APRILIA RS 125 front end on a TZR 125 (2KR) Possible??? HELP
Stuster
PostPosted: 19:16 - 22 Aug 2010    Post subject: APRILIA RS 125 front end on a TZR 125 (2KR) Possible??? HELP Reply with quote
Hi all.
I am currently building a TZR 125 and am ready to put the chassie back togeather. I have been looking at the wheels on his and they are really a massive let down, as they look like they belong on a push bike haha. I wouldnt mind putting some bigger wheels on like the RS 125. I have found a complete front end for a aprillia RS 125 2008 with the disc calliper speedomiter etc.
I think this would look great on the TZR but was wondering if this would fit? Has anyone out there done anything like this befoure?
Any advice will be great.
Stuart
Yamaha TZR125 x 3 Lifan LF125 14-F x 3 Jinlun 125 x 1 Honda CBR 600 F1 Honda Varadero 125cc I am now starting my Honda VFR400 NC30 Project Smile (Still ongoing 27/02/18) Daelim Roadwin 125R
chris_m2k10
PostPosted: 23:00 - 22 Aug 2010    Post subject: ... Reply with quote
they will fit.
but if u do not want to chance it and go through hastle i would just buy standard tzr wheels.
but yes they will defanitely fit
pits
PostPosted: 10:20 - 23 Aug 2010    Post subject: Reply with quote
I wouldn't of thought so, I may be wrong, but first problem really is going from Honda to Aprilia.
Just a quick look at a TZR front end from a picture, I think the front end looks slightly longer, and the mounting is completely different as the frame is fairly different, and there would be no real well of fixing it, if stuff didn't line up, you can't drill or cut the frame as that would render your bike useless, not sure about making something either.
Aprilia has upside down forks aswell, and just looking at pictures I think you may have tank clearance issues.
But I really don't know, the other question is whether the front tyre would be a good match for the rear tyre size wise and whether or not you could fit the Aprilia rear on, I honestly don't know, would bits of TZR250 not fit better? Is there any difference between 250 parts and the 125?
andysdad
PostPosted: 11:44 - 23 Aug 2010    Post subject: Reply with quote
i have put a cbr 600 f4 front end and rear swingarm onto a chinese tiny wheeled 125. it can be done. just make sure u have a shed to do it in as its a few days work on each end. if u do decide to do it i can help u with it but make sure u have a decent mig welder with gas. mines lasted 6 months with no cracks at the welds so its definately safe and then i sold it. and the wheels were twice the size of originals. ive got a tzr 125 aswell and i am definately putting the rs125 wheels on if not then bigger wheels.
1992 TZR 125
1999 Impreza WRX
Stuster
PostPosted: 15:38 - 23 Aug 2010    Post subject: Reply with quote
Thanks a lot for the advice. I can only try ey haha. I will but the front end an put pics up. If it doent work i am sure i could just use the wheels. Also do you now how to up load pics to this forum?
Thanks again.
Stuart
Stuster
PostPosted: 15:38 - 23 Aug 2010    Post subject: Re: ... Reply with quote
BLUEX5 wrote:
chris_m2k10 wrote:
they will fit.
https://i5.photobucket.com/albums/y164/BLUEX5/Bill.png
Hi. whats with the HAHA pic?
Stuster
PostPosted: 16:08 - 23 Aug 2010    Post subject: Reply with quote
BLUEX5 wrote:
Are you regularly finding the limits of grip on the stock rims?
Do you know that bunging bigger rims and tyres on a bike not originally designed for them my cause handling issues (if it fucks up the geometry it might even make it terminally unstable)?
My opinion is you are looking to stick bigger rubber on for purely cosmetic reasons, which is pretty gay.
Well thats you opinon isnt it. I know plent of people that have swapped and changed items and parts on bike to make the look and proformance better. The geometry will be fine as long as the front and back tyre run in line with each other. Also if the forks are the same length as the TZR there wont be ay problems. So in my and other peoples opinion the bigger tyres will only make the bike handle better.
So why is this "Gay"????
PostPosted: 16:27 - 23 Aug 2010    Post subject: Reply with quote
Needs more than just the wheels to be in line.
The RS wheel and tyre are signicantly wider (110 rather than 90), which will change how the front and rear react as you lean over. Ie, lean over at 45 degree and the front is lifted up 6~7mm relative to the back compared to a stock tyre.
The wider tyre means more weight, which will make the suspension less effective.
The front forks will need changes to cope with the different weight of the bike, weight distribution, etc.
The benefits are pretty much non existant. A wider contact patch in itself does not give more friction (basic physics), so you are relying on using a better tyre.
Mentioning tyres the RS uses radial tyres. If you use the RS front wheel and stock tyre with the stock TZR back end then you will have the problem that the rear isn't a radial and no radials are around which are that narrow (front radial and cross ply rear is illegal). Swapping to an RS rear wheel will be very difficult as it is FAR wider than the TZR rear wheel (RS front tyre is wider than the TZR rear tyre) and almost certainly wouldn't fit in the swinging arm, let alone have the chain line up (even if you swap the wheel over as the RS chain is on the opposite side). That leaves trying to find a suitable cross ply front.
You will also almost certainly have to swap the clocks (doubt the RS and TZR speedo drives are geared the same, and the TZR one will certainly not fit the RS wheel spindle).
And that is ignoring the basics such as the forks being about the same length, being able to fit the bars in the fairing, being able to get the RS yokes to mate to the TZR steering head stem, lock stops being in the right place, getting the TZR ignition switch to fit the RS yokes, etc.
