Need info about restricting a bike
Mr White
PostPosted: 09:41 - 21 Aug 2010    Post subject: Need info about restricting a bike Reply with quote
I am only 20 years old and I am planning to buy a Hyosung GT650R or Suzuki SV650. Thus whatever I buy I will have to get restricted down to 33bhp.
I have seen some restriction kits(washers) for SV650 on ebay, for £30.
However the only GT650R restriction kits I could find are the ones on FI international website and cost £200.
There is £170 difference, hence my next question Mr. Green
GT650and SV650 have not the same but similiar engines. (GT650 has 10bhp more)
However they have the same carbs.
If I fit a SV restrictor kit on a GTR will it produce 33 or 43ish bhp (as it has 10 bhp more as standard).
Can this be further corrected with a smaller jet and a smaller hole in the air box?
Assasination of the leadership of Poland, shots fired at survivers of the plane crash.
https://www.youtube.com/watch?v=FEx7HL4H5yk&feature=player_embedded WATCH IN 480P RESOLUTION TO SEE ALL THE DETAILS
woll
PostPosted: 10:27 - 21 Aug 2010    Post subject: Reply with quote
I think the sv650 are restricted by the ecu, so i'm not sure if it will work. Just don't restrict it Laughing
ram_doom
PostPosted: 11:40 - 21 Aug 2010    Post subject: Reply with quote
If your sv/hyosung is carbed, nicky-jano on here has some 33bhp restrictors going cheap Razz
TL1000s, KDX200
PostPosted: 12:04 - 21 Aug 2010    Post subject: Reply with quote
For an injected SV it can be restricted by the ECU yes. But it can also be restricted with washers, and the carbed one has to be restricted with washers.
woll
PostPosted: 12:31 - 21 Aug 2010    Post subject: Reply with quote
Ah i see, learn something new everyday Thumbs Up
Devans
PostPosted: 12:36 - 21 Aug 2010    Post subject: Reply with quote
My mates SV 650 04 plate has washers an a throttle stop.
m0l0t0v
PostPosted: 12:38 - 21 Aug 2010    Post subject: Reply with quote
I've seen a few carb'd Hornets restricted by washers AND CDI... Have to remove both, if you leave the CDI chances are it wont rev past 5-6k or so.
Paulington
PostPosted: 13:00 - 21 Aug 2010    Post subject: Reply with quote
My SV650 is a washer in the inlet manifold and a throttle stop. Thumbs Down!
Mr White
PostPosted: 13:35 - 21 Aug 2010    Post subject: Reply with quote
Im looking at quite old 99-00 SV650
m0l0t0v
PostPosted: 14:25 - 21 Aug 2010    Post subject: Reply with quote
BLUEX5 wrote:
That'll be quick then Laughing
I thought that was a mod to make it faster/more exciting? Thinking
radical
PostPosted: 16:07 - 21 Aug 2010    Post subject: Reply with quote
Op, I dont think the GTR has carbs althought the earlier models did, I havent had to restrict a bike before but surely a bike could be restricted by simply backing of the throttle cables which would prevent the bike making its maximum power or is there a lot of paperwork needed to confirm the horsepower limit?
Scythe
PostPosted: 16:44 - 21 Aug 2010    Post subject: Reply with quote
Where? Need some myself for an 2001 SV
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
PostPosted: 17:32 - 21 Aug 2010    Post subject: Reply with quote
Suspect that using SV restrictors would give you within a gnats of 33hp. However if it uses a throttle stop as well as the washers then probably a bit different, and a cdi swap would probably be impossible.
No paperwork required at all, but to lose ~40hp you would only need a tiny bit of throttle travel left, which would mean running the cables very slack.
Mr White
PostPosted: 17:39 - 21 Aug 2010    Post subject: Reply with quote
07 GT650R I was looking at had carbs
ThoughtContro...
PostPosted: 18:05 - 21 Aug 2010    Post subject: Reply with quote
The 99-02 "curvy" models are the carbed ones. In addition to washer restriction kits there are official Suzuki restriction kits for them (Suzuki part no. 13501-20F50). This is a replacement carb piston, you'd need two. It's shown in this link
https://www.sv650.org/sv_faq.htm#How_to_de-restrict_a_Mk1_SV_
https://www.sv650.org/derestriction/derestrict_SV650K2_step12.jpg
The restricted item is the top one in the pic, note the small hole.
You could probably find both types of restrictor on ebay fairly frequently or ask on the forum at sv650.org
The Hyosung looks a nicer bike, especially in red. Parts are likely to be more expensive and harder to source cheaper parts second hand.
The SV is more common, parts are easily available second hand, so if the worst comes to the worst you probably wont have to wait too long or spend too much money on repairs. If you are restricting then you wont be using any extra power available in the Hyosung, unless the restrictors accidentally fall out Mr. Green
You'll probably curse the SV when you try to change the front spark plug tho
Prize cunt
Paulington
PostPosted: 20:47 - 21 Aug 2010    Post subject: Reply with quote
Whilst it will touch 100-110mph indicated (so a real 90-102mph or so), it gets there like a fudgin' snail. Laughing!
The last post was made 16 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 103.52 Kb
