no spark
dave36
PostPosted: 22:03 - 21 Aug 2010    Post subject: no spark Reply with quote
right lads have a honda nsr 80 no spark, cdi, coil, rectiver have tried on another bike all work, have checked run button and ignition both ok, tried new plug, checked wiring, at a loss now, any help be great thanks
radical
PostPosted: 22:29 - 21 Aug 2010    Post subject: Reply with quote
Op, run a wire from your negative battery terminal to the engine and attach to any metal part of the engine you can, if the plug sparks then you have a bad earth connection to the engine.
dave36
PostPosted: 08:39 - 22 Aug 2010    Post subject: Reply with quote
have checked all wires, have heard the generator been said before,
will try that with wire today..
dave36
PostPosted: 17:19 - 22 Aug 2010    Post subject: no spark Reply with quote
ran a wire from battery negitive to engine still no spark,
andy_g2k7
PostPosted: 20:34 - 12 Sep 2010    Post subject: Reply with quote
try putting the bike on its centre stand , put it into gear and push the back wheel round and put a tester on the wires coming from the magneto. if you have life there then it must be wiring or a bad earth i had the same problem on a chinese bike my friend owned turned out the magneto needed replacing
nsr's rule
The last post was made 16 years, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 47.6 Kb