Stuster
PostPosted: 16:45 - 23 Aug 2010    Post subject: Reply with quote
Hi Keith, Thanks for the advice. I have seen a few of you thread and always seem to be clued up on these matters.
I will take into account what you have said. Is there anything else that you can suggest? Like i said its more the back end i dont like. I think the TZR back wheel just looks a little silly haha. What if I put a fatter back tyre on? Would this change things?
Thanks again Smile
Stuster
PostPosted: 16:49 - 23 Aug 2010    Post subject: Reply with quote
OK, You obviously know it all so I'll shut the fuck up and let you ruin your own bike in peace. Middle Finger
hahaha, I have'nt said that i now anything. I said that this was my opinion thats all. If I new it all I wouldnt be on this forum would I. I would be happy if you offered me some advice insted of being illiterate and posting abusive messages.
Like I say if you do have any advice for me I will take this on board. I dont now an awful lot about motorcycles and am just looking at a few opions thats all.
Thanks Stuart Very Happy
Stuster
PostPosted: 16:59 - 23 Aug 2010    Post subject: Reply with quote
Keith, you have a TZR 250 rite? Is the wheel base on them any different? What would be the options with this? Would the swingarm and forks line up? I now the frame is different.
Regards Stuart Smile
PostPosted: 17:03 - 23 Aug 2010    Post subject: Reply with quote
Seriously, if you want it to work well then keep it fairly stock. Invest in decent tyres of the stock sizes.
Fatter tyre on the stock rim will really screw up the handling as the tyre will be pinched out of shape.
andysdad
PostPosted: 15:55 - 07 Sep 2010    Post subject: rs rear Reply with quote
all u need is the rs swingarm and wheel, if u stayed close to me u could have came round and we coulda did it in a day. have u went ahead with this then or did these ppl talk u out of it?
1992 TZR 125
1999 Impreza WRX
PostPosted: 16:11 - 07 Sep 2010    Post subject: Reply with quote
RS125 chain is on the other side to the TZR125, and being a banana swinging arm you can really run the chain on the wrong side or invert the swinging arm. So fitting an RS swinging arm to a TZR is a bit of a non starter
PostPosted: 16:22 - 07 Sep 2010    Post subject: Reply with quote
Two points:
Arrow Anyone who thinks simply putting wider tyres on a bike will make it handle better is a complete moron.
Arrow last line of my sig. Read it.
PostPosted: 16:28 - 07 Sep 2010    Post subject: Reply with quote
Re-reading this thread I do despair at the state of the future of humanity.
This is why people like Stan Stephens say that advice given on internet forums is crap. Because, a lot of it is.
Digit
PostPosted: 19:16 - 07 Sep 2010    Post subject: Reply with quote
Increasing the area of rubber in contact with the road will not guarantee any improvement in handling. Consider this.
Increase foot print by a theoretical 10% and you have reduced the loading per sq inch/centimetre which, depending on rubber mix, can reduce grip.
Roy.
Happy daze!
PostPosted: 20:34 - 07 Sep 2010    Post subject: Re: rs rear Reply with quote
Well, we know a bit about bikes (unlike yourself) and also we are able to write the english language (unlike yourself).
Please, it is important for the mental and financial well being of the OP that he doesn't try any ill conceived modifications to his TZR. All we're trying to do is to help. If he wants to go ahead and ruin a perfectly good bike, its no skin off of our nose... however it is important to note that Keith, myself and BlueX5 have given the proper advice rather than mere forum bluster like yourself.
Anybody can come on a forum and go "Yeah sure it is possible". If three of the maybe ten people on this forum who could make such a mod work if it were possible advise against it, then I'd take note personally. But of course, what do I know? I've only rebuilt the front ends on maybe seven bikes so I bow down to your superior knowledge.
Digit
PostPosted: 20:54 - 07 Sep 2010    Post subject: Reply with quote
I've modded the front end on two bikes, one, many years ago, a Francis Barnett, ran on 18 inch rims. In those days the only tyre was the Avon Safety Mileage a misnomer if ever there was. It was flat across the tread and would fall into the corners, we used to buff the edges off to improve them.
The engine was highly tuned and the grip awful, plus the front brake was a single leading shoe, so I rebuilt the hub to give two leading shoes and a 19 inch rim as i could then buy a tyre with a round profile.
Worked a treat, till I parked, the extra height meant that the centre stand would not reach the ground and the damn thing fell over!
Roy.
Happy daze!
stevo as b4
PostPosted: 09:18 - 08 Sep 2010    Post subject: Reply with quote
You want thin and light wheels and tyres on your TZR, maybe decent branded fairly grippy ones mind, given the limitations of tyre choice in the small sizes that are used on the TZR. If you can get Pirelli MT65's or similar in the size you need then fit them as they have excellent grip in the dry and are good in the wet too!
Thin tyres and small lightweight wheels are your friends so that you can make the most of your 22bhp or thereabouts. Look at how well the Kawasaki AR125's went in full power form 90mph, and they have 3.0/3.25" section tyres as std.
Stuster
PostPosted: 23:00 - 06 Oct 2010    Post subject: Reply with quote
Thanks for all your advice guys. Like i said i dont now a lot about bikes so was just after a little advice on the matter,
I think i will keep the stock rims on as advised as said many times in here you do no more than me. (Rookie)
Much appriciated guys and thanks.
The last post was made 15 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 142.48 Kb
