Willson
PostPosted: 10:43 - 21 Aug 2010    Post subject: Reply with quote
I agree with Bob, don't skimp on your brakes.
Buy a decent disc it will pay you dividends, instead of buying second hand discs etc, and finding you've got to replace them once a month, or worse.
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
rodeobob
PostPosted: 11:17 - 21 Aug 2010    Post subject: Reply with quote
Definately not a comment that an experienced bike rider would make.
Whats your bike???
5 part worn could give you 3 useable ones too, thats my experience.
Might be different where you come from but the places here that do bike Roadworthys so you can register your bike have verniers not with parallel jaws but with pins on the end, they can get in over the 'lip' on the disc and into say a nice groove thats worn in the disc.
You cant see this in the picture on the eBay listing. What some Gumby eBay seller lists up as OK and what truns up in the mail are usually two different things.
Bob.
DT200R '91
DT175 '91
Paxovasa
PostPosted: 11:20 - 21 Aug 2010    Post subject: Reply with quote
I know that brake pads have to have a minimum of 3mm on them for a MOT.
Does anyone know what the limit is for discs?
rodeobob
PostPosted: 11:26 - 21 Aug 2010    Post subject: Reply with quote
Varies from wheel to wheel, bike to bike.
Use the link above, it lists the full specs for heaps and heaps of bikes, specs include std and min thickness.
Bob.
DT200R '91
DT175 '91
Paxovasa
PostPosted: 11:32 - 21 Aug 2010    Post subject: Reply with quote
Bob.
Thanks Bob.
But that is for Australia, I want to know what the legal wear limit for an MOT is in the UK Thumbs Up
Teflon-Mike
tl;dr
PostPosted: 11:43 - 21 Aug 2010    Post subject: Re: How thick are brake discs Reply with quote
I think the disc is probably the same part no as the ones on my CB750. Wear limit is 4mm on the rubbing face, think the disc starts life about 8mm thick.
I wouldn't bother with a second hand disc on the front [full-stop]
Old guideline was 75% font 25% back, shifting to more front in good conditions.
with most braking coming from the front end, and only ONE disc up there, make it best you can.
Know they are expensive, but, not worth skimping on THAT particular component.
On the back, where not AS critical, and the discs are often more expensive than the fronts (wereon my CB!) using a 2nd hand disc, as long as it DOES have plenty of meat still on it, probably an OK compromise.
But, down to 5mm, on an 8mm disc with 4mm wear limit, that's 75% worn out... new disc = £80 so its only got 1/4 of the life left in it, so just on simple maths, its's NOT worth more than £20, and when you consider warranty on new disc, confidence its true and never been distorted, probably not even THAT...... so you'd have to be PRETTY desperate or virtualy given a disc that thin to think it worth using, wouldn't you?
Also, woth noting that when worn discs get measured, you'll put a caliper accross teh rubbed area and measure how far apart the jaws are.... thats NOT the disc thickness. disc will have been grooved where its bedded to the pads, and those groves can be as deem as 0.25mm or more, on both sides of the disc, even if its not badlt scored, so if it measured 5mm between the peaks of the faces, may be as thin as 4.5mm 'nominal' thickness if you could average out the depth of the grooving........
As for machining down car discs?!?! Lot of curiouse advice there!
NO! Car discs are cast iron, bike discs stainless steel. You can get cast bike discs; old Guzzi's & BMW's used to use Brembo's. They were bloonin thick, and had wider jaw calipers on them. Worked damn well, compared to stainless discs, but they wore faster and they go rusty, and dont look very good.
Also pad material for cast brakes is a lot different to stainless. Use a cast disc with pads designed to run on stainless, they'll probable over-heat and get chewed out n moments. Other way round, they probably just wont bite!
Milling down a cast disc to the thickness of a stainless one so you can fit it in a stock caliper is a VERY bad idea. Disc just wont have the meat in it to dissapate the heat generated, and it will warp an awful lot more easily, worse possibly crack, as the metal is more brittle.
When people talk about machining discs down; IF you know what you are doing, all things are possible, and I know of people that HAVE milled down cast or stainles discs in DIAMETER, not thickness, to suit alternative applications; (Old TZ's with 'little' rotors, being one) but fitted with teh correct caliper for the disc.
More often though when people get discs machines, its 'skimming' a mildly warped or scored disc, to give it a new face, PROVIDED the machining hasn't seen it thinner than wear limit.
rodeobob
PostPosted: 11:45 - 21 Aug 2010    Post subject: Reply with quote
Thats is for everywhere.
A 2009 model Vauxhall does not have the same min thickness for a disc as a 70's Escort.
Same as cars, bike disc thicknesses are all over the shop.
The bike manufacturer states what the min thickness is. So a workshop manual will tell you. So will that site, well if your bike is listed. They make discs for all sorts of bikes, quite a few were never even sold in Australia, info is based on manufacturer specs.
Bob.
