Current Drawn...
Martay
PostPosted: 21:09 - 23 Aug 2010    Post subject: Current Drawn... Reply with quote
Hi there,
doing a little vehicle wiring, and ive managed to confuse myself working out the current drawn in the circuit, so i can work out the size of fuse needed and weather the relay is strong enough.
Basically, im using a relay (switched from the high beam) to turn on a set of OE foglights, and a set of spotlights bumper mounted.
Ive attached a bad paint diagram. Its a 12v circuit. Could someone work out the current drawn by the entire setup please Very Happy
Massive thanks and Karma for all help.
Many Ta's
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
Hex
Party Boy
PostPosted: 22:11 - 23 Aug 2010    Post subject: Reply with quote
I could be well out but if Amps is Watts/Volts your pulling like 17-18 and a bit Amps.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Martay
PostPosted: 22:41 - 23 Aug 2010    Post subject: Reply with quote
Yeah thats the 'formula' that i was thinking, but wasnt sure if it was true because of the parallel-ness! I think im making a simple problem complicated!
Anywho, cheers
herulach
PostPosted: 22:51 - 23 Aug 2010    Post subject: Reply with quote
Each of those bulbs will only be seeing 6V in that circuit, so not only will they be a nice shade of yellow, I doubt they'll be 55w at that voltage either.
You need to wire it so they all see 12V (or more like 14). in which case each bulb will draw about 4 amps. Add a bit for wire losses and you're looking at a 20A fuse. Make sure you've got some nice fat wire!
YBR 125>FZS600
colin1
Captain Safety
PostPosted: 23:52 - 23 Aug 2010    Post subject: Reply with quote
power = voltage x current
so current = power / voltage
ie current = 55 x 4 / 12
= 220 /12
= 18.3 amps
herulach is right though you should wire them all in parallel not in series, as it is, they wont be fully lighting up so it will be using more like 9 amps
wired correctly and they would be drawing 18.3 amps, at the moment probably just 9amps
Martay
PostPosted: 08:12 - 24 Aug 2010    Post subject: Reply with quote
Awesome stuff Smile
A tad more wiring than i thought, but it'll give me something to do today!
Cheers for the help, saved me from hours of disappointment!
Karma
Hex
Party Boy
PostPosted: 08:58 - 24 Aug 2010    Post subject: Reply with quote
What he said, I knew I'd missed something. Laughing
Martay
PostPosted: 12:10 - 24 Aug 2010    Post subject: Reply with quote
DONE!
Spent all morning wiring the lights in, and they all work as they should. Rather than having one 12v feeding 2 lights, ive got 4 seperate 12v feeds, one for each light. Each light then has its own earth.
All work at maximum bright-ness.
Cheers for the help. Im really impressed =)
herulach
PostPosted: 19:48 - 24 Aug 2010    Post subject: Reply with quote
Is that on your 125? Hope you've got a trickle charger, I'd put money on the alternator not being able to keep up with that current draw.
YBR 125>FZS600
Fortuna
PostPosted: 20:17 - 24 Aug 2010    Post subject: Reply with quote
Hi,
I'm an electronics engineer so can offer some assistance.
As has be pointed out all the bulbs needed to be parallel which you've now done.
Using the basic Ohms law formula of I=P/V (I being current, P power and V voltage) we get 18.333 recurring.
i.e. 220W/12V=18.333A.
Wattage is additive in calculations.
As pointed out you need a 20amp fuse.
Not repeating what is written above, just confirming it Smile
Martay
PostPosted: 09:20 - 25 Aug 2010    Post subject: Reply with quote
Nah, its not on the bike. On the front of my fiesta. Same as this, but this is an internet pic. (https://www.google.co.uk/imgres?imgurl=https://img.photobucket.com/albums/v355/add_name_here/S8000836.jpg&imgrefurl=https://b-techracing.blogspot.com/&usg=__kEgrHJ0fAcNSgC6b2N2JirwXHxw=&h=600&w=800&sz=182&hl=en&start=21&zoom=1&tbnid=ZWC01tUWFcUQZM:&tbnh=141&tbnw=182&prev=/images%3Fq%3Dfiesta%2Bmk4%2Bspotlights%26um%3D1%26hl%3Den%26sa%3DN%26biw%3D1280%26bih%3D609%26tbs%3Disch:10%2C247&um=1&itbs=1&iact=hc&vpx=638&vpy=306&dur=1893&hovh=194&hovw=259&tx=112&ty=159&ei=WdF0TJQ418-MB6Ox4ZsG&oei=TdF0TPyTH5eP4ga18b3nBQ&esq=2&page=2&ndsp=18&ved=1t:429,r:3,s:21&biw=1280&bih=609)
herulach
PostPosted: 22:50 - 25 Aug 2010    Post subject: Reply with quote
Hmmmm, tasteful.
YBR 125>FZS600
The last post was made 16 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 76.59 Kb
