How to check for a short circuit?
Dannyenglishb...
PostPosted: 10:33 - 21 Aug 2010    Post subject: How to check for a short circuit? Reply with quote
Any help please? Aprieciate it .
doggone
PostPosted: 10:39 - 21 Aug 2010    Post subject: Reply with quote
Blown fuses, smelly smoke?
Try disconnecting things, remove all fuses and put them in one by one until problem occurs.
Need more info.
Dannyenglishb...
PostPosted: 12:26 - 21 Aug 2010    Post subject: Reply with quote
basically whats happened this week is ive charge the battery 2 days ago disconected from the bike, then its went dead over night, ive been bumping it and its charging by the alternator it will still start after a hour or so after its been running, this mornin it was dead, i tryed charging it wen the battery is connected to the bike and it wudnt charge had it on for a hour and half so shud of started, so i bumped it and rode it for a bit and now its got charge but obviously its gna die in bout a hour.
and i cant even get it into a garage till monday because the guy who owns it is off this weekend.
This is probably a noob question but the wire that stops ur bike starting wen the stand is down is disconnected would that be doing anything?
Help is appreciated.
Paxovasa
PostPosted: 12:53 - 21 Aug 2010    Post subject: Reply with quote
Side stand switch will not cause the battery to be drained Thumbs Up
Do you have heated grips fitted?
Dannyenglishb...
PostPosted: 13:09 - 21 Aug 2010    Post subject: Reply with quote
Oh right, Na i aint got heated grips mate.
Paxovasa
PostPosted: 13:17 - 21 Aug 2010    Post subject: Reply with quote
How old is the bike?
It may just be a case that the battery has come to the end of its life Thumbs Up
Dannyenglishb...
PostPosted: 13:24 - 21 Aug 2010    Post subject: Reply with quote
07, i bought a brand new battery 2 weeks ago and it did exactly the same thing ,, then that new battery died completely wudnt charge even disconected from the bike ,, now its got the old battery on wich charges wen its disconnected from the bike but not wen on the bike but its charging wen its actually running. so tbh i dont think its the battery myself. a few people ave been saying short circuit but i am a pure noob to fixing bikes.
Paxovasa
PostPosted: 13:29 - 21 Aug 2010    Post subject: Reply with quote
Is there an alarm fitted to the bike?
As something is draining the battery and that is stopping it from been charged when it is connected to the bike.
Dannyenglishb...
PostPosted: 13:34 - 21 Aug 2010    Post subject: Reply with quote
no alarm on it Neutral
2E
PostPosted: 13:42 - 21 Aug 2010    Post subject: Reply with quote
Your charger, is it actually a BIKE battery charger not a car one? as the latter puts out too much ampage and basically warps the battery.
Have you been jumpstarting the bike from a car?
Bringing Classic Bikes Back Into Fashion
Rides: 1980 Honda CX500
Paxovasa
PostPosted: 13:47 - 21 Aug 2010    Post subject: Reply with quote
Jump starting a bike from a car will not harm the bike or battery (unless it runs on a 6v battery) Thumbs Up
Dannyenglishb...
PostPosted: 15:23 - 21 Aug 2010    Post subject: Reply with quote
I hope your right because i have been charging it off a 12 v car battery charger, ive just went and bought a motorbike charger and new battery for 55 quid so i hope you are right. i will let you know what happens.
Paxovasa
PostPosted: 20:30 - 21 Aug 2010    Post subject: Reply with quote
He is right, a car charger will fry your battery as it charges them too quickly Thumbs Up
Dannyenglishb...
PostPosted: 22:16 - 21 Aug 2010    Post subject: Reply with quote
so how does the alternator charge the battery back up ?
Glenben92
PostPosted: 07:53 - 22 Aug 2010    Post subject: Reply with quote
Magnets and coils connected to the spinning engine, like a normal generator would basically, just... smaller as it only needs to generate small amounts of power. I'd check for shorts in the wiring somewhere. Get yourself a multimeter and start going over things. Check for continuity between positive wires and the bike frame (earth point).. there should NOT be continuity. If there is, it's shorting somewhere.
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
Dannyenglishb...
PostPosted: 22:07 - 22 Aug 2010    Post subject: Reply with quote
Right bought new charger + battery , charged it up, took it out, put voltmeter on it , read bout 12,55 wen it stopped going down fast. watched it over next 4 hours and it dropped to 12.47 . so its draining isnt it ? or should it drop to about that? 12.47 is about 80 % battery.
Dannyenglishb...
PostPosted: 20:14 - 25 Aug 2010    Post subject: Reply with quote
thanks alot for the replies guys think its sorted now
Dannyenglishb...
PostPosted: 13:49 - 30 Aug 2010    Post subject: Reply with quote
5 days on with the new battery and charger ,, its dead again now its just died this morning so another 55 pound down the drain. So is it a short circuit?
oldpink
PostPosted: 15:53 - 14 Sep 2010    Post subject: Reply with quote
with everything off
try putting the meter on the positive terminal of the battery / battery lead and onto the engine block
if you get a reading you have a problem, its possible you have a wire or wires shorting
or the insulation has broke down or split and earthing
inspect all of the wires you can see looking for cracks in the plastic shield or any sign of burning
maybe around the headstock as the movement there can wear the insulation away
and leave bare wire
Luke_Retrofly
Silly Lesbian
PostPosted: 16:20 - 14 Sep 2010    Post subject: Reply with quote
https://bloatedpenguin.mikescottlew.com/wp-content/uploads/2009/10/080404shortcircuit.jpg
Flounced - Long overdue
Fuck you bitch I'm in the top 10 list I can do the what the fuck I want!
The last post was made 15 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 102.83 Kb
