Knocking from between footpegs
kooga13
PostPosted: 11:34 - 24 Aug 2010    Post subject: Knocking from between footpegs Reply with quote
Hi, my Sprint 955 ST has developed a knocking sound which seems to be coming from between my feet. Bike is a 2000 model, 40k on clock, last serviced about 300 miles ago. I can feel and hear a clunk when opening the throttle and also when closing the throttle, it feels like something is loose. When i ride slow and lightly flick the throttle open and closed the knock is really bad. Theres no noises when the engine's ticking over and it doesn't do it when the clutch is disengaged. It's got progressively worse over the past few weeks and I can now feel a bit of a knocking between the pegs during normal riding. Theres also a very small oil (i think) leak, just a few occasional spots after a long ride. I think it's coming from a very thin tube (looks like a wire) that's hanging loose just above the gear lever. Oh, and first to second is very stiff if the bike is cold (not sure if these things are related!) Any advice or obvious things to check would be much appreciated, Cheers
Paxovasa
PostPosted: 11:40 - 24 Aug 2010    Post subject: Reply with quote
Check the chain for tight spots, check the centre stand (if one fitted).
kooga13
PostPosted: 11:53 - 24 Aug 2010    Post subject: Reply with quote
Centre stand is ok, chain seems fine and is well lubed. Will read up on tight spots (im fairly new to all this), check and get back. Thanks
Acemastr
PostPosted: 12:23 - 24 Aug 2010    Post subject: Reply with quote
I get this on my CBR, word has it it's the final drive bearing but I've not confirmed this, if you do find out please let me know!
2016 Toyota Tacoma Limited
jowettdriver
PostPosted: 13:07 - 24 Aug 2010    Post subject: Reply with quote
From what you describe it sounds like something to do with the transmission or final drive.
Are the front and rear sprockets corectly fitted? I have known the front sprocket to come loose and chew the splines causing knocking sounds to come from the transmission. (although this was on a cg, so not sure if the sprint has the sprocket attatched in the same way.)
Tim.
Bikes: 1980 Honda CX500, 2003 Honda CB250, 1980 Honda CG125
kooga13
PostPosted: 13:33 - 24 Aug 2010    Post subject: Reply with quote
There is some lateral play in the rear sprocket, not sure if this is normal? i'll have a look at the front sprocket later - what should i look for? (i.e. whats normal?). sorry if this is a stupid question lol
jowettdriver
PostPosted: 14:28 - 24 Aug 2010    Post subject: Reply with quote
Not a stupid question at all!! I probably should have explained better.
When you say there is some lateral play in the rear sprocket, how much do you mean? Roughly how far does the outer edge of the sprocket move when you pull at it?
As far as the front sprocket is concerned, if the sprocket is the splined type then it should be a nice snug fit over the splines and held by the locking ring with no visible run out (no sideways movement or wobble)
Tim.
kooga13
PostPosted: 15:43 - 24 Aug 2010    Post subject: Reply with quote
hi ,theres probably about 3 - 5mm lateral play in the rear sprocket. what are splines?? cheers!
Paxovasa
PostPosted: 16:05 - 24 Aug 2010    Post subject: Reply with quote
Splines are the groves in the rod that the sprocket slots onto Thumbs Up
As in the pic: https://t0.gstatic.com/images?q=tbn:sOyocue39qcIjM:https://i18.photobucket.com/albums/b149/scoopdoc/144_4455.jpg&t=1[img]
ZRX61
Victor Meldrew
PostPosted: 16:18 - 24 Aug 2010    Post subject: Reply with quote
[quote="Paxovasa"]
The word you're struggling to find is 'shaft" Wink
Paxovasa
PostPosted: 16:20 - 24 Aug 2010    Post subject: Reply with quote
Is that not a "shaft drive" Wink
jowettdriver
PostPosted: 21:39 - 24 Aug 2010    Post subject: Reply with quote
3-5mm sounds like an awful lot to me, it may be worth checking the bolts that attatch the sprocket to the wheel are tight.
kooga13
PostPosted: 10:34 - 25 Aug 2010    Post subject: Reply with quote
Tightened up rear sprocket bolts and there's no play now but the knocking is still there. Did some investigating last night: took the front sprocket cover off & it looked fine but i took some pics so i'll post them later. chain had about 30mm of play at the centre of the lower part - is this excessive? also noticed that when the bike is in gear and being rolled back / fwd with clutch in, it clunks when first pushed. it doesnt do it in neutral - again, not sure whether this is normal?
ZRX61
Victor Meldrew
PostPosted: 18:17 - 25 Aug 2010    Post subject: Reply with quote
Of course it isn't, but you posted a picture of the lay shaft...
Paxovasa
PostPosted: 18:42 - 25 Aug 2010    Post subject: Reply with quote
So humour escapes you Rolling Eyes
I posted that pic as an example of the spines, as they did not know what was meant by the term "spines" Thumbs Up
ZRX61
Victor Meldrew
PostPosted: 18:59 - 25 Aug 2010    Post subject: Reply with quote
& confused matters by refering to it as a rod... there's more than enough misinformation from the mechanical muppets on this site without adding to it Wink
jowettdriver
PostPosted: 08:35 - 26 Aug 2010    Post subject: Reply with quote
If you can find no problems with the final drive, (chain and sprockets) then i'm afraid that the problem is likely to be within the transmission. Its always worth checking the simple things first though.
The stiffness in the change from first to second when cold, has it always been like that or has this come on over the last few weeks/months?
It sounds like you have some play somewhere within the transmission, it is at its worst when moving from power to the overrun, but has now started to knock all the time, suggesting it is getting worse. If the stiffness in the change is a new problem then this also points in this direction.
I'm sorry I can't be of more help, but unless you live near Norwich I think it is time to get someone to look at it for you.
Tim.
kooga13
PostPosted: 09:26 - 26 Aug 2010    Post subject: Reply with quote
thanks for all the advice, i'll take it to a mechanic Crying or Very sad and post an update when sorted
The last post was made 16 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 94.79 Kb