DT200R '91
DT175 '91
Paxovasa
PostPosted: 11:51 - 21 Aug 2010    Post subject: Reply with quote
OK Bob,
My Suzuki GSF600 K3 (2003), what is the wear limit?
rodeobob
PostPosted: 12:06 - 21 Aug 2010    Post subject: Reply with quote
A 600 bandit.
Look it up yourself.
The link is there.
Bob.
DT200R '91
DT175 '91
Paxovasa
PostPosted: 12:14 - 21 Aug 2010    Post subject: Reply with quote
rodeobob wrote:
A 600 bandit.
The link is there.
Bob.
I looked it up, but it does not tell me what the wear limit is Thumbs Up
m0l0t0v
PostPosted: 12:32 - 21 Aug 2010    Post subject: Reply with quote
If an "experienced" bike rider is experiencing front brake failure often then I want to know what this experience is and if he is off the road and stopped working on bikes.
rodeobob
PostPosted: 15:37 - 21 Aug 2010    Post subject: Reply with quote
Wanna try again there m0l0t0v, sorry i read it a few times but i cant make sense of it.
I gather you are saying that an experienced bike rider wouldnt be having front brake failure because he would be sorting things out before the got that far.
Paxovasa, Wear limit would be the minimum thickness wouldnt it???
Bob.
DT200R '91
DT175 '91
m0l0t0v
PostPosted: 15:42 - 21 Aug 2010    Post subject: Reply with quote
How often do the front brakes fail? Hardly ever. A huge number of members on this forum and I can only think of one instance where the front brakes failed. It's very rare.
You're saying an experienced rider wouldn't agree. So by that logic an experienced rider has several front brake failures. Not because he would be sorting them out, rather did he create the problems that created the failures?
PostPosted: 15:54 - 21 Aug 2010    Post subject: Reply with quote
Most discs have the minimum thickness stamped in them. If they are on or below that then there's an increased risk of warping or even complete failure. The mass isn't there to soak up the energy from braking causing the disc to over-heat.
Put simply if your used disc is appreciably above it's wear-limit (minimum thickness) and not warped there's no reason why you can't use it.
I never heard of anyone machining a cast-iron car disc to fit a bike but that doesn't automatically make it a dangerous exercise. That would have to be decided on a case-by-case merit.
rodeobob
PostPosted: 16:43 - 21 Aug 2010    Post subject: Reply with quote
m0l0t0v, whats your point???
Are you just trying to make argument for the sake of making argument. You are still not making much sense im afraid. Maybe im too dumb. Quote something or whatever, im not following you.
Theres only one way to fix a bike, thats the right way.
As far as the comment about the use the rear brake comment that Robby made. Front brake failures are extreemly rare, that is true. And in that instance you have no other option other than to use the rear brake. 99.9% of the time that will result in an accident as with the panic the rear weel will lock, most of the time you'd run out of braking room as you were braking for a reason and the rear brake is at best only about 20% efficent and with the back wheel locked the rear would slide out and you would have a big crash, or maybe a small low side.
Perhaps i was taken out of context, not trying to victimise Robby for his comment, but i was more getting at the fact that with his brake solution he offered up, he would more likely than not be experiencing such and accident for the sake of 70 quid. I got the impression that he was expressing that this would be a fine out come, save 70 quid and have a front brake failure.
I dissagree.
Bob.
DT200R '91
DT175 '91
PostPosted: 17:02 - 21 Aug 2010    Post subject: Reply with quote
I think you ought to give a little more credit to the general motorcycling populace. Most riders who knew they were limping home with a failed front brake would decrease their speed, increase stopping distances and pre-empt other's maneuvers accordingly and actually arrive home safe.
Ingah
PostPosted: 17:13 - 21 Aug 2010    Post subject: Reply with quote
Seem to have sparked a little debate here...
So on reading through, to summarise what i've taken from it all...:
* As i don't know what i'm doing with brake discs, stick to the correct bike discs. NP, i'm not one of those people that feels safe trying to get someone to bodge me a replacement anyway.
* Scoring / warping / thickness / size of the lip, are all important factors when buying a used disc.
* That 5mm thickness disc is probably not going to have much life left in it. So i'm probably best to look for another one instead.
* It'd probably be wise to fit the new pads i require at the same time as the new (used) disc. When i can get ahold of one.
* If my front disc fails i'm probably dead, because my rear drum brake is absolutely rubbish.
The problem is that new OEM disc is £110. TBH, i can't nearly afford it yet - because i've spent too much money on OEM components when i could've been saving it elsewhere. So i'll just end up leaving it for now and be on the lookout for a good used disc. I now understand that a new disc would be a safer bet, but sometimes you just can't afford a new one there and then. And if i leave it until i can, i'm more likely to come a-cropper.
I didn't understand that site either:
Part No 20.028
Description MGear Brake Disc - Solid
Fitment Front right
OD Ø mm ID Ø mm BHC Ø mm No of BH BH Ø TH min. TH Offset
296 144 166 6 10.5 5 4 0
What does all these unexplained abbrevations mean? (i guess TH min. is obvious as it matches the 4mm i'm aware of.. but the rest is gobbledegook to me).
-- Ingah
The last post was made 16 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 143.73 Kb
